The global keyboard shortcut for guake stopped working for me (was F12 for me).
There is an open issue with guake: Guake Reports Error When Trying To Bind F12 Key. · Issue #2295 · Guake/guake · GitHub
But it seems strange that it broke only after this update for me.
Your post has been moved to a dedicated topic.
Pleas provide your system information and someone will help when they are able. Regards. ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
