The fate of Manjaro ARM Unstable
For those switching to EndeavourOS.
Can you tell me what they put in /etc/fstab, in /etc/environment, .bash_profile, .bashrc.
The size of the boot partition and if it’s FAT 16 or 32 formatting.
cmdline.txt and config.txt.
Personally, if I switch, it will be to Arch, so I might as well go straight to the source, and honestly, it’s not that complicated. For example, for Gnome, you can do pacman -S gnome networkmanager and then launch the gdm and networkmanager services. That’s the end of the basic configuration.
fstab had the boot partition only. i also added the root partition when i migrated to my SSD.
environment is basically blank.
bash_profile has this line only
[[ -f ~/.bashrc ]] && . ~/.bashrc
bashrc has:
[[ $- != i ]] && return
alias ls=‘ls --color=auto’
alias grep=‘grep --color=auto’
PS1='[\u@\h \W]$ ’
I don’t remember the size of the original boot partition, i made it 512mb and fat32. It works.
cmdline.txt
rw rootwait console=serial0,115200 console=tty1 fsck.repair=yes
config.txt
# For more options and information see:
# http://rptl.io/configtxt
dtparam=audio=on
dtoverlay=vc4-kms-v3d
display_auto_detect=1
disable_overscan=1
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=0
# Enable DRM VC4 V3D driver
# dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Uncomment if hdmi display is not detected and composite is being output
# hdmi_force_hotplug=1
# Uncomment if you want to disable wifi or bluetooth respectively
# dtoverlay=disable-wifi
# dtoverlay=disable-bt
# Uncomment this to enable infrared communication.
# dtoverlay=gpio-ir,gpio_pin=17
# dtoverlay=gpio-ir-tx,gpio_pin=18
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
In the original config.txt, bluetooth was disabled. Endevour comes bluetooth disabled by default (for security reasons they say)
i find all here
https://github.com/endeavouros-arm/image-build-script/blob/main/script-image-build.sh and https://github.com/endeavouros-arm/image-build-script/blob/main/config-eos.sh
boot size apparently it’s 458 for manjaro, and 512 endeavour et recommended for bookworm https://forums.raspberrypi.com/viewtopic.php?t=359690. And gpt fot endeavour? need testing if disk/sdcard
Maybe you or someone else could synchronize the packages from time to time, for example, once a month?
If anyone has any suggestions on what to put in adduser
manjaro
 useradd -D
GROUP=1000
GROUPS=
HOME=/home
INACTIVE=-1
EXPIRE=
SHELL=/bin/bash
SKEL=/etc/skel
USRSKEL=/usr/etc/skel
CREATE_MAIL_SPOOL=yes
LOG_INIT=yes
groups
bloodmoon sys network scanner power video storage optical lp input wheel
useradd -m -u 1000 -G wheel,sys,audio,input,video,storage,lp,network,users,power -s /bin/bash bloodmoon
endeavouros
useradd -m -G wheel,sys,rfkill,users -s /bin/bash -u 1000 "$USERNAME"
archarm has
group 984 shell usr/bin/bash and mail spool no
I installed Manjaro on my Pi 5 using this image a while ago. It would always get regular updates over many months, but now not a single package has been updated since August. Is it dead?
https://forum.manjaro.org/t/the-fate-of-manjaro-arm-unstable/181661/26
