The desktop won't start after lock screen error
The screen locker is broken and unlocking is not possible anymore.
In order to unlock switch to a virtual terminal (e.g. Ctrl+Alt+F2),
log in and execute the command:
loginctl unlock session c2
Afterwards switch back to the running session
I restarted and then the PC won’t start. Just stay charging the desktop untill the middle of the line of charge and stop
I have this errors.
journalct1 -xb -p3
  • Journal begins at Fri 2021-07-16 20:12:54 -05, ends at Sat 2021-07-17 20:16:25 -05. jul 17 20:15:26 daniel-x45u systemd-backlight [302]: Failed to get backlight or LED device ‘backlight:acpi_video0’: No such device
jul 17 20:15:26 daniel-x45u systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video.
Subject: A start job for unit systemd-backlight@backlight:acpi_video0.service has failed Defined-By: systemd
A start job for unit systemd-backlight@backlight:acpi_video0.service has finished with a failure.
The job identifier is 255 and the job result is failed.
Thanks to all, and i am sorry for my English. I speak Spanish
Hola @Dgmz
welcome to the forum :slight_smile: Unfortunately, I don’t speak Spanish, but your English is quite OK. You might want to check the Spanish forum Español - Manjaro Linux Forum but I don’t know how many people are active there.
Are you starting KDE using KDE startup scripts or systemd as described here Plasma and the systemd startup – David Edmundson's Web Log
You might want to check if someone has a similar problem at https://bugs.kde.org/ and if not report it there. You might also get help here https://forum.kde.org/ to see if you can find someone to help you. You should, however try to provide as much information about your system as possible, so people have a better chance of helping you.
