The Manjaro installation didn't continue
[manjaro@manjaro ~]$ inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2411 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=0
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Hewlett-Packard product: HP Pavilion dv6 Notebook PC
    v: 0596100000244610000020100 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 3581 v: 10.1C serial: <superuser required>
    part-nu: LC941EA#ABF uuid: <superuser required> BIOS: Hewlett-Packard v: F.05
    date: 02/10/2011
  System RAM: total: 4 GiB available: 3.77 GiB used: 2.25 GiB (59.7%)
  Array-1: capacity: 8 GiB slots: 2 modules: 1 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Bottom - Slot 1 (top) type: no module installed
  Device-2: Bottom - Slot 2 (under) type: DDR3 detail: synchronous
    size: 4 GiB speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 16JSF51264HZ-1G4D1
    serial: <filter>
  Info: model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2095 min/max: 800/2100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2095 2: 2095 3: 2095 4: 2095 bogomips: 16770
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
    mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M
    Series] vendor: Hewlett-Packard driver: N/A alternate: radeon, amdgpu
    arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
    pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
    chip-ID: 1002:6760 class-ID: 0300
  Device-3: Suyin HP TrueVision HD Integrated Webcam driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:3
    chip-ID: 064e:e258 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
  Monitor-1: LVDS-1 model: Seiko Epson 0x4251 built: 2008 res: 1366x768
    hz: 60 dpi: 101 gamma: 1.2 chroma: red: x: 0.580 y: 0.341 green: x: 0.310
    y: 0.549 blue: x: 0.153 y: 0.153 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    device-ID: 8086:0116 memory: 1.46 GiB unified: yes
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Ralink RT5390 [802.11 b/g/n 1T1R G-band PCI Express Single Chip]
    vendor: Hewlett-Packard Pavilion DM1Z-3000 PCIe wireless card
    driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 0d:00.0 chip-ID: 1814:539f class-ID: 0280
  Device-1: Ralink CSR BS8510 driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.5:4 chip-ID: 148f:2000
    class-ID: e001
  Local Storage: total: 654.77 GiB used: 5.93 GiB (0.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK6465GSX
    size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 2C scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 model: N/A size: 58.59 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
    mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
  Optical-1: /dev/sr0 vendor: hp model: CDDVDW TS-L633R rev: 0300
    dev-links: cdrom
  ID-1: /tmp/calamares-root-5ktq3bm5 raw-size: 587.86 GiB
    size: 577.57 GiB (98.25%) used: 5.93 GiB (1.0%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: 8d83d115-89bd-47c3-b0b2-a466395d3ae0
  ID-1: /dev/sda2 maj-min: 8:2 size: 8.3 GiB fs: swap label: swap
    uuid: 0c024a1a-3168-4366-b8d7-9cd9b68df5a9
  ID-2: /dev/sdb1 maj-min: 8:17 size: 3.56 GiB fs: iso9660
  ID-3: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 3AA3-EE45
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.2:3 info: Suyin HP TrueVision HD Integrated Webcam
    type: video driver: uvcvideo interfaces: 2 rev: 2.0
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.3:3 info: USB Disk 2.0 type: mass storage driver: usb-storage
    power: 100mA chip-ID: 346d:5678 class-ID: 0806 serial: <filter>
  Device-2: 2-1.4:5 info: SiGma Micro XM102K Optical Wheel Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 1c4f:0034 class-ID: 0301
  Device-3: 2-1.5:4 info: Ralink CSR BS8510 type: bluetooth driver: btusb
    chip-ID: 148f:2000 class-ID: e001
  System Temperatures: cpu: 74.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1168 libs: 329 tools: pamac pm: flatpak pkgs: 0
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors2.manjaro.org/stable/$repo/$arch
    3: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    4: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    5: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    6: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    7: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    9: https://mirror.23m.com/manjaro/stable/$repo/$arch
    10: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    11: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    13: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    15: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    17: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    18: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    21: http://manjaro.grena.ge/stable/$repo/$arch
    22: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    23: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    24: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    25: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    28: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    29: https://linorg.usp.br/manjaro/stable/$repo/$arch
    30: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    31: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    32: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    33: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    34: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    36: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    38: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    39: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    40: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    41: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    43: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    44: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    45: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    46: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    47: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    49: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    50: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    51: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    52: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    53: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    54: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    55: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    56: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    57: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    58: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    59: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    60: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    61: https://manjaro.ynh.ovh/stable/$repo/$arch
    62: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    63: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    64: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    65: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    66: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    67: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    68: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    69: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    70: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    71: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    72: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    73: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    75: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    76: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    77: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    78: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    79: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    80: https://repos.silknet.com/manjaro/stable/$repo/$arch
    81: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    82: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    83: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    84: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    85: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    86: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    87: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    88: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    89: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    90: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    91: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    92: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    93: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    94: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    95: http://manjaro.mirror.ac.za/stable/$repo/$arch
    96: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    97: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    98: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    99: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    100: https://manjaro.kurdy.org/stable/$repo/$arch
    101: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    102: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    103: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    104: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    105: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    106: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    107: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    108: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    109: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    111: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    112: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    113: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    114: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    115: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    116: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    117: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    118: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    119: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    120: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    121: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    122: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    123: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    124: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    125: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    126: https://mirror.init7.net/manjaro/stable/$repo/$arch
    127: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    128: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    129: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    130: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    131: https://mirror.zetup.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 223
  1: cpu: 50.0% command: ps pid: 4348 mem: 3.34 MiB (0.0%)
  2: cpu: 42.7% command: firefox pid: 3432 mem: 487.5 MiB (12.6%)
  3: cpu: 40.2% command: rsync pid: 4230 mem: 7.97 MiB (0.2%)
  4: cpu: 24.7% command: firefox pid: 3727 mem: 239.7 MiB (6.2%)
  5: cpu: 23.4% command: rsync pid: 4232 mem: 9.75 MiB (0.2%)
  Memory top: 5 of 223
  1: mem: 487.5 MiB (12.6%) command: firefox pid: 3432 cpu: 42.7%
  2: mem: 317.5 MiB (8.2%) command: calamares pid: 2758 cpu: 17.7%
  3: mem: 239.7 MiB (6.2%) command: firefox pid: 3727 cpu: 24.7%
  4: mem: 136.5 MiB (3.5%) command: firefox pid: 3765 cpu: 1.6%
  5: mem: 130.4 MiB (3.3%) command: firefox pid: 3619 cpu: 1.0%
  Processes: 223 Power: uptime: 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 1.47 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.36
I KNEW MY SOLUTION WILL WORK
Wait if i fixed it that means i can install the OS normally and it works
I edit the grub menu and at the line that starts with linux add radeon.modeset=0
Kernel 6.10 has reached End of Life (EOL). It should be replaced with either the latest kernel available, or the latest LTS kernel available. Note that Kernel 6.12 (LTS) is expected to be available in November. LTS kernels are often the safest route.
You only have 4 GB of RAM.
I might typically suggest increasing the size of your swap to compensate, but I see you have none configured at all;
It would be beneficial to create some.
If your intention is to reinstall in any case, I’d suggest creating an 8/12 GB swap partition during install. If using the Calamares erase disk partitioning method, the option to configure swap is given – you just need to not ignore it.
Good luck.
