i’m inclined to believe sway and wayland are working for other folks. i wonder why not for me? Are sTinkPads not happy on wayland? This vid gave me (false?) hope. My e540’s quite a bit newer than that one afterall. Haven’t gone and tried ubu as of yet tho.
Configure NVIDIA (non-free) settings and load them on Startup suggests how to switch between free and nonfree drivers, but it requires a reboot. Is there a way to do so with the iso?
manjaro-sway-21.1.0-211230-linux515.iso
boots up, my keyboard and mouse work, i can use either one to change the language or dismiss the installer, mod+? toggles the help just fine, but neither mod+enter nor mod+d bring up a shell or a launcher, and after trying them, nothing further appears in either journalctl
or dmesg
and no new or changed files appear within /tmp/** /home/** /var/log/**
. Same lack of response whether i boot up with or without my 2nd and 3rd displays attached. Any ideas?
i’m on a ThinkPad e540.
Here’s the sway live environment dmesg: http://ix.io/3KoF
Here’s the sway live environment journalctl: http://ix.io/3Kos
Neither inxi nor xrandr are in the sway iso. Here they are on my installed KDE system:
# inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=b2d9c25b-03ab-4676-ae6e-cc4dce724d09 rw panic=30
udev.log_priority=3
Desktop: N/A wm: kwin_x11 vt: 1 dm: startx Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 20C6008SUS v: ThinkPad Edge E540
Mobo: LENOVO model: 20C6008SUS v: 0B98401 WIN serial: <superuser required>
UEFI: LENOVO v: J9ETA2WW (2.28 ) date: 06/20/2018
ID-1: BAT0 charge: 17.6 Wh (51.6%) condition: 34.1/52.8 Wh (64.5%)
volts: 11.3 min: 11.1 model: LGC LNV-45N1 type: Li-ion serial: <filter>
status: Not charging
RAM: total: 7.65 GiB used: 3.13 GiB (40.9%)
RAM Report:
Info: model: Intel Core i5-4200M bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2494 high: 2495 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2494 2: 2495 3: 2494
4: 2495 bogomips: 19961
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Realtek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-12:7 chip-ID: 0bda:5719 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2616 s-dpi: 96 s-size: 507x691mm (20.0x27.2")
s-diag: 857mm (33.7")
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 1038:12ad
class-ID: 0300
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:08b2 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
bus-ID: 3-7:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 465.76 GiB used: 147.97 GiB (31.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS725050A7E635
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A8Z0 scheme: GPT
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ8E2 rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 415.84 GiB size: 408.31 GiB (98.19%)
used: 147.93 GiB (36.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b2d9c25b-03ab-4676-ae6e-cc4dce724d09
ID-2: /boot/efi raw-size: 476 MiB size: 475.1 MiB (99.80%)
used: 38.7 MiB (8.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1FEA-1CC9
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /f/swapfile
ID-1: /dev/sda3 maj-min: 8:3 size: 16.76 GiB fs: ntfs label: N/A
uuid: 03FDF2F31548EC3F
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-1:2 info: SteelSeries ApS SteelSeries Arctis 7 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:12ad class-ID: 0300
Device-2: 3-2:3 info: Dell KB216 Wired Keyboard type: Keyboard,HID
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Device-3: 3-6:4 info: Dell Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:3012 class-ID: 0301
Device-4: 3-7:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-5: 3-11:6 info: Validity Sensors VFS5011 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0011 class-ID: ff00 serial: <filter>
Device-6: 3-12:7 info: Realtek Integrated Camera type: Video
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 213 Uptime: 1h 9m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1142 lib: 312 Shell: Bash v: 5.1.12
running-in: tmux-master2021 inxi: 3.3.11
# xrandr
Screen 0: minimum 320 x 200, current 1920 x 2616, maximum 16384 x 16384
eDP-1 connected primary 1366x768+552+1848 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.01*+
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
VGA-1 connected 1366x768+553+1080 (normal left inverted right x axis y axis) 256mm x 274mm
1360x768 59.95* 60.02
1024x768 75.03 70.07 60.00
800x600 85.06 72.19 75.00 60.32 57.90 56.25
640x480 75.00 72.81 59.94
720x400 70.08
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 698mm x 392mm
1920x1080 60.00*+ 59.94 30.00 24.00 29.97 23.98
1920x1080i 60.00 59.94
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 59.90
1280x960 60.00
1360x768 60.02
1280x800 59.91
1152x864 75.00
1280x720 60.00 60.00 30.00 59.94 29.97 24.00 23.98
800x600 72.19 75.00 60.32
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 75.00 72.81 60.00 59.94
720x400 70.08
DP-1 disconnected (normal left inverted right x axis y axis)
if any further info might help, i’ll be glad to provide…
