hi everyone, i recently have a problem with the network connection
when i start the pc, the network is connected (to the LAN), but I haven’t connected to the internet and the ping google.com
has not any result.
but when i restart the networkmanager by sudo systemctl restart NetworkManager
the problem will solve!
i don’t know how to solve this. the following is the log result when i started the pc and haven’t the internet connection
My pc info :
OS: Manjaro Linux x86_64
Kernel: 5.15.46-1-MANJARO
DE : KDE
systemctl status NetworkManager
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Wed 2022-06-15 22:13:47 +0430; 41s ago
Docs: man:NetworkManager(8)
Main PID: 674 (NetworkManager)
Tasks: 15 (limit: 18927)
Memory: 11.8M
CPU: 155ms
CGroup: /system.slice/NetworkManager.service
└─674 /usr/bin/NetworkManager --no-daemon
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9226] device (enp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9229] device (enp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9234] manager: NetworkManager state is now CONNECTED_LOCAL
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9240] manager: NetworkManager state is now CONNECTED_SITE
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9241] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9265] device (enp4s0): Activation: successful, device activated.
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9274] manager: startup complete
Jun 15 22:13:52 Manjaro NetworkManager[674]: <info> [1655315032.2696] dhcp6 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Jun 15 22:13:52 Manjaro NetworkManager[674]: <info> [1655315032.2707] policy: set 'Wired connection 1' (enp4s0) as default for IPv6 routing and DNS
Jun 15 22:13:53 Manjaro NetworkManager[674]: <info> [1655315033.6126] agent-manager: agent[b29a61808211ae8a,:1.26/org.kde.plasma.networkmanagement/1000]: agent registered
journalctl -xeu NetworkManager
Jun 15 22:13:47 Manjaro systemd[1]: Starting Network Manager...
░░ Subject: A start job for unit NetworkManager.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit NetworkManager.service has begun execution.
░░ The job identifier is 93.
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6578] NetworkManager (version 1.38.0-1) is starting... (for the first time)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6578] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Jun 15 22:13:47 Manjaro systemd[1]: Started Network Manager.
░░ Subject: A start job for unit NetworkManager.service has finished successfully
░░ A start job for unit NetworkManager.service has finished successfully.
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6592] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6637] manager[0x55767608c010]: monitoring kernel firmware directory '/lib/firmware'.
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6920] hostname: hostname: using hostnamed
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6920] hostname: static hostname changed from (none) to "Manjaro"
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6925] dns-mgr[0x55767605c250]: init: dns=default,systemd-resolved rc-manager=symlink
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6926] manager[0x55767608c010]: rfkill: Wi-Fi hardware radio set enabled
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6927] manager[0x55767608c010]: rfkill: WWAN hardware radio set enabled
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6983] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-bluetooth.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6987] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-wwan.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.6993] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-adsl.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7051] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-team.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7068] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-ovs.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7089] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.38.0-1/libnm-device-plugin-wifi.so)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7091] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7092] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7092] manager: Networking is enabled by state file
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7105] settings: Loaded settings plugin: keyfile (internal)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7168] dhcp-init: Using DHCP client 'internal'
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7168] device (lo): carrier: link connected
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7169] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7175] manager: (enp4s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7180] settings: (enp4s0): created default wired connection 'Wired connection 1'
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7180] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7887] ovsdb: disconnected from ovsdb
Jun 15 22:13:47 Manjaro NetworkManager[674]: <info> [1655315027.7893] modem-manager: ModemManager available
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9082] device (enp4s0): carrier: link connected
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9088] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9098] policy: auto-activating connection 'Wired connection 1' (e64ca8b4-a0e7-356d-b16e-8e2720f3161b)
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9110] device (enp4s0): Activation: starting connection 'Wired connection 1' (e64ca8b4-a0e7-356d-b16e-8e2720f3161b)
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9112] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9116] manager: NetworkManager state is now CONNECTING
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9119] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9133] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9138] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9161] dhcp4 (enp4s0): state changed new lease, address=192.168.1.109
Jun 15 22:13:49 Manjaro NetworkManager[674]: <info> [1655315029.9187] device (enp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
