Hello. I have very low color depth on my laptop when I use Manjaro OS. I can’t see that problem if I use Ubuntu for example.
Basically can see “ridges” between different colors, or color brightness, they are especially noticeable when image is dark. It looks like there is not enough bits to render the image properly. But on Ubuntu, I can’t see that problem. I have seen something similar on the internet, then there was kernel problem, but I tried different, newer kernel, and it didn’t fix it.
How can I resolve this problem?
Thank you.
Some basic information about your system may help others help you with your issue. Please read and post a full inxi output:
Sorry. Here is the output:
Kernel: 5.15.89-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a25ce011-0d70-4636-a0df-517c9df7c321 rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop E410MAB_E410MA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: E410MAB v: 1.0 serial: <filter>
UEFI: American Megatrends v: E410MAB.304 date: 02/08/2022
ID-1: BAT0 charge: 10.0 Wh (24.4%) condition: 40.9/42.1 Wh (97.3%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging
RAM: total: 3.66 GiB used: 2.86 GiB (78.3%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: A1_DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 16
total: 16 manufacturer: Micron_Technolog part-no: 4ATF1264HZ-2G6E1
serial: N/A
Device-2: A1_DIMM1 type: no module installed
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 8 microcode: 0x20
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1766 high: 2123 min/max: 800/2800 base/boost: 1100/2700
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1410 2: 2123 bogomips: 4378
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 322e:210d class-ID: 0e02
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: i915 note: X driver n/a display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: XWAYLAND0 model: AU Optronics 0x723c built: 2020
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 600 (GLK
2) direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel bus-ID: 1-7:4 v: kernel
chip-ID: 0b05:6200 alternate: snd_soc_skl,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 class-ID: 0300 chip-ID: 8086:3198 class-ID: 0403
Device-2: ASUSTek C-Media Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.89-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 238.47 GiB used: 34.91 GiB (14.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AB1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EDFK0SA6 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 131.14 GiB size: 128.02 GiB (97.62%) used: 34.9 GiB (27.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a25ce011-0d70-4636-a0df-517c9df7c321
used: 5.4 MiB (1.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 2E15-D3C8
ID-1: swap-1 type: file size: 8 GiB used: 604 MiB (7.4%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 107.04 GiB fs: ext4 label: N/A
uuid: 784aa506-2004-46f3-9e0a-c26a5c4ad360
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-1:2 info: Logitech Mouse type: Mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046d:c077
class-ID: 0301
Device-2: 1-5:3 info: Sonix USB2.0 HD UVC WebCam type: Video
Device-3: 1-7:4 info: ASUSTek C-Media Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0b05:6200 class-ID: 0300
Device-4: 1-9:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 233 Uptime: 1h 15m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1313 pm: pacman pkgs: 1309 libs: 321
tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 4
Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.24
As I understand it is unsolvable.
Then post /var/log/Xorg.0.log
Sure. Here are:
dmesg:
[ 0.000000] microcode: microcode updated early to revision 0x20, date = 2022-03-23
[ 0.000000] Linux version 5.15.89-1-MANJARO (builduser@fv-az617-851) (gcc (GCC) 12.2.1 20230111, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a25ce011-0d70-4636-a0df-517c9df7c321 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[3]: 576, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 640, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 2032
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012150fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000012151000-0x0000000076059fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007605a000-0x0000000079a2afff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079a2b000-0x0000000079a6efff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000079a6f000-0x0000000079acefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000079acf000-0x0000000079e7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079e80000-0x0000000079f5dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000079f5e000-0x000000007a972fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a973000-0x000000007a973fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007a974000-0x000000007a975fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a976000-0x000000007aa40fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007aa41000-0x000000007aac0fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007aac1000-0x000000007affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007b000000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d3709000-0x00000000d3709fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0x79a6e000 ACPI 2.0=0x79a6e014 TPMFinalLog=0x79a9b000 SMBIOS=0x79d39000 SMBIOS 3.0=0x79d38000 ESRT=0x72e42c98
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. VivoBook_ASUSLaptop E410MAB_E410MA/E410MAB, BIOS E410MAB.304 02/08/2022
[ 0.000000] tsc: Detected 1094.400 MHz processor
[ 0.000000] [Firmware Bug]: TSC ADJUST: CPU0: -127268852 force to 0
[ 0.000023] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000028] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000045] last_pfn = 0x180000 max_arch_pfn = 0x400000000
[ 0.000088] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000280] last_pfn = 0x7b000 max_arch_pfn = 0x400000000
[ 0.005506] esrt: Reserving ESRT space from 0x0000000072e42c98 to 0x0000000072e42cd0.
[ 0.005514] e820: update [mem 0x72e42000-0x72e42fff] usable ==> reserved
[ 0.005546] Using GB pages for direct mapping
[ 0.006498] Secure boot disabled
[ 0.006500] RAMDISK: [mem 0x358c1000-0x36c57fff]
[ 0.006508] ACPI: Early table checksum verification disabled
[ 0.006514] ACPI: RSDP 0x0000000079A6E014 000024 (v02 _ASUS_)
[ 0.006520] ACPI: XSDT 0x0000000079A6D728 0000E4 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.006529] ACPI: FACP 0x0000000079A6C000 000114 (v06 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.006537] ACPI: DSDT 0x0000000079A5B000 0108F0 (v02 _ASUS_ Notebook 01072009 INTL 20160930)
[ 0.006543] ACPI: FACS 0x0000000079ACD000 000040
[ 0.006547] ACPI: FPDT 0x0000000079A5A000 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.006552] ACPI: FIDT 0x0000000079A59000 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.006557] ACPI: MCFG 0x0000000079A58000 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.006562] ACPI: ECDT 0x0000000079A57000 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.006567] ACPI: SSDT 0x0000000079A56000 0000B1 (v01 Intel_ ADebTabl 00001000 INTL 20160930)
[ 0.006572] ACPI: DBG2 0x0000000079A55000 000072 (v00 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006577] ACPI: DBGP 0x0000000079A54000 000034 (v01 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006582] ACPI: HPET 0x0000000079A52000 000038 (v01 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006587] ACPI: LPIT 0x0000000079A51000 00005C (v01 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006592] ACPI: APIC 0x0000000079A50000 000084 (v04 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006597] ACPI: NPKT 0x0000000079A4F000 000065 (v01 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006602] ACPI: SSDT 0x0000000079A44000 00405E (v02 INTEL DptfTab 00000003 BRXT 0100000D)
[ 0.006607] ACPI: SSDT 0x0000000079A43000 00014E (v01 Intel_ Platform 00001000 INTL 20160930)
[ 0.006612] ACPI: SSDT 0x0000000079A42000 0004B4 (v02 PmRef Cpu0Ist 00003000 INTL 20160930)
[ 0.006617] ACPI: SSDT 0x0000000079A41000 000775 (v02 CpuRef CpuSsdt 00003000 INTL 20160930)
[ 0.006622] ACPI: SSDT 0x0000000079A40000 00035F (v02 PmRef Cpu0Tst 00003000 INTL 20160930)
[ 0.006627] ACPI: SSDT 0x0000000079A3F000 0001E6 (v02 PmRef ApTst 00003000 INTL 20160930)
[ 0.006632] ACPI: SSDT 0x0000000079A3C000 00286F (v02 SaSsdt SaSsdt 00003000 INTL 20160930)
[ 0.006637] ACPI: BGRT 0x0000000079A3B000 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.006642] ACPI: TPM2 0x0000000079A3A000 000034 (v04 _ASUS_ Notebook 00000001 AMI 00000000)
[ 0.006647] ACPI: DMAR 0x0000000079A53000 0000A8 (v01 INTEL GLK-SOC 00000003 BRXT 0100000D)
[ 0.006652] ACPI: WDAT 0x0000000079A39000 000104 (v01 00000000 00000000)
[ 0.006657] ACPI: WSMT 0x0000000079A4E000 000028 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.006661] ACPI: Reserving FACP table memory at [mem 0x79a6c000-0x79a6c113]
[ 0.006663] ACPI: Reserving DSDT table memory at [mem 0x79a5b000-0x79a6b8ef]
[ 0.006665] ACPI: Reserving FACS table memory at [mem 0x79acd000-0x79acd03f]
[ 0.006667] ACPI: Reserving FPDT table memory at [mem 0x79a5a000-0x79a5a043]
[ 0.006668] ACPI: Reserving FIDT table memory at [mem 0x79a59000-0x79a5909b]
[ 0.006670] ACPI: Reserving MCFG table memory at [mem 0x79a58000-0x79a5803b]
[ 0.006671] ACPI: Reserving ECDT table memory at [mem 0x79a57000-0x79a570c0]
[ 0.006673] ACPI: Reserving SSDT table memory at [mem 0x79a56000-0x79a560b0]
[ 0.006674] ACPI: Reserving DBG2 table memory at [mem 0x79a55000-0x79a55071]
[ 0.006676] ACPI: Reserving DBGP table memory at [mem 0x79a54000-0x79a54033]
[ 0.006677] ACPI: Reserving HPET table memory at [mem 0x79a52000-0x79a52037]
[ 0.006679] ACPI: Reserving LPIT table memory at [mem 0x79a51000-0x79a5105b]
[ 0.006680] ACPI: Reserving APIC table memory at [mem 0x79a50000-0x79a50083]
[ 0.006682] ACPI: Reserving NPKT table memory at [mem 0x79a4f000-0x79a4f064]
[ 0.006683] ACPI: Reserving SSDT table memory at [mem 0x79a44000-0x79a4805d]
[ 0.006685] ACPI: Reserving SSDT table memory at [mem 0x79a43000-0x79a4314d]
[ 0.006686] ACPI: Reserving SSDT table memory at [mem 0x79a42000-0x79a424b3]
[ 0.006688] ACPI: Reserving SSDT table memory at [mem 0x79a41000-0x79a41774]
[ 0.006689] ACPI: Reserving SSDT table memory at [mem 0x79a40000-0x79a4035e]
[ 0.006691] ACPI: Reserving SSDT table memory at [mem 0x79a3f000-0x79a3f1e5]
[ 0.006693] ACPI: Reserving SSDT table memory at [mem 0x79a3c000-0x79a3e86e]
[ 0.006694] ACPI: Reserving BGRT table memory at [mem 0x79a3b000-0x79a3b037]
[ 0.006696] ACPI: Reserving TPM2 table memory at [mem 0x79a3a000-0x79a3a033]
[ 0.006697] ACPI: Reserving DMAR table memory at [mem 0x79a53000-0x79a530a7]
[ 0.006699] ACPI: Reserving WDAT table memory at [mem 0x79a39000-0x79a39103]
[ 0.006701] ACPI: Reserving WSMT table memory at [mem 0x79a4e000-0x79a4e027]
[ 0.006909] No NUMA configuration found
[ 0.006911] Faking a node at [mem 0x0000000000000000-0x000000017fffffff]
[ 0.006917] NODE_DATA(0) allocated [mem 0x17fffc000-0x17fffffff]
[ 0.006957] Zone ranges:
[ 0.006959] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.006962] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.006964] Normal [mem 0x0000000100000000-0x000000017fffffff]
[ 0.006967] Device empty
[ 0.006969] Movable zone start for each node
[ 0.006970] Early memory node ranges
[ 0.006971] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.006973] node 0: [mem 0x0000000000059000-0x000000000009dfff]
[ 0.006975] node 0: [mem 0x0000000000100000-0x000000000fffffff]
[ 0.006976] node 0: [mem 0x0000000012151000-0x0000000076059fff]
[ 0.006978] node 0: [mem 0x0000000079f5e000-0x000000007a972fff]
[ 0.006980] node 0: [mem 0x000000007a976000-0x000000007aa40fff]
[ 0.006981] node 0: [mem 0x000000007aac1000-0x000000007affffff]
[ 0.006983] node 0: [mem 0x0000000100000000-0x000000017fffffff]
[ 0.006985] Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
[ 0.006991] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.006994] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007034] On node 0, zone DMA: 98 pages in unavailable ranges
[ 0.012674] On node 0, zone DMA32: 8529 pages in unavailable ranges
[ 0.013053] On node 0, zone DMA32: 16132 pages in unavailable ranges
[ 0.013058] On node 0, zone DMA32: 3 pages in unavailable ranges
[ 0.013078] On node 0, zone DMA32: 128 pages in unavailable ranges
[ 0.019810] On node 0, zone Normal: 20480 pages in unavailable ranges
[ 0.019843] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
[ 0.020831] ACPI: PM-Timer IO Port: 0x408
[ 0.020845] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[ 0.020849] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[ 0.020850] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[ 0.020852] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[ 0.020896] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-119
[ 0.020900] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.020903] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.020909] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.020911] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.020925] e820: update [mem 0x73554000-0x7356cfff] usable ==> reserved
[ 0.020949] TSC deadline timer available
[ 0.020952] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.021004] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.021008] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.021011] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[ 0.021014] PM: hibernation: Registered nosave memory: [mem 0x10000000-0x12150fff]
[ 0.021018] PM: hibernation: Registered nosave memory: [mem 0x72e42000-0x72e42fff]
[ 0.021021] PM: hibernation: Registered nosave memory: [mem 0x73554000-0x7356cfff]
[ 0.021024] PM: hibernation: Registered nosave memory: [mem 0x7605a000-0x79a2afff]
[ 0.021026] PM: hibernation: Registered nosave memory: [mem 0x79a2b000-0x79a6efff]
[ 0.021027] PM: hibernation: Registered nosave memory: [mem 0x79a6f000-0x79acefff]
[ 0.021028] PM: hibernation: Registered nosave memory: [mem 0x79acf000-0x79e7ffff]
[ 0.021030] PM: hibernation: Registered nosave memory: [mem 0x79e80000-0x79f5dfff]
[ 0.021033] PM: hibernation: Registered nosave memory: [mem 0x7a973000-0x7a973fff]
[ 0.021034] PM: hibernation: Registered nosave memory: [mem 0x7a974000-0x7a975fff]
[ 0.021038] PM: hibernation: Registered nosave memory: [mem 0x7aa41000-0x7aac0fff]
[ 0.021041] PM: hibernation: Registered nosave memory: [mem 0x7b000000-0x7fffffff]
[ 0.021042] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xcfffffff]
[ 0.021044] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xd0ffffff]
[ 0.021045] PM: hibernation: Registered nosave memory: [mem 0xd1000000-0xd3708fff]
[ 0.021046] PM: hibernation: Registered nosave memory: [mem 0xd3709000-0xd3709fff]
[ 0.021048] PM: hibernation: Registered nosave memory: [mem 0xd370a000-0xdfffffff]
[ 0.021049] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.021050] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfe041fff]
[ 0.021052] PM: hibernation: Registered nosave memory: [mem 0xfe042000-0xfe044fff]
[ 0.021053] PM: hibernation: Registered nosave memory: [mem 0xfe045000-0xfe8fffff]
[ 0.021054] PM: hibernation: Registered nosave memory: [mem 0xfe900000-0xfe902fff]
[ 0.021056] PM: hibernation: Registered nosave memory: [mem 0xfe903000-0xfebfffff]
[ 0.021057] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.021058] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
[ 0.021059] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
[ 0.021061] PM: hibernation: Registered nosave memory: [mem 0xfed02000-0xfedfffff]
[ 0.021062] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.021063] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff7fffff]
[ 0.021064] PM: hibernation: Registered nosave memory: [mem 0xff800000-0xffffffff]
[ 0.021067] [mem 0x80000000-0xcfffffff] available for PCI devices
[ 0.021069] Booting paravirtualized kernel on bare hardware
[ 0.021073] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.027606] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.028057] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[ 0.028071] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[ 0.028076] pcpu-alloc: [0] 0 1 2 3
[ 0.028122] Built 1 zonelists, mobility grouping on. Total pages: 987371
[ 0.028126] Policy zone: Normal
[ 0.028128] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a25ce011-0d70-4636-a0df-517c9df7c321 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.028286] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
[ 0.028941] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.029303] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.029746] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.070436] Memory: 3691156K/4012816K available (16392K kernel code, 2086K rwdata, 10936K rodata, 2016K init, 3656K bss, 321400K reserved, 0K cma-reserved)
[ 0.071353] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.071394] ftrace: allocating 44488 entries in 174 pages
[ 0.100421] ftrace: allocated 174 pages with 5 groups
[ 0.100641] rcu: Preemptible hierarchical RCU implementation.
[ 0.100642] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.100643] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.100645] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.100647] Trampoline variant of Tasks RCU enabled.
[ 0.100648] Rude variant of Tasks RCU enabled.
[ 0.100649] Tracing variant of Tasks RCU enabled.
[ 0.100650] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.100651] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.108122] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.108680] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.108754] Console: colour dummy device 80x25
[ 0.108776] printk: console [tty0] enabled
[ 0.108824] ACPI: Core revision 20210730
[ 0.109264] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[ 0.109386] APIC: Switch to symmetric I/O mode setup
[ 0.109389] DMAR: Host address width 39
[ 0.109391] DMAR: DRHD base: 0x000000fed64000 flags: 0x0
[ 0.109398] DMAR: dmar0: reg_base_addr fed64000 ver 1:0 cap 1c0000c40660462 ecap 9e2ff0505e
[ 0.109402] DMAR: DRHD base: 0x000000fed65000 flags: 0x1
[ 0.109409] DMAR: dmar1: reg_base_addr fed65000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.109412] DMAR: RMRR base: 0x000000799c9000 end: 0x000000799e8fff
[ 0.109415] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[ 0.109418] DMAR-IR: IOAPIC id 1 under DRHD base 0xfed65000 IOMMU 1
[ 0.109420] DMAR-IR: HPET id 0 under DRHD base 0xfed65000
[ 0.109422] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.111469] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.111472] x2apic enabled
[ 0.111512] Switched APIC routing to cluster x2apic.
[ 0.116145] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.132671] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0xfc66f4fc7c, max_idle_ns: 440795224246 ns
[ 0.132682] Calibrating delay loop (skipped), value calculated using timer frequency.. 2189.00 BogoMIPS (lpj=3648000)
[ 0.132687] pid_max: default: 32768 minimum: 301
[ 0.138115] LSM: Security Framework initializing
[ 0.138126] landlock: Up and running.
[ 0.138127] Yama: becoming mindful.
[ 0.138184] AppArmor: AppArmor initialized
[ 0.138323] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.138338] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.138913] x86/cpu: SGX disabled by BIOS.
[ 0.138927] CPU0: Thermal monitoring enabled (TM1)
[ 0.138929] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.139031] process: using mwait in idle threads
[ 0.139034] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.139036] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.139042] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.139046] Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
[ 0.139047] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.139049] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.139052] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.139054] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.160420] Freeing SMP alternatives memory: 36K
[ 0.160639] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 2606
[ 0.160667] smpboot: CPU0: Intel(R) Celeron(R) N4020 CPU @ 1.10GHz (family: 0x6, model: 0x7a, stepping: 0x8)
[ 0.161071] Performance Events: PEBS fmt3+, Goldmont plus events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.161106] ... version: 4
[ 0.161107] ... bit width: 48
[ 0.161108] ... generic registers: 4
[ 0.161109] ... value mask: 0000ffffffffffff
[ 0.161110] ... max period: 00007fffffffffff
[ 0.161111] ... fixed-purpose events: 3
[ 0.161112] ... event mask: 000000070000000f
[ 0.161235] rcu: Hierarchical SRCU implementation.
[ 0.162123] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.162244] smp: Bringing up secondary CPUs ...
[ 0.162510] x86: Booting SMP configuration:
[ 0.162512] .... node #0, CPUs: #1
[ 0.007417] [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
[ 0.164659] smp: Brought up 1 node, 2 CPUs
[ 0.164659] smpboot: Max logical packages: 2
[ 0.164659] smpboot: Total of 2 processors activated (4379.00 BogoMIPS)
[ 0.164659] devtmpfs: initialized
[ 0.164659] x86/mm: Memory block size: 128MB
[ 0.166118] ACPI: PM: Registering ACPI NVS region [mem 0x79a6f000-0x79acefff] (393216 bytes)
[ 0.166118] ACPI: PM: Registering ACPI NVS region [mem 0x7a973000-0x7a973fff] (4096 bytes)
[ 0.166150] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.166164] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.166294] pinctrl core: initialized pinctrl subsystem
[ 0.166596] PM: RTC time: 08:06:45, date: 2023-02-03
[ 0.167116] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.167349] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.167421] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.167489] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.167507] audit: initializing netlink subsys (disabled)
[ 0.167542] audit: type=2000 audit(1675411605.053:1): state=initialized audit_enabled=0 res=1
[ 0.167542] thermal_sys: Registered thermal governor 'fair_share'
[ 0.167542] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.167542] thermal_sys: Registered thermal governor 'step_wise'
[ 0.167542] thermal_sys: Registered thermal governor 'user_space'
[ 0.167542] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.167542] cpuidle: using governor ladder
[ 0.167542] cpuidle: using governor menu
[ 0.167542] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.167542] ACPI: bus type PCI registered
[ 0.167542] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.167542] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.167542] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.167542] PCI: Using configuration type 1 for base access
[ 0.170024] Kprobes globally optimized
[ 0.170063] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.170063] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.170063] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.172856] ACPI: Added _OSI(Module Device)
[ 0.172858] ACPI: Added _OSI(Processor Device)
[ 0.172859] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.172860] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.172862] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.172863] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.172865] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.195104] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.196205] ACPI: EC: EC started
[ 0.196206] ACPI: EC: interrupt blocked
[ 0.197448] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.197450] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.200263] ACPI: Dynamic OEM Table Load:
[ 0.200274] ACPI: SSDT 0xFFFF944080348E00 000190 (v02 PmRef Cpu0Cst 00003001 INTL 20160930)
[ 0.201632] ACPI: Dynamic OEM Table Load:
[ 0.201640] ACPI: SSDT 0xFFFF944080349600 0001E6 (v02 PmRef ApIst 00003000 INTL 20160930)
[ 0.202685] ACPI: Dynamic OEM Table Load:
[ 0.202693] ACPI: SSDT 0xFFFF944080E0F700 0000C9 (v02 PmRef ApCst 00003000 INTL 20160930)
[ 0.204017] ACPI: Interpreter enabled
[ 0.204058] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.204059] ACPI: Using IOAPIC for interrupt routing
[ 0.204102] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.204690] ACPI: Enabled 6 GPEs in block 00 to 7F
[ 0.210005] ACPI: PM: Power Resource [DRST]
[ 0.210172] ACPI: PM: Power Resource [DRST]
[ 0.210342] ACPI: PM: Power Resource [DRST]
[ 0.210519] ACPI: PM: Power Resource [DRST]
[ 0.210695] ACPI: PM: Power Resource [DRST]
[ 0.210872] ACPI: PM: Power Resource [DRST]
[ 0.211103] ACPI: PM: Power Resource [WRST]
[ 0.217701] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.217711] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.219875] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.221425] PCI host bridge to bus 0000:00
[ 0.221428] pci_bus 0000:00: root bus resource [io 0x0070-0x0077]
[ 0.221430] pci_bus 0000:00: root bus resource [io 0x0000-0x006f window]
[ 0.221433] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7 window]
[ 0.221435] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.221437] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.221439] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.221441] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ 0.221442] pci_bus 0000:00: root bus resource [mem 0x7c000001-0x7fffffff window]
[ 0.221444] pci_bus 0000:00: root bus resource [mem 0x80000000-0xcfffffff window]
[ 0.221446] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff window]
[ 0.221448] pci_bus 0000:00: root bus resource [mem 0xfea00000-0xfeafffff window]
[ 0.221450] pci_bus 0000:00: root bus resource [mem 0xfed00000-0xfed003ff window]
[ 0.221451] pci_bus 0000:00: root bus resource [mem 0xfed01000-0xfed01fff window]
[ 0.221453] pci_bus 0000:00: root bus resource [mem 0xfed03000-0xfed03fff window]
[ 0.221455] pci_bus 0000:00: root bus resource [mem 0xfed06000-0xfed06fff window]
[ 0.221457] pci_bus 0000:00: root bus resource [mem 0xfed08000-0xfed09fff window]
[ 0.221458] pci_bus 0000:00: root bus resource [mem 0xfed80000-0xfedbffff window]
[ 0.221460] pci_bus 0000:00: root bus resource [mem 0xfed1c000-0xfed1cfff window]
[ 0.221462] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xfeefffff window]
[ 0.221464] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.222066] pci 0000:00:00.0: [8086:31f0] type 00 class 0x060000
[ 0.222830] pci 0000:00:00.1: [8086:318c] type 00 class 0x118000
[ 0.222852] pci 0000:00:00.1: reg 0x10: [mem 0x80000000-0x80007fff 64bit]
[ 0.223585] pci 0000:00:00.3: [8086:3190] type 00 class 0x088000
[ 0.223597] pci 0000:00:00.3: reg 0x10: [mem 0xa122c000-0xa122cfff 64bit]
[ 0.224343] pci 0000:00:02.0: [8086:3185] type 00 class 0x030000
[ 0.224352] pci 0000:00:02.0: reg 0x10: [mem 0xa0000000-0xa0ffffff 64bit]
[ 0.224358] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.224363] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.224381] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.224386] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.225377] pci 0000:00:0c.0: [8086:31dc] type 00 class 0x028000
[ 0.225424] pci 0000:00:0c.0: reg 0x10: [mem 0xa1214000-0xa1217fff 64bit]
[ 0.225534] pci 0000:00:0c.0: PME# supported from D0 D3hot D3cold
[ 0.226315] pci 0000:00:0e.0: [8086:3198] type 00 class 0x040300
[ 0.226344] pci 0000:00:0e.0: reg 0x10: [mem 0xa1210000-0xa1213fff 64bit]
[ 0.226381] pci 0000:00:0e.0: reg 0x20: [mem 0xa1000000-0xa10fffff 64bit]
[ 0.226435] pci 0000:00:0e.0: PME# supported from D0 D3hot D3cold
[ 0.229148] pci 0000:00:0f.0: [8086:319a] type 00 class 0x078000
[ 0.229172] pci 0000:00:0f.0: reg 0x10: [mem 0xa122b000-0xa122bfff 64bit]
[ 0.229272] pci 0000:00:0f.0: PME# supported from D3hot
[ 0.230012] pci 0000:00:12.0: [8086:31e3] type 00 class 0x010601
[ 0.230026] pci 0000:00:12.0: reg 0x10: [mem 0xa1218000-0xa1219fff]
[ 0.230035] pci 0000:00:12.0: reg 0x14: [mem 0xa122a000-0xa122a0ff]
[ 0.230044] pci 0000:00:12.0: reg 0x18: [io 0xf090-0xf097]
[ 0.230052] pci 0000:00:12.0: reg 0x1c: [io 0xf080-0xf083]
[ 0.230061] pci 0000:00:12.0: reg 0x20: [io 0xf060-0xf07f]
[ 0.230069] pci 0000:00:12.0: reg 0x24: [mem 0xa1229000-0xa12297ff]
[ 0.230107] pci 0000:00:12.0: PME# supported from D3hot
[ 0.230841] pci 0000:00:13.0: [8086:31d8] type 01 class 0x060400
[ 0.230942] pci 0000:00:13.0: PME# supported from D0 D3hot D3cold
[ 0.231728] pci 0000:00:14.0: [8086:31d7] type 01 class 0x060400
[ 0.231828] pci 0000:00:14.0: PME# supported from D0 D3hot D3cold
[ 0.232577] pci 0000:00:15.0: [8086:31a8] type 00 class 0x0c0330
[ 0.232594] pci 0000:00:15.0: reg 0x10: [mem 0xa1200000-0xa120ffff 64bit]
[ 0.232653] pci 0000:00:15.0: PME# supported from D3hot D3cold
[ 0.233385] pci 0000:00:17.0: [8086:31b4] type 00 class 0x118000
[ 0.233403] pci 0000:00:17.0: reg 0x10: [mem 0xa1228000-0xa1228fff 64bit]
[ 0.233415] pci 0000:00:17.0: reg 0x18: [mem 0xa1227000-0xa1227fff 64bit]
[ 0.234155] pci 0000:00:17.1: [8086:31b6] type 00 class 0x118000
[ 0.234172] pci 0000:00:17.1: reg 0x10: [mem 0xa1226000-0xa1226fff 64bit]
[ 0.234184] pci 0000:00:17.1: reg 0x18: [mem 0xa1225000-0xa1225fff 64bit]
[ 0.234963] pci 0000:00:18.0: [8086:31bc] type 00 class 0x118000
[ 0.234981] pci 0000:00:18.0: reg 0x10: [mem 0xa1224000-0xa1224fff 64bit]
[ 0.234992] pci 0000:00:18.0: reg 0x18: [mem 0xa1223000-0xa1223fff 64bit]
[ 0.235739] pci 0000:00:18.1: [8086:31be] type 00 class 0x118000
[ 0.235756] pci 0000:00:18.1: reg 0x10: [mem 0xa1222000-0xa1222fff 64bit]
[ 0.235767] pci 0000:00:18.1: reg 0x18: [mem 0xa1221000-0xa1221fff 64bit]
[ 0.236516] pci 0000:00:18.2: [8086:31c0] type 00 class 0x118000
[ 0.236533] pci 0000:00:18.2: reg 0x10: [mem 0xfea10000-0xfea10fff 64bit]
[ 0.236545] pci 0000:00:18.2: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 0.237317] pci 0000:00:18.3: [8086:31ee] type 00 class 0x118000
[ 0.237334] pci 0000:00:18.3: reg 0x10: [mem 0xa1220000-0xa1220fff 64bit]
[ 0.237356] pci 0000:00:18.3: reg 0x18: [mem 0xa121f000-0xa121ffff 64bit]
[ 0.238128] pci 0000:00:19.0: [8086:31c2] type 00 class 0x118000
[ 0.238145] pci 0000:00:19.0: reg 0x10: [mem 0xa121e000-0xa121efff 64bit]
[ 0.238167] pci 0000:00:19.0: reg 0x18: [mem 0xa121d000-0xa121dfff 64bit]
[ 0.238907] pci 0000:00:19.1: [8086:31c4] type 00 class 0x118000
[ 0.238934] pci 0000:00:19.1: reg 0x10: [mem 0xa121c000-0xa121cfff 64bit]
[ 0.238957] pci 0000:00:19.1: reg 0x18: [mem 0xa121b000-0xa121bfff 64bit]
[ 0.239761] pci 0000:00:1f.0: [8086:31e8] type 00 class 0x060100
[ 0.240316] pci 0000:00:1f.1: [8086:31d4] type 00 class 0x0c0500
[ 0.240384] pci 0000:00:1f.1: reg 0x10: [mem 0xa121a000-0xa121a0ff 64bit]
[ 0.240452] pci 0000:00:1f.1: reg 0x20: [io 0xf040-0xf05f]
[ 0.241297] pci 0000:01:00.0: [2646:500d] type 00 class 0x010802
[ 0.241318] pci 0000:01:00.0: reg 0x10: [mem 0xa1100000-0xa1103fff 64bit]
[ 0.241366] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256)
[ 0.241372] pci 0000:01:00.0: Max Payload Size set to 128 (was 128, max 128)
[ 0.241489] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:13.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 0.241910] pci 0000:00:13.0: PCI bridge to [bus 01]
[ 0.241916] pci 0000:00:13.0: bridge window [mem 0xa1100000-0xa11fffff]
[ 0.242049] pci 0000:00:14.0: PCI bridge to [bus 02]
[ 0.244214] ACPI: PCI: Interrupt link LNKA configured for IRQ 3
[ 0.244346] ACPI: PCI: Interrupt link LNKB configured for IRQ 4
[ 0.244482] ACPI: PCI: Interrupt link LNKC configured for IRQ 5
[ 0.244612] ACPI: PCI: Interrupt link LNKD configured for IRQ 6
[ 0.244757] ACPI: PCI: Interrupt link LNKE configured for IRQ 7
[ 0.244887] ACPI: PCI: Interrupt link LNKF configured for IRQ 9
[ 0.245017] ACPI: PCI: Interrupt link LNKG configured for IRQ 10
[ 0.245148] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[ 0.250397] ACPI: EC: interrupt unblocked
[ 0.250400] ACPI: EC: event unblocked
[ 0.250427] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.250429] ACPI: EC: GPE=0x25
[ 0.250431] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot ECDT EC initialization complete
[ 0.250434] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.250491] iommu: Default domain type: Translated
[ 0.250492] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.250506] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.250506] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.250506] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.250506] vgaarb: loaded
[ 0.250506] SCSI subsystem initialized
[ 0.250506] libata version 3.00 loaded.
[ 0.250506] ACPI: bus type USB registered
[ 0.250506] usbcore: registered new interface driver usbfs
[ 0.250506] usbcore: registered new interface driver hub
[ 0.250506] usbcore: registered new device driver usb
[ 0.250506] pps_core: LinuxPPS API ver. 1 registered
[ 0.250506] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.250506] PTP clock support registered
[ 0.250506] EDAC MC: Ver: 3.0.0
[ 0.250506] Registered efivars operations
[ 0.250506] NetLabel: Initializing
[ 0.250506] NetLabel: domain hash size = 128
[ 0.250506] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.250506] NetLabel: unlabeled traffic allowed by default
[ 0.250506] PCI: Using ACPI for IRQ routing
[ 0.281119] PCI: pci_cache_line_size set to 64 bytes
[ 0.281870] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.281900] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.281901] e820: reserve RAM buffer [mem 0x72e42000-0x73ffffff]
[ 0.281903] e820: reserve RAM buffer [mem 0x73554000-0x73ffffff]
[ 0.281905] e820: reserve RAM buffer [mem 0x7605a000-0x77ffffff]
[ 0.281906] e820: reserve RAM buffer [mem 0x7a973000-0x7bffffff]
[ 0.281908] e820: reserve RAM buffer [mem 0x7aa41000-0x7bffffff]
[ 0.281909] e820: reserve RAM buffer [mem 0x7b000000-0x7bffffff]
[ 0.284598] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.284613] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
[ 0.287184] clocksource: Switched to clocksource tsc-early
[ 0.309725] VFS: Disk quotas dquot_6.6.0
[ 0.309769] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.309984] AppArmor: AppArmor Filesystem Enabled
[ 0.310051] pnp: PnP ACPI init
[ 0.310280] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.310285] system 00:00: [io 0x0400-0x047f] could not be reserved
[ 0.310287] system 00:00: [io 0x0500-0x05fe] has been reserved
[ 0.310289] system 00:00: [io 0x0600-0x061f] has been reserved
[ 0.310291] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.310822] system 00:02: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.310825] system 00:02: [mem 0xfea00000-0xfeafffff] could not be reserved
[ 0.310829] system 00:02: [mem 0xfed01000-0xfed01fff] has been reserved
[ 0.310832] system 00:02: [mem 0xfed03000-0xfed03fff] has been reserved
[ 0.310835] system 00:02: [mem 0xfed06000-0xfed06fff] has been reserved
[ 0.310838] system 00:02: [mem 0xfed08000-0xfed09fff] has been reserved
[ 0.310841] system 00:02: [mem 0xfed80000-0xfedbffff] has been reserved
[ 0.310844] system 00:02: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 0.310846] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.311733] pnp: PnP ACPI: found 4 devices
[ 0.318291] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.318428] NET: Registered PF_INET protocol family
[ 0.318569] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.319644] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.319715] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.319758] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.319894] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.319963] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.320074] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.320113] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.320134] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.320239] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.320246] NET: Registered PF_XDP protocol family
[ 0.320276] pci 0000:00:18.2: BAR 2: assigned [mem 0x80008000-0x80008fff 64bit]
[ 0.320304] pci 0000:00:13.0: PCI bridge to [bus 01]
[ 0.320335] pci 0000:00:13.0: bridge window [mem 0xa1100000-0xa11fffff]
[ 0.320372] pci 0000:00:14.0: PCI bridge to [bus 02]
[ 0.320406] pci_bus 0000:00: resource 4 [io 0x0070-0x0077]
[ 0.320408] pci_bus 0000:00: resource 5 [io 0x0000-0x006f window]
[ 0.320410] pci_bus 0000:00: resource 6 [io 0x0078-0x0cf7 window]
[ 0.320412] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.320414] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.320416] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.320418] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[ 0.320420] pci_bus 0000:00: resource 11 [mem 0x7c000001-0x7fffffff window]
[ 0.320422] pci_bus 0000:00: resource 12 [mem 0x80000000-0xcfffffff window]
[ 0.320424] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xefffffff window]
[ 0.320425] pci_bus 0000:00: resource 14 [mem 0xfea00000-0xfeafffff window]
[ 0.320427] pci_bus 0000:00: resource 15 [mem 0xfed00000-0xfed003ff window]
[ 0.320429] pci_bus 0000:00: resource 16 [mem 0xfed01000-0xfed01fff window]
[ 0.320431] pci_bus 0000:00: resource 17 [mem 0xfed03000-0xfed03fff window]
[ 0.320433] pci_bus 0000:00: resource 18 [mem 0xfed06000-0xfed06fff window]
[ 0.320435] pci_bus 0000:00: resource 19 [mem 0xfed08000-0xfed09fff window]
[ 0.320436] pci_bus 0000:00: resource 20 [mem 0xfed80000-0xfedbffff window]
[ 0.320438] pci_bus 0000:00: resource 21 [mem 0xfed1c000-0xfed1cfff window]
[ 0.320440] pci_bus 0000:00: resource 22 [mem 0xfee00000-0xfeefffff window]
[ 0.320443] pci_bus 0000:01: resource 1 [mem 0xa1100000-0xa11fffff]
[ 0.321341] PCI: CLS 64 bytes, default 64
[ 0.321404] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.321405] software IO TLB: mapped [mem 0x000000006bcf7000-0x000000006fcf7000] (64MB)
[ 0.321407] Trying to unpack rootfs image as initramfs...
[ 0.321495] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0xfc66f4fc7c, max_idle_ns: 440795224246 ns
[ 0.321518] clocksource: Switched to clocksource tsc
[ 0.326732] Initialise system trusted keyrings
[ 0.326769] Key type blacklist registered
[ 0.326852] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.329007] zbud: loaded
[ 0.337730] Key type asymmetric registered
[ 0.337735] Asymmetric key parser 'x509' registered
[ 0.337778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.337839] io scheduler mq-deadline registered
[ 0.337841] io scheduler kyber registered
[ 0.337915] io scheduler bfq registered
[ 0.338528] pcieport 0000:00:13.0: PME: Signaling with IRQ 122
[ 0.338978] pcieport 0000:00:14.0: PME: Signaling with IRQ 123
[ 0.339139] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.339625] ACPI: AC: AC Adapter [AC0] (off-line)
[ 0.339696] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:01/PNP0C0C:00/input/input0
[ 0.339718] ACPI: button: Power Button [PWRB]
[ 0.339756] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:01/PNP0C0D:01/input/input1
[ 0.339781] ACPI: button: Lid Switch [LID]
[ 0.339824] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:01/input/input2
[ 0.339848] ACPI: button: Power Button [PWRB]
[ 0.342439] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.342442] ACPI: thermal: Thermal Zone [THRM] (35 C)
[ 0.342648] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.345747] Non-volatile memory driver v1.3
[ 0.345749] Linux agpgart interface v0.103
[ 0.345751] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.347928] ACPI: battery: Slot [BAT0] (battery present)
[ 0.353159] nvme nvme0: pci function 0000:01:00.0
[ 0.353207] ahci 0000:00:12.0: version 3.0
[ 0.353459] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.353463] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst
[ 0.354816] scsi host0: ahci
[ 0.354927] ata1: SATA max UDMA/133 abar m2048@0xa1229000 port 0xa1229100 irq 124
[ 0.354992] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.355000] ehci-pci: EHCI PCI platform driver
[ 0.355012] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.355023] ohci-pci: OHCI PCI platform driver
[ 0.355038] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.355100] usbcore: registered new interface driver usbserial_generic
[ 0.355106] usbserial: USB Serial support registered for generic
[ 0.355218] rtc_cmos 00:03: RTC can wake from S4
[ 0.355966] rtc_cmos 00:03: registered as rtc0
[ 0.356117] rtc_cmos 00:03: setting system clock to 2023-02-03T08:06:45 UTC (1675411605)
[ 0.356158] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[ 0.356281] intel_pstate: Intel P-state driver initializing
[ 0.356549] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.357009] efifb: probing for efifb
[ 0.357049] efifb: showing boot graphics
[ 0.358656] efifb: framebuffer at 0x90000000, using 4160k, total 4160k
[ 0.358659] efifb: mode is 1366x768x32, linelength=5504, pages=1
[ 0.358660] efifb: scrolling: redraw
[ 0.358661] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.358709] fbcon: Deferring console take-over
[ 0.358710] fb0: EFI VGA frame buffer device
[ 0.358750] hid: raw HID events driver (C) Jiri Kosina
[ 0.358864] ashmem: initialized
[ 0.359132] drop_monitor: Initializing network drop monitor service
[ 0.359210] Initializing XFRM netlink socket
[ 0.359428] NET: Registered PF_INET6 protocol family
[ 0.362529] nvme nvme0: missing or invalid SUBNQN field.
[ 0.394019] nvme nvme0: 4/0/0 default/read/poll queues
[ 0.396733] nvme0n1: p1 p2 p3
[ 0.563301] Freeing initrd memory: 20060K
[ 0.571428] Segment Routing with IPv6
[ 0.571433] RPL Segment Routing with IPv6
[ 0.571478] In-situ OAM (IOAM) with IPv6
[ 0.571513] NET: Registered PF_PACKET protocol family
[ 0.571915] microcode: sig=0x706a8, pf=0x1, revision=0x20
[ 0.571924] microcode: Microcode Update Driver: v2.2.
[ 0.571957] resctrl: L2 allocation detected
[ 0.571964] IPI shorthand broadcast: enabled
[ 0.571992] sched_clock: Marking stable (567854800, 4084633)->(575250178, -3310745)
[ 0.572203] registered taskstats version 1
[ 0.572332] Loading compiled-in X.509 certificates
[ 0.577043] Loaded X.509 cert 'Build time autogenerated kernel key: a04985617783cb2b7525c9d3b54d13d065c7b159'
[ 0.577959] zswap: loaded using pool zstd/z3fold
[ 0.578314] Key type .fscrypt registered
[ 0.578317] Key type fscrypt-provisioning registered
[ 0.578413] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.578846] PM: Magic number: 11:111:118
[ 0.579192] RAS: Correctable Errors collector initialized.
[ 0.672826] ata1: SATA link down (SStatus 4 SControl 300)
[ 0.675506] Freeing unused decrypted memory: 2036K
[ 0.676164] Freeing unused kernel image (initmem) memory: 2016K
[ 0.676174] Write protecting the kernel read-only data: 30720k
[ 0.677920] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.679132] Freeing unused kernel image (rodata/data gap) memory: 1352K
[ 0.725510] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.725518] rodata_test: all tests were successful
[ 0.725532] Run /init as init process
[ 0.725534] with arguments:
[ 0.725537] /init
[ 0.725539] splash
[ 0.725541] with environment:
[ 0.725543] HOME=/
[ 0.725545] TERM=linux
[ 0.725546] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 1.148279] xhci_hcd 0000:00:15.0: xHCI Host Controller
[ 1.148292] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 1
[ 1.149416] xhci_hcd 0000:00:15.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[ 1.149713] xhci_hcd 0000:00:15.0: xHCI Host Controller
[ 1.149725] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 2
[ 1.149729] xhci_hcd 0000:00:15.0: Host supports USB 3.0 SuperSpeed
[ 1.150006] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.150009] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.150012] usb usb1: Product: xHCI Host Controller
[ 1.150013] usb usb1: Manufacturer: Linux 5.15.89-1-MANJARO xhci-hcd
[ 1.150015] usb usb1: SerialNumber: 0000:00:15.0
[ 1.150224] hub 1-0:1.0: USB hub found
[ 1.150294] hub 1-0:1.0: 9 ports detected
[ 1.151629] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.151632] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.151634] usb usb2: Product: xHCI Host Controller
[ 1.151636] usb usb2: Manufacturer: Linux 5.15.89-1-MANJARO xhci-hcd
[ 1.151638] usb usb2: SerialNumber: 0000:00:15.0
[ 1.151876] hub 2-0:1.0: USB hub found
[ 1.151894] hub 2-0:1.0: 7 ports detected
[ 1.152132] usb: port power management may be unreliable
[ 1.155078] i8042: PNP: PS/2 Controller [PNP030b:PS2K] at 0x60,0x64 irq 1
[ 1.155082] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.156990] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.180617] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.275382] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.402695] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[ 1.433942] systemd[1]: systemd 252.4-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.433952] systemd[1]: Detected architecture x86-64.
[ 1.435367] systemd[1]: Hostname set to <mykhailo-vivobookasuslaptope410mabe410ma>.
[ 1.496711] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[ 1.550047] usb 1-1: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[ 1.550056] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.550058] usb 1-1: Product: USB Optical Mouse
[ 1.550060] usb 1-1: Manufacturer: Logitech
[ 1.672711] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 1.814349] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.815954] systemd[1]: Created slice Slice /system/getty.
[ 1.816465] systemd[1]: Created slice Slice /system/modprobe.
[ 1.816906] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.817226] systemd[1]: Created slice User and Session Slice.
[ 1.817326] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.817585] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.817650] systemd[1]: Reached target Login Prompts.
[ 1.817679] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 1.817726] systemd[1]: Reached target Remote File Systems.
[ 1.817752] systemd[1]: Reached target Slice Units.
[ 1.817781] systemd[1]: Reached target Mounting snaps.
[ 1.817837] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.817947] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.818220] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.819882] systemd[1]: Listening on Process Core Dump Socket.
[ 1.820081] systemd[1]: Listening on Journal Audit Socket.
[ 1.820239] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.820400] systemd[1]: Listening on Journal Socket.
[ 1.821276] systemd[1]: Listening on udev Control Socket.
[ 1.821430] systemd[1]: Listening on udev Kernel Socket.
[ 1.822622] systemd[1]: Mounting Huge Pages File System...
[ 1.823768] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.824897] systemd[1]: Mounting Kernel Debug File System...
[ 1.826137] systemd[1]: Mounting Kernel Trace File System...
[ 1.827686] systemd[1]: Starting Load AppArmor profiles...
[ 1.829102] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.830411] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.832120] systemd[1]: Starting Load Kernel Module configfs...
[ 1.835039] systemd[1]: Starting Load Kernel Module drm...
[ 1.836789] systemd[1]: Starting Load Kernel Module fuse...
[ 1.836957] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 1.837684] usb 1-5: New USB device found, idVendor=322e, idProduct=210d, bcdDevice=11.02
[ 1.837689] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.837691] usb 1-5: Product: USB2.0 HD UVC WebCam
[ 1.837693] usb 1-5: Manufacturer: Sonix Technology Co., Ltd.
[ 1.847709] systemd[1]: Starting Load Kernel Modules...
[ 1.857413] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.857542] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 1.858376] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.858976] systemd[1]: Starting Coldplug All udev Devices...
[ 1.861680] systemd[1]: Mounted Huge Pages File System.
[ 1.866183] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.866495] systemd[1]: Mounted Kernel Debug File System.
[ 1.866785] systemd[1]: Mounted Kernel Trace File System.
[ 1.867269] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.867869] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.868057] systemd[1]: Finished Load Kernel Module configfs.
[ 1.868451] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.868631] systemd[1]: Finished Load Kernel Module drm.
[ 1.872547] systemd[1]: Mounting Kernel Configuration File System...
[ 1.879924] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
[ 1.886399] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 1.892048] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.892082] fuse: init (API version 7.34)
[ 1.892601] systemd[1]: Mounted Kernel Configuration File System.
[ 1.894463] systemd[1]: Activating swap /swapfile...
[ 1.894522] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 1.902938] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 1.909527] Adding 8388604k swap on /swapfile. Priority:-2 extents:59 across:127549436k SSFS
[ 1.910103] systemd[1]: Starting Load/Save Random Seed...
[ 1.914414] systemd[1]: Starting Create System Users...
[ 1.919020] systemd[1]: Starting Setup Virtual Console...
[ 1.920345] systemd[1]: Activated swap /swapfile.
[ 1.938820] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 1.939029] systemd[1]: Finished Load Kernel Module fuse.
[ 1.939994] systemd[1]: Reached target Swaps.
[ 1.949458] systemd[1]: Mounting FUSE Control File System...
[ 1.962712] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[ 1.963315] systemd[1]: Finished Create System Users.
[ 1.963836] systemd[1]: Mounted FUSE Control File System.
[ 1.973106] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.993967] device-mapper: uevent: version 1.0.3
[ 1.994140] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 2.004290] systemd[1]: Finished Setup Virtual Console.
[ 2.042310] systemd[1]: Finished Load Kernel Modules.
[ 2.044200] systemd[1]: Starting Apply Kernel Variables...
[ 2.055616] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.056142] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.056235] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 2.058139] systemd[1]: Starting Journal Service...
[ 2.059619] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.086640] systemd[1]: Finished Apply Kernel Variables.
[ 2.089138] systemd[1]: Starting CLI Netfilter Manager...
[ 2.130160] systemd[1]: Finished CLI Netfilter Manager.
[ 2.130518] audit: type=1130 audit(1675411607.270:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.217072] audit: type=1400 audit(1675411607.356:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=235 comm="apparmor_parser"
[ 2.252612] audit: type=1400 audit(1675411607.390:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=234 comm="apparmor_parser"
[ 2.261631] systemd[1]: Finished Coldplug All udev Devices.
[ 2.261702] audit: type=1130 audit(1675411607.400:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.271417] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 2.271533] audit: type=1130 audit(1675411607.410:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.273073] systemd[1]: Starting Show Plymouth Boot Screen...
[ 2.277018] systemd[1]: Started Journal Service.
[ 2.278602] audit: type=1130 audit(1675411607.416:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.286412] systemd-journald[246]: Received client request to flush runtime journal.
[ 2.293372] audit: type=1130 audit(1675411607.433:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.397647] audit: type=1130 audit(1675411607.536:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.439198] audit: type=1400 audit(1675411607.550:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=253 comm="apparmor_parser"
[ 2.957059] loop1: detected capacity change from 0 to 20008
[ 2.979281] loop0: detected capacity change from 0 to 20008
[ 3.051592] loop2: detected capacity change from 0 to 102048
[ 3.077987] loop3: detected capacity change from 0 to 101624
[ 3.093667] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.101390] usb 1-7: New USB device found, idVendor=0b05, idProduct=6200, bcdDevice= 2.08
[ 3.101399] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.101402] usb 1-7: Product: C-Media(R) Audio
[ 3.101404] usb 1-7: Manufacturer: ASUSTeK COMPUTER INC.
[ 3.181246] loop: module loaded
[ 3.181742] loop4: detected capacity change from 0 to 113888
[ 3.183964] loop5: detected capacity change from 0 to 113888
[ 3.242702] usb 1-9: new full-speed USB device number 5 using xhci_hcd
[ 3.376027] random: crng init done
[ 3.383793] usb 1-9: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.383809] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.890116] mc: Linux media interface: v0.10
[ 4.213441] videodev: Linux video capture interface: v2.00
[ 4.216387] i801_smbus 0000:00:1f.1: SPD Write Disable is set
[ 4.216459] i801_smbus 0000:00:1f.1: SMBus using PCI interrupt
[ 4.233301] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 4.246270] i2c i2c-0: 1/2 memory slots populated (from DMI)
[ 4.312190] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 4.356627] idma64 idma64.2: Found Intel integrated DMA 64-bit
[ 4.357147] idma64 idma64.3: Found Intel integrated DMA 64-bit
[ 4.367232] idma64 idma64.6: Found Intel integrated DMA 64-bit
[ 4.369053] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 4.370078] idma64 idma64.7: Found Intel integrated DMA 64-bit
[ 4.420403] input: ASUE1409:00 04F3:3157 Mouse as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input5
[ 4.420489] input: ASUE1409:00 04F3:3157 Touchpad as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input6
[ 4.420543] input: ASUE1409:00 04F3:3157 Keyboard as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input7
[ 4.420686] hid-generic 0018:04F3:3157.0001: input,hidraw0: I2C HID v1.00 Mouse [ASUE1409:00 04F3:3157] on i2c-ASUE1409:00
[ 4.596843] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 4.596850] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 4.596851] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 4.596853] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 4.596854] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 4.707593] cryptd: max_cpu_qlen set to 1000
[ 4.761371] SSE version of gcm_enc/dec engaged.
[ 4.804665] intel_rapl_common: Found RAPL domain package
[ 4.804673] intel_rapl_common: Found RAPL domain core
[ 4.804675] intel_rapl_common: Found RAPL domain uncore
[ 4.804678] intel_rapl_common: Found RAPL domain dram
[ 4.930611] dw-apb-uart.2: ttyS4 at MMIO 0xa1224000 (irq = 4, base_baud = 115200) is a 16550A
[ 4.996343] dw-apb-uart.3: ttyS5 at MMIO 0xa1222000 (irq = 5, base_baud = 115200) is a 16550A
[ 5.016372] dw-apb-uart.4: ttyS6 at MMIO 0xfea10000 (irq = 6, base_baud = 115200) is a 16550A
[ 5.036315] dw-apb-uart.5: ttyS7 at MMIO 0xa1220000 (irq = 7, base_baud = 115200) is a 16550A
[ 5.134633] usb 1-5: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:210d)
[ 5.152653] asus_wmi: ASUS WMI generic driver loaded
[ 5.169897] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:15.0/usb1/1-5/1-5:1.0/input/input8
[ 5.201557] asus_wmi: Initialization: 0x1
[ 5.201647] asus_wmi: BIOS WMI version: 9.0
[ 5.201706] asus_wmi: SFUN value: 0x21
[ 5.201711] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 5.201713] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 5.223960] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input9
[ 5.225761] kauditd_printk_skb: 130 callbacks suppressed
[ 5.225764] audit: type=1400 audit(1675411610.363:61): apparmor="STATUS" operation="profile_load" profile="unconfined" name="apache2" pid=366 comm="apparmor_parser"
[ 5.225966] audit: type=1300 audit(1675411610.363:61): arch=c000003e syscall=1 success=yes exit=4801 a0=6 a1=5599c355e8d0 a2=12c1 a3=0 items=0 ppid=231 pid=366 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.226318] audit: type=1327 audit(1675411610.363:61): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.226739] audit: type=1400 audit(1675411610.366:62): apparmor="STATUS" operation="profile_load" profile="unconfined" name="apache2//DEFAULT_URI" pid=366 comm="apparmor_parser"
[ 5.226837] audit: type=1300 audit(1675411610.366:62): arch=c000003e syscall=1 success=yes exit=3657 a0=6 a1=5599c34aa570 a2=e49 a3=0 items=0 ppid=231 pid=366 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.226939] audit: type=1327 audit(1675411610.366:62): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.227273] audit: type=1400 audit(1675411610.366:63): apparmor="STATUS" operation="profile_load" profile="unconfined" name="apache2//HANDLING_UNTRUSTED_INPUT" pid=366 comm="apparmor_parser"
[ 5.227637] audit: type=1300 audit(1675411610.366:63): arch=c000003e syscall=1 success=yes exit=3161 a0=6 a1=5599c3559320 a2=c59 a3=0 items=0 ppid=231 pid=366 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.227741] audit: type=1327 audit(1675411610.366:63): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.241468] audit: type=1400 audit(1675411610.366:64): apparmor="STATUS" operation="profile_load" profile="unconfined" name="apache2//phpsysinfo" pid=366 comm="apparmor_parser"
[ 5.249958] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.266768] usbcore: registered new interface driver uvcvideo
[ 5.288477] input: ASUE1409:00 04F3:3157 Mouse as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input10
[ 5.288580] input: ASUE1409:00 04F3:3157 Touchpad as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input11
[ 5.288707] input: ASUE1409:00 04F3:3157 Keyboard as /devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-2/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input12
[ 5.288898] hid-multitouch 0018:04F3:3157.0001: input,hidraw0: I2C HID v1.00 Mouse [ASUE1409:00 04F3:3157] on i2c-ASUE1409:00
[ 5.319640] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.494941] Bluetooth: Core ver 2.22
[ 5.495163] NET: Registered PF_BLUETOOTH protocol family
[ 5.495166] Bluetooth: HCI device and connection manager initialized
[ 5.495172] Bluetooth: HCI socket layer initialized
[ 5.495175] Bluetooth: L2CAP socket layer initialized
[ 5.495183] Bluetooth: SCO socket layer initialized
[ 5.514231] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.0/0003:046D:C077.0002/input/input13
[ 5.515787] hid-generic 0003:046D:C077.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:15.0-1/input0
[ 5.522437] input: ASUSTeK COMPUTER INC. C-Media(R) Audio as /devices/pci0000:00/0000:00:15.0/usb1/1-7/1-7:1.3/0003:0B05:6200.0003/input/input14
[ 5.526049] mousedev: PS/2 mouse device common for all mice
[ 5.558540] ACPI: battery: new extension: ASUS Battery Extension
[ 5.576362] hid-generic 0003:0B05:6200.0003: input,hidraw2: USB HID v1.11 Device [ASUSTeK COMPUTER INC. C-Media(R) Audio] on usb-0000:00:15.0-7/input3
[ 5.576550] usbcore: registered new interface driver usbhid
[ 5.576553] usbhid: USB HID core driver
[ 5.786203] usbcore: registered new interface driver btusb
[ 5.793243] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[ 5.794239] Bluetooth: hci0: Device revision is 2
[ 5.794241] Bluetooth: hci0: Secure boot is enabled
[ 5.794243] Bluetooth: hci0: OTP lock is enabled
[ 5.794244] Bluetooth: hci0: API lock is enabled
[ 5.794245] Bluetooth: hci0: Debug lock is disabled
[ 5.794246] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.795886] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 5.914995] Intel(R) Wireless WiFi driver for Linux
[ 5.915067] iwlwifi 0000:00:0c.0: enabling device (0000 -> 0002)
[ 6.017021] intel_telemetry_core Init
[ 6.067667] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[ 6.091406] iwlwifi 0000:00:0c.0: WRT: Overriding region id 0
[ 6.091414] iwlwifi 0000:00:0c.0: WRT: Overriding region id 1
[ 6.091417] iwlwifi 0000:00:0c.0: WRT: Overriding region id 2
[ 6.091419] iwlwifi 0000:00:0c.0: WRT: Overriding region id 3
[ 6.091420] iwlwifi 0000:00:0c.0: WRT: Overriding region id 4
[ 6.091422] iwlwifi 0000:00:0c.0: WRT: Overriding region id 6
[ 6.091424] iwlwifi 0000:00:0c.0: WRT: Overriding region id 8
[ 6.091425] iwlwifi 0000:00:0c.0: WRT: Overriding region id 9
[ 6.091427] iwlwifi 0000:00:0c.0: WRT: Overriding region id 10
[ 6.091429] iwlwifi 0000:00:0c.0: WRT: Overriding region id 11
[ 6.091430] iwlwifi 0000:00:0c.0: WRT: Overriding region id 15
[ 6.091432] iwlwifi 0000:00:0c.0: WRT: Overriding region id 16
[ 6.091433] iwlwifi 0000:00:0c.0: WRT: Overriding region id 18
[ 6.091435] iwlwifi 0000:00:0c.0: WRT: Overriding region id 19
[ 6.091437] iwlwifi 0000:00:0c.0: WRT: Overriding region id 20
[ 6.091438] iwlwifi 0000:00:0c.0: WRT: Overriding region id 21
[ 6.091440] iwlwifi 0000:00:0c.0: WRT: Overriding region id 28
[ 6.091988] iwlwifi 0000:00:0c.0: loaded firmware version 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 6.148468] usbcore: registered new interface driver snd-usb-audio
[ 6.349430] iwlwifi 0000:00:0c.0: Detected Intel(R) Wireless-AC 9461, REV=0x318
[ 6.356147] thermal thermal_zone7: failed to read out thermal zone (-61)
[ 6.379546] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[ 6.404803] iwlwifi 0000:00:0c.0: base HW address: c8:cb:9e:14:37:32
[ 6.448561] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 6.555409] iwlwifi 0000:00:0c.0 wlo1: renamed from wlan0
[ 6.703775] i915 0000:00:02.0: [drm] Unknown revid 0x06
[ 6.706867] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 6.707054] i915 0000:00:02.0: [drm] couldn't get memory information
[ 6.730248] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 6.731277] mei_hdcp 0000:00:0f.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 6.734360] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
[ 6.765389] loop6: detected capacity change from 0 to 8
[ 6.787091] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 6.789469] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 6.792740] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15
[ 6.792897] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.873554] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.873561] Bluetooth: BNEP filters: protocol multicast
[ 6.873568] Bluetooth: BNEP socket layer initialized
[ 7.080891] fbcon: i915drmfb (fb0) is primary device
[ 7.080896] fbcon: Deferring console take-over
[ 7.080902] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 7.106915] NET: Registered PF_QIPCRTR protocol family
[ 7.166634] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input16
[ 7.166720] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input17
[ 7.166788] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input18
[ 7.166850] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input19
[ 7.166907] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input20
[ 7.201030] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.201221] Bluetooth: hci0: Firmware loaded in 1372394 usecs
[ 7.201261] Bluetooth: hci0: Waiting for device to boot
[ 7.215243] Bluetooth: hci0: Device booted in 13673 usecs
[ 7.215462] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[ 7.217234] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 7.220241] Bluetooth: hci0: Firmware revision 0.1 build 108 week 45 2022
[ 7.220594] iwlwifi 0000:00:0c.0: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 7.303048] NET: Registered PF_ALG protocol family
[ 7.404530] iwlwifi 0000:00:0c.0: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 10.924393] wlo1: authenticate with 16:41:89:c7:21:e0
[ 10.935319] wlo1: send auth to 16:41:89:c7:21:e0 (try 1/3)
[ 11.035664] wlo1: authenticate with 16:41:89:c7:21:e0
[ 11.035673] wlo1: send auth to 16:41:89:c7:21:e0 (try 1/3)
[ 11.050964] wlo1: authenticated
[ 11.052755] wlo1: associate with 16:41:89:c7:21:e0 (try 1/3)
[ 11.054730] wlo1: RX AssocResp from 16:41:89:c7:21:e0 (capab=0x11 status=0 aid=1)
[ 11.057957] wlo1: associated
[ 11.169687] wlo1: Limiting TX power to 0 (-128 - 0) dBm as advertised by 16:41:89:c7:21:e0
[ 11.213585] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 11.250064] kauditd_printk_skb: 93 callbacks suppressed
[ 11.250069] audit: type=1334 audit(1675411616.390:114): prog-id=31 op=LOAD
[ 11.250076] audit: type=1300 audit(1675411616.390:114): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffc75199690 a2=90 a3=9e items=0 ppid=1 pid=470 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj=unconfined key=(null)
[ 11.250080] audit: type=1327 audit(1675411616.390:114): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 11.346731] audit: type=1334 audit(1675411616.486:115): prog-id=32 op=LOAD
[ 11.411819] audit: type=1130 audit(1675411616.550:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.432529] audit: type=1100 audit(1675411616.570:117): pid=616 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 11.433358] audit: type=1101 audit(1675411616.573:118): pid=616 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 11.435534] audit: type=1103 audit(1675411616.573:119): pid=616 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 11.436532] audit: type=1006 audit(1675411616.576:120): pid=616 uid=0 subj=unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=1 res=1
[ 11.436537] audit: type=1300 audit(1675411616.576:120): arch=c000003e syscall=1 success=yes exit=3 a0=8 a1=7ffcda5456d0 a2=3 a3=7ffcda5453e5 items=0 ppid=565 pid=616 auid=120 uid=0 gid=120 euid=0 suid=0 fsuid=0 egid=120 sgid=120 fsgid=120 tty=(none) ses=1 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj=unconfined key=(null)
[ 15.104399] rfkill: input handler disabled
[ 16.724274] kauditd_printk_skb: 48 callbacks suppressed
[ 16.724279] audit: type=1130 audit(1675411621.863:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-quit-wait comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.042819] audit: type=1131 audit(1675411622.183:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.456345] audit: type=1100 audit(1675411625.596:156): pid=984 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="mykhailoh" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 20.458383] audit: type=1101 audit(1675411625.596:157): pid=984 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="mykhailoh" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 20.459827] audit: type=1103 audit(1675411625.600:158): pid=984 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="mykhailoh" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 20.461089] audit: type=1006 audit(1675411625.600:159): pid=984 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 20.461100] audit: type=1300 audit(1675411625.600:159): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7ffe5a12eb50 a2=4 a3=7ffe5a12e864 items=0 ppid=565 pid=984 auid=1000 uid=0 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj=unconfined key=(null)
[ 20.461109] audit: type=1327 audit(1675411625.600:159): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D70617373776F72645D
[ 20.495195] audit: type=1130 audit(1675411625.633:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.509203] audit: type=1101 audit(1675411625.646:161): pid=998 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="mykhailoh" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.111054] rfkill: input handler enabled
[ 23.644309] kauditd_printk_skb: 31 callbacks suppressed
[ 23.644314] audit: type=1130 audit(1675411628.783:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.898560] Bluetooth: RFCOMM TTY layer initialized
[ 23.898574] Bluetooth: RFCOMM socket layer initialized
[ 23.898585] Bluetooth: RFCOMM ver 1.11
[ 24.553429] rfkill: input handler disabled
[ 28.440060] audit: type=1106 audit(1675411633.580:180): pid=616 uid=0 auid=120 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 28.440377] audit: type=1104 audit(1675411633.580:181): pid=616 uid=0 auid=120 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=mykhailo-vivobookasuslaptope410mabe410ma addr=? terminal=/dev/tty1 res=success'
[ 37.788278] audit: type=1131 audit(1675411642.988:182): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.797368] audit: type=1334 audit(1675411643.002:183): prog-id=0 op=UNLOAD
[ 37.797378] audit: type=1334 audit(1675411643.002:184): prog-id=0 op=UNLOAD
[ 37.797382] audit: type=1334 audit(1675411643.002:185): prog-id=0 op=UNLOAD
[ 38.751705] audit: type=1131 audit(1675411643.977:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.773614] audit: type=1131 audit(1675411644.001:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.834357] audit: type=1131 audit(1675411651.175:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.847004] audit: type=1334 audit(1675411651.189:189): prog-id=0 op=UNLOAD
[ 57.748375] audit: type=1131 audit(1675411663.145:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.765049] audit: type=1131 audit(1675411663.162:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.790820] audit: type=1334 audit(1675411663.188:192): prog-id=0 op=UNLOAD
[ 57.790829] audit: type=1334 audit(1675411663.188:193): prog-id=0 op=UNLOAD
[ 57.790832] audit: type=1334 audit(1675411663.188:194): prog-id=0 op=UNLOAD
[ 57.843975] audit: type=1334 audit(1675411663.242:195): prog-id=0 op=UNLOAD
[ 57.843985] audit: type=1334 audit(1675411663.242:196): prog-id=0 op=UNLOAD
[ 57.843988] audit: type=1334 audit(1675411663.242:197): prog-id=0 op=UNLOAD
[ 74.753771] audit: type=1131 audit(1675411680.165:198): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 221.713458] audit: type=1334 audit(1675411827.142:199): prog-id=51 op=LOAD
[ 221.836651] audit: type=1130 audit(1675411827.266:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 225.649325] audit: type=1100 audit(1675411831.076:201): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="mykhailoh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 225.658915] audit: type=1101 audit(1675411831.086:202): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="mykhailoh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 225.660840] audit: type=1110 audit(1675411831.089:203): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 225.661311] audit: type=1105 audit(1675411831.089:204): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 251.749470] audit: type=1131 audit(1675411857.178:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 251.761469] audit: type=1334 audit(1675411857.191:206): prog-id=0 op=UNLOAD
[ 307.526718] audit: type=1334 audit(1675411912.963:207): prog-id=52 op=LOAD
[ 307.526896] audit: type=1334 audit(1675411912.963:208): prog-id=53 op=LOAD
[ 307.526960] audit: type=1334 audit(1675411912.963:209): prog-id=54 op=LOAD
[ 307.602313] audit: type=1130 audit(1675411913.036:210): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 324.117701] audit: type=1106 audit(1675411929.558:211): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 324.117998] audit: type=1104 audit(1675411929.558:212): pid=2733 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 337.628808] audit: type=1131 audit(1675411943.070:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 337.632933] audit: type=1334 audit(1675411943.073:214): prog-id=0 op=UNLOAD
[ 337.632942] audit: type=1334 audit(1675411943.073:215): prog-id=0 op=UNLOAD
[ 337.632945] audit: type=1334 audit(1675411943.073:216): prog-id=0 op=UNLOAD
[ 349.533409] audit: type=1101 audit(1675411954.975:217): pid=2835 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="mykhailoh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 349.534596] audit: type=1110 audit(1675411954.978:218): pid=2835 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 349.535021] audit: type=1105 audit(1675411954.978:219): pid=2835 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
journalctl:
Feb 03 07:36:43 mykhailo-vivobookasuslaptope410mabe410ma kernel: x86/cpu: SGX d>
Feb 03 07:36:43 mykhailo-vivobookasuslaptope410mabe410ma kernel: Spectre V2 : W>
Feb 03 07:36:48 mykhailo-vivobookasuslaptope410mabe410ma bluetoothd[491]: src/p>
Feb 03 07:36:48 mykhailo-vivobookasuslaptope410mabe410ma systemd[1]: Failed to >
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ Defined-By: systemd
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 459 and the job result is failed.
Feb 03 07:37:03 mykhailo-vivobookasuslaptope410mabe410ma gdm-password][1025]: g>
Feb 03 07:37:04 mykhailo-vivobookasuslaptope410mabe410ma systemd[1036]: Failed >
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 159 and the job result is failed.
Feb 03 07:37:11 mykhailo-vivobookasuslaptope410mabe410ma gdm-launch-environment>
Feb 03 09:53:08 mykhailo-vivobookasuslaptope410mabe410ma systemd-coredump[15628>
Feb 03 09:53:09 mykhailo-vivobookasuslaptope410mabe410ma systemd-coredump[15793>
lines 3-25/25 (END)
Xorg file doesn’t exist, any Xorg file in mentioned path:
cat /var/log/Xorg.0.log ✔ 1m 37s
cat: /var/log/Xorg.0.log: No such file or directory
Can you check whether there is any log file related to Xorg?
ls -l /var/log/*.log*
Since there appears to be no log file for Xorg you likely never ran an X session.
Gnome uses Wayland by default - and I don’t know how to get to it’s log files or whether there even is one.
But you can start your Gnome session to run in Xorg.
At the login screen, after you choose the username, but before you put in the pasword, there appears a small selector.
I think in the bottom right corner of the screen - not sure and can’t check because I do not run Gnome.
It’s just how I remember it.
Look for that - and change the session type to “Gnome under Xorg” or something to that effect.
Then you should have the log file we where looking for.
It could also be that this will solve your problem without needing further investigation - Xorg might just work better than Wayland on your machine.
Give that a try?
Yeah, sure. I did what you said and changed to Gnome Xorg in log in menu.
And I entered these commands after that, and here what I get:
~ ls -l /var/log/*.log* ✔
-rw------- 1 root root 532050 Feb 3 12:15 /var/log/boot.log
-rw-r--r-- 1 root root 180667 Feb 3 10:42 /var/log/pacman.log
~ cat /var/log/Xorg.0.log ✔
There is still no Xorg file in that directory.
But the problem with the video seems to be fixed. or at least it become better. Thank you for your help.
I case you want to look deeper into it …
If it isn’t in here:
/var/log/
the log file for the Xorg session under GDM/Gnome is probably here:
~/.local/share/xorg/
ls -l ~/.local/share/xorg
When Xorg is running, it should also create another file that could be useful:
ls -l ~/.xsession-errors*
Yeah, that is right, here is Xorg file:
[ 24.391] (--) Log file renamed from "/home/mykhailoh/.local/share/xorg/Xorg.pid-1026.log" to "/home/mykhailoh/.local/share/xorg/Xorg.0.log"
[ 24.393]
X.Org X Server 1.21.1.6
[ 24.393] Current Operating System: Linux mykhailo-vivobookasuslaptope410mabe410ma 5.15.89-1-MANJARO #1 SMP PREEMPT Wed Jan 18 20:37:11 UTC 2023 x86_64
[ 24.393] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a25ce011-0d70-4636-a0df-517c9df7c321 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 24.393]
[ 24.394] Current version of pixman: 0.42.2
[ 24.394] Before reporting problems, check http://wiki.x.org
[ 24.394] Markers: (--) probed, (**) from config file, (==) default setting,
[ 24.394] (==) Log file: "/home/mykhailoh/.local/share/xorg/Xorg.0.log", Time: Fri Feb 3 12:46:14 2023
[ 24.394] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 24.395] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 24.396] (==) No Layout section. Using the first Screen section.
[ 24.397] (==) No screen section available. Using defaults.
[ 24.397] (**) |-->Screen "Default Screen Section" (0)
[ 24.397] (**) | |-->Monitor "<default monitor>"
[ 24.397] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 24.398] (**) | |-->Device "integrated"
[ 24.398] (==) No monitor specified for screen "Default Screen Section".
[ 24.398] (==) Automatically adding devices
[ 24.398] (==) Automatically enabling devices
[ 24.398] (==) Automatically adding GPU devices
[ 24.398] (==) Automatically binding GPU devices
[ 24.398] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 24.398] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 24.398] Entry deleted from font path.
[ 24.398] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 24.398] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 24.398] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 24.398] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 24.398] (==) FontPath set to:
/usr/share/fonts/TTF
[ 24.398] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 24.398] (II) The server relies on udev to provide the list of input devices.
[ 24.398] (II) Module ABI versions:
[ 24.398] X.Org ANSI C Emulation: 0.4
[ 24.398] X.Org Video Driver: 25.2
[ 24.398] X.Org XInput driver : 24.4
[ 24.398] X.Org Server Extension : 10.0
[ 24.401] (++) using VT number 2
[ 24.403] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 24.404] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 24.404] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 24.405] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 24.411] (--) PCI:*(0@0:2:0) 8086:3185:1043:1dc2 rev 6, Mem @ 0xa0000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 24.411] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 24.411] (II) LoadModule: "glx"
[ 24.412] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 24.416] (II) Module glx: vendor="X.Org Foundation"
[ 24.416] compiled for 1.21.1.6, module version = 1.0.0
[ 24.416] ABI class: X.Org Server Extension, version 10.0
[ 24.416] (II) LoadModule: "modesetting"
[ 24.416] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 24.418] (II) Module modesetting: vendor="X.Org Foundation"
[ 24.418] compiled for 1.21.1.6, module version = 1.21.1
[ 24.419] Module class: X.Org Video Driver
[ 24.419] ABI class: X.Org Video Driver, version 25.2
[ 24.419] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 24.419] (II) modeset(0): using drv /dev/dri/card0
[ 24.419] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 24.419] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 24.419] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 24.419] (==) modeset(0): RGB weight 888
[ 24.419] (==) modeset(0): Default visual is TrueColor
[ 24.419] (II) Loading sub module "glamoregl"
[ 24.419] (II) LoadModule: "glamoregl"
[ 24.419] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 24.426] (II) Module glamoregl: vendor="X.Org Foundation"
[ 24.426] compiled for 1.21.1.6, module version = 1.0.1
[ 24.426] ABI class: X.Org ANSI C Emulation, version 0.4
[ 24.474] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 600 (GLK 2)
[ 24.474] (II) modeset(0): glamor initialized
[ 24.474] (==) modeset(0): VariableRefresh: disabled
[ 24.474] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 24.475] (II) modeset(0): Output eDP-1 has no monitor section
[ 24.477] (II) modeset(0): Output HDMI-1 has no monitor section
[ 24.743] (II) modeset(0): Output DP-1 has no monitor section
[ 24.745] (II) modeset(0): EDID for output eDP-1
[ 24.745] (II) modeset(0): Manufacturer: AUO Model: 723c Serial#: 0
[ 24.745] (II) modeset(0): Year: 2020 Week: 52
[ 24.745] (II) modeset(0): EDID Version: 1.4
[ 24.745] (II) modeset(0): Digital Display Input
[ 24.745] (II) modeset(0): 6 bits per channel
[ 24.745] (II) modeset(0): Digital interface is DisplayPort
[ 24.745] (II) modeset(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 24.745] (II) modeset(0): Gamma: 2.20
[ 24.745] (II) modeset(0): No DPMS capabilities specified
[ 24.745] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 24.745] (II) modeset(0): First detailed timing is preferred mode
[ 24.745] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 24.745] (II) modeset(0): redX: 0.562 redY: 0.336 greenX: 0.344 greenY: 0.574
[ 24.745] (II) modeset(0): blueX: 0.163 blueY: 0.126 whiteX: 0.313 whiteY: 0.329
[ 24.745] (II) modeset(0): Manufacturer's mask: 0
[ 24.745] (II) modeset(0): Supported detailed timing:
[ 24.745] (II) modeset(0): clock: 76.3 MHz Image Size: 309 x 173 mm
[ 24.745] (II) modeset(0): h_active: 1366 h_sync: 1404 h_sync_end 1426 h_blank_end 1592 h_border: 0
[ 24.745] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 798 v_border: 0
[ 24.745] (II) modeset(0): Unknown vendor-specific block f
[ 24.745] (II) modeset(0): AUO
[ 24.745] (II) modeset(0): B140XTN07.2
[ 24.745] (II) modeset(0): EDID (in hex):
[ 24.745] (II) modeset(0): 00ffffffffffff0006af3c7200000000
[ 24.745] (II) modeset(0): 341e0104951f117802c0d58f56589329
[ 24.745] (II) modeset(0): 20505400000001010101010101010101
[ 24.745] (II) modeset(0): 010101010101ce1d56e250001e302616
[ 24.745] (II) modeset(0): 360035ad100000180000000f00000000
[ 24.745] (II) modeset(0): 00000000000000000020000000fe0041
[ 24.745] (II) modeset(0): 554f0a202020202020202020000000fe
[ 24.745] (II) modeset(0): 004231343058544e30372e32200a0072
[ 24.745] (II) modeset(0): Printing probed modes for output eDP-1
[ 24.745] (II) modeset(0): Modeline "1366x768"x60.1 76.30 1366 1404 1426 1592 768 771 777 798 -hsync -vsync (47.9 kHz eP)
[ 24.745] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 24.745] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 24.745] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 24.745] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 24.745] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 24.745] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 24.745] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 24.745] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 24.746] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 24.746] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 24.746] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 24.746] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 24.746] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 24.746] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 24.746] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 24.746] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 24.746] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 24.746] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 24.746] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 24.746] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 24.746] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 24.746] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 24.746] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 24.746] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 24.746] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 24.746] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 24.746] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 24.746] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 24.746] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 24.746] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 24.748] (II) modeset(0): EDID for output HDMI-1
[ 25.013] (II) modeset(0): EDID for output DP-1
[ 25.013] (II) modeset(0): Output eDP-1 connected
[ 25.013] (II) modeset(0): Output HDMI-1 disconnected
[ 25.013] (II) modeset(0): Output DP-1 disconnected
[ 25.013] (II) modeset(0): Using exact sizes for initial modes
[ 25.013] (II) modeset(0): Output eDP-1 using initial mode 1366x768 +0+0
[ 25.013] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 25.013] (==) modeset(0): DPI set to (96, 96)
[ 25.013] (II) Loading sub module "fb"
[ 25.013] (II) LoadModule: "fb"
[ 25.013] (II) Module "fb" already built-in
[ 25.040] (==) modeset(0): Backing store enabled
[ 25.040] (==) modeset(0): Silken mouse enabled
[ 25.123] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 25.123] (==) modeset(0): DPMS enabled
[ 25.124] (WW) modeset(0): Option "DRI" is not used
[ 25.124] (II) modeset(0): [DRI2] Setup complete
[ 25.124] (II) modeset(0): [DRI2] DRI driver: iris
[ 25.124] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 25.124] (II) Initializing extension Generic Event Extension
[ 25.124] (II) Initializing extension SHAPE
[ 25.125] (II) Initializing extension MIT-SHM
[ 25.126] (II) Initializing extension XInputExtension
[ 25.126] (II) Initializing extension XTEST
[ 25.127] (II) Initializing extension BIG-REQUESTS
[ 25.127] (II) Initializing extension SYNC
[ 25.128] (II) Initializing extension XKEYBOARD
[ 25.128] (II) Initializing extension XC-MISC
[ 25.129] (II) Initializing extension SECURITY
[ 25.129] (II) Initializing extension XFIXES
[ 25.130] (II) Initializing extension RENDER
[ 25.130] (II) Initializing extension RANDR
[ 25.131] (II) Initializing extension COMPOSITE
[ 25.131] (II) Initializing extension DAMAGE
[ 25.132] (II) Initializing extension MIT-SCREEN-SAVER
[ 25.132] (II) Initializing extension DOUBLE-BUFFER
[ 25.133] (II) Initializing extension RECORD
[ 25.133] (II) Initializing extension DPMS
[ 25.134] (II) Initializing extension Present
[ 25.134] (II) Initializing extension DRI3
[ 25.135] (II) Initializing extension X-Resource
[ 25.135] (II) Initializing extension XVideo
[ 25.136] (II) Initializing extension XVideo-MotionCompensation
[ 25.136] (II) Initializing extension GLX
[ 25.146] (II) AIGLX: Loaded and initialized iris
[ 25.146] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 25.146] (II) Initializing extension XFree86-VidModeExtension
[ 25.146] (II) Initializing extension XFree86-DGA
[ 25.146] (II) Initializing extension XFree86-DRI
[ 25.146] (II) Initializing extension DRI2
[ 25.147] (II) modeset(0): Damage tracking initialized
[ 25.147] (II) modeset(0): Setting screen physical size to 361 x 203
[ 25.232] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 25.232] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 25.232] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 25.232] (**) Video Bus: Applying InputClass "system-keyboard"
[ 25.232] (II) LoadModule: "libinput"
[ 25.233] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 25.236] (II) Module libinput: vendor="X.Org Foundation"
[ 25.236] compiled for 1.21.1.3, module version = 1.2.1
[ 25.236] Module class: X.Org XInput Driver
[ 25.236] ABI class: X.Org XInput driver, version 24.4
[ 25.236] (II) Using input driver 'libinput' for 'Video Bus'
[ 25.237] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 28 paused 0
[ 25.237] (**) Video Bus: always reports core events
[ 25.238] (**) Option "Device" "/dev/input/event12"
[ 25.241] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 25.242] (II) event12 - Video Bus: device is a keyboard
[ 25.242] (II) event12 - Video Bus: device removed
[ 25.242] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15/event12"
[ 25.242] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 25.242] (**) Option "xkb_layout" "us"
[ 25.244] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 25.244] (II) event12 - Video Bus: device is a keyboard
[ 25.245] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 25.245] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.245] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 25.245] (**) Power Button: Applying InputClass "system-keyboard"
[ 25.245] (II) Using input driver 'libinput' for 'Power Button'
[ 25.247] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 31 paused 0
[ 25.247] (**) Power Button: always reports core events
[ 25.247] (**) Option "Device" "/dev/input/event0"
[ 25.249] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 25.249] (II) event0 - Power Button: device is a keyboard
[ 25.250] (II) event0 - Power Button: device removed
[ 25.250] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:01/PNP0C0C:00/input/input0/event0"
[ 25.250] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 25.250] (**) Option "xkb_layout" "us"
[ 25.252] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 25.252] (II) event0 - Power Button: device is a keyboard
[ 25.254] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 25.254] (II) No input driver specified, ignoring this device.
[ 25.254] (II) This device may have been added with another device file.
[ 25.255] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 25.255] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.255] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 25.255] (**) Power Button: Applying InputClass "system-keyboard"
[ 25.255] (II) Using input driver 'libinput' for 'Power Button'
[ 25.257] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 32 paused 0
[ 25.257] (**) Power Button: always reports core events
[ 25.257] (**) Option "Device" "/dev/input/event2"
[ 25.259] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 25.259] (II) event2 - Power Button: device is a keyboard
[ 25.259] (II) event2 - Power Button: device removed
[ 25.259] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:01/input/input2/event2"
[ 25.259] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 25.259] (**) Option "xkb_layout" "us"
[ 25.261] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 25.261] (II) event2 - Power Button: device is a keyboard
[ 25.262] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 25.262] (II) No input driver specified, ignoring this device.
[ 25.262] (II) This device may have been added with another device file.
[ 25.263] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 25.263] (II) No input driver specified, ignoring this device.
[ 25.263] (II) This device may have been added with another device file.
[ 25.263] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 25.264] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 25.264] (II) No input driver specified, ignoring this device.
[ 25.264] (II) This device may have been added with another device file.
[ 25.265] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 25.265] (II) No input driver specified, ignoring this device.
[ 25.265] (II) This device may have been added with another device file.
[ 25.267] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event4)
[ 25.267] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 25.267] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 25.267] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[ 25.268] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 25.268] (**) Logitech USB Optical Mouse: always reports core events
[ 25.269] (**) Option "Device" "/dev/input/event4"
[ 25.271] (II) event4 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 25.271] (II) event4 - Logitech USB Optical Mouse: device is a pointer
[ 25.271] (II) event4 - Logitech USB Optical Mouse: device removed
[ 25.271] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-1/1-1:1.0/0003:046D:C077.0002/input/input7/event4"
[ 25.271] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 9)
[ 25.272] (**) Option "AccelerationScheme" "none"
[ 25.272] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[ 25.272] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 25.272] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 25.275] (II) event4 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 25.276] (II) event4 - Logitech USB Optical Mouse: device is a pointer
[ 25.277] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[ 25.277] (II) No input driver specified, ignoring this device.
[ 25.277] (II) This device may have been added with another device file.
[ 25.279] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event11)
[ 25.279] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "evdev keyboard catchall"
[ 25.279] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "libinput keyboard catchall"
[ 25.279] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "system-keyboard"
[ 25.279] (II) Using input driver 'libinput' for 'USB2.0 HD UVC WebCam: USB2.0 HD'
[ 25.280] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 34 paused 0
[ 25.280] (**) USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events
[ 25.280] (**) Option "Device" "/dev/input/event11"
[ 25.282] (II) event11 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 25.283] (II) event11 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 25.283] (II) event11 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[ 25.283] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-5/1-5:1.0/input/input14/event11"
[ 25.283] (II) XINPUT: Adding extended input device "USB2.0 HD UVC WebCam: USB2.0 HD" (type: KEYBOARD, id 10)
[ 25.283] (**) Option "xkb_layout" "us"
[ 25.286] (II) event11 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 25.286] (II) event11 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 25.288] (II) config/udev: Adding input device ASUSTeK COMPUTER INC. C-Media(R) Audio (/dev/input/event8)
[ 25.288] (**) ASUSTeK COMPUTER INC. C-Media(R) Audio: Applying InputClass "evdev keyboard catchall"
[ 25.288] (**) ASUSTeK COMPUTER INC. C-Media(R) Audio: Applying InputClass "libinput keyboard catchall"
[ 25.288] (**) ASUSTeK COMPUTER INC. C-Media(R) Audio: Applying InputClass "system-keyboard"
[ 25.288] (II) Using input driver 'libinput' for 'ASUSTeK COMPUTER INC. C-Media(R) Audio'
[ 25.289] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 35 paused 0
[ 25.289] (**) ASUSTeK COMPUTER INC. C-Media(R) Audio: always reports core events
[ 25.289] (**) Option "Device" "/dev/input/event8"
[ 25.292] (II) event8 - ASUSTeK COMPUTER INC. C-Media(R) Audio: is tagged by udev as: Keyboard
[ 25.292] (II) event8 - ASUSTeK COMPUTER INC. C-Media(R) Audio: device is a keyboard
[ 25.293] (II) event8 - ASUSTeK COMPUTER INC. C-Media(R) Audio: device removed
[ 25.293] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/usb1/1-7/1-7:1.3/0003:0B05:6200.0003/input/input8/event8"
[ 25.293] (II) XINPUT: Adding extended input device "ASUSTeK COMPUTER INC. C-Media(R) Audio" (type: KEYBOARD, id 11)
[ 25.293] (**) Option "xkb_layout" "us"
[ 25.296] (II) event8 - ASUSTeK COMPUTER INC. C-Media(R) Audio: is tagged by udev as: Keyboard
[ 25.296] (II) event8 - ASUSTeK COMPUTER INC. C-Media(R) Audio: device is a keyboard
[ 25.298] (II) config/udev: Adding input device ASUE1409:00 04F3:3157 Mouse (/dev/input/event5)
[ 25.298] (**) ASUE1409:00 04F3:3157 Mouse: Applying InputClass "evdev pointer catchall"
[ 25.298] (**) ASUE1409:00 04F3:3157 Mouse: Applying InputClass "libinput pointer catchall"
[ 25.298] (II) Using input driver 'libinput' for 'ASUE1409:00 04F3:3157 Mouse'
[ 25.299] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 36 paused 0
[ 25.299] (**) ASUE1409:00 04F3:3157 Mouse: always reports core events
[ 25.299] (**) Option "Device" "/dev/input/event5"
[ 25.301] (II) event5 - ASUE1409:00 04F3:3157 Mouse: is tagged by udev as: Mouse Pointingstick
[ 25.302] (II) event5 - ASUE1409:00 04F3:3157 Mouse: device is a pointer
[ 25.304] (II) event5 - ASUE1409:00 04F3:3157 Mouse: device removed
[ 25.304] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-1/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input10/event5"
[ 25.304] (II) XINPUT: Adding extended input device "ASUE1409:00 04F3:3157 Mouse" (type: MOUSE, id 12)
[ 25.304] (**) Option "AccelerationScheme" "none"
[ 25.304] (**) ASUE1409:00 04F3:3157 Mouse: (accel) selected scheme none/0
[ 25.304] (**) ASUE1409:00 04F3:3157 Mouse: (accel) acceleration factor: 2.000
[ 25.304] (**) ASUE1409:00 04F3:3157 Mouse: (accel) acceleration threshold: 4
[ 25.306] (II) event5 - ASUE1409:00 04F3:3157 Mouse: is tagged by udev as: Mouse Pointingstick
[ 25.307] (II) event5 - ASUE1409:00 04F3:3157 Mouse: device is a pointer
[ 25.310] (II) config/udev: Adding input device ASUE1409:00 04F3:3157 Mouse (/dev/input/mouse1)
[ 25.310] (II) No input driver specified, ignoring this device.
[ 25.310] (II) This device may have been added with another device file.
[ 25.311] (II) config/udev: Adding input device ASUE1409:00 04F3:3157 Touchpad (/dev/input/event6)
[ 25.311] (**) ASUE1409:00 04F3:3157 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 25.311] (**) ASUE1409:00 04F3:3157 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 25.311] (II) Using input driver 'libinput' for 'ASUE1409:00 04F3:3157 Touchpad'
[ 25.313] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 37 paused 0
[ 25.314] (**) ASUE1409:00 04F3:3157 Touchpad: always reports core events
[ 25.314] (**) Option "Device" "/dev/input/event6"
[ 25.316] (II) event6 - ASUE1409:00 04F3:3157 Touchpad: is tagged by udev as: Touchpad
[ 25.319] (II) event6 - ASUE1409:00 04F3:3157 Touchpad: device is a touchpad
[ 25.319] (II) event6 - ASUE1409:00 04F3:3157 Touchpad: device removed
[ 25.320] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-1/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input11/event6"
[ 25.320] (II) XINPUT: Adding extended input device "ASUE1409:00 04F3:3157 Touchpad" (type: TOUCHPAD, id 13)
[ 25.323] (**) Option "AccelerationScheme" "none"
[ 25.323] (**) ASUE1409:00 04F3:3157 Touchpad: (accel) selected scheme none/0
[ 25.323] (**) ASUE1409:00 04F3:3157 Touchpad: (accel) acceleration factor: 2.000
[ 25.323] (**) ASUE1409:00 04F3:3157 Touchpad: (accel) acceleration threshold: 4
[ 25.326] (II) event6 - ASUE1409:00 04F3:3157 Touchpad: is tagged by udev as: Touchpad
[ 25.328] (II) event6 - ASUE1409:00 04F3:3157 Touchpad: device is a touchpad
[ 25.330] (II) config/udev: Adding input device ASUE1409:00 04F3:3157 Touchpad (/dev/input/mouse2)
[ 25.330] (II) No input driver specified, ignoring this device.
[ 25.330] (II) This device may have been added with another device file.
[ 25.331] (II) config/udev: Adding input device ASUE1409:00 04F3:3157 Keyboard (/dev/input/event7)
[ 25.331] (**) ASUE1409:00 04F3:3157 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.331] (**) ASUE1409:00 04F3:3157 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 25.331] (**) ASUE1409:00 04F3:3157 Keyboard: Applying InputClass "system-keyboard"
[ 25.331] (II) Using input driver 'libinput' for 'ASUE1409:00 04F3:3157 Keyboard'
[ 25.333] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 38 paused 0
[ 25.333] (**) ASUE1409:00 04F3:3157 Keyboard: always reports core events
[ 25.333] (**) Option "Device" "/dev/input/event7"
[ 25.335] (II) event7 - ASUE1409:00 04F3:3157 Keyboard: is tagged by udev as: Keyboard
[ 25.335] (II) event7 - ASUE1409:00 04F3:3157 Keyboard: device is a keyboard
[ 25.336] (II) event7 - ASUE1409:00 04F3:3157 Keyboard: device removed
[ 25.336] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:17.1/i2c_designware.1/i2c-1/i2c-ASUE1409:00/0018:04F3:3157.0001/input/input12/event7"
[ 25.336] (II) XINPUT: Adding extended input device "ASUE1409:00 04F3:3157 Keyboard" (type: KEYBOARD, id 14)
[ 25.336] (**) Option "xkb_layout" "us"
[ 25.338] (II) event7 - ASUE1409:00 04F3:3157 Keyboard: is tagged by udev as: Keyboard
[ 25.338] (II) event7 - ASUE1409:00 04F3:3157 Keyboard: device is a keyboard
[ 25.341] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event10)
[ 25.341] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 25.341] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 25.341] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[ 25.341] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[ 25.342] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 39 paused 0
[ 25.343] (**) Asus WMI hotkeys: always reports core events
[ 25.343] (**) Option "Device" "/dev/input/event10"
[ 25.344] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 25.344] (II) event10 - Asus WMI hotkeys: device is a keyboard
[ 25.345] (II) event10 - Asus WMI hotkeys: device removed
[ 25.345] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input13/event10"
[ 25.345] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 15)
[ 25.345] (**) Option "xkb_layout" "us"
[ 25.347] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 25.347] (II) event10 - Asus WMI hotkeys: device is a keyboard
[ 25.348] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 25.348] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.348] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 25.348] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 25.348] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 25.350] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 40 paused 0
[ 25.350] (**) AT Translated Set 2 keyboard: always reports core events
[ 25.350] (**) Option "Device" "/dev/input/event3"
[ 25.351] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 25.352] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 25.354] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 25.355] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 25.355] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[ 25.355] (**) Option "xkb_layout" "us"
[ 25.356] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 25.356] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 25.360] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 25.360] (II) No input driver specified, ignoring this device.
[ 25.360] (II) This device may have been added with another device file.
[ 26.120] (II) modeset(0): EDID vendor "AUO", prod id 29244
[ 26.121] (II) modeset(0): Printing DDC gathered Modelines:
[ 26.121] (II) modeset(0): Modeline "1366x768"x0.0 76.30 1366 1404 1426 1592 768 771 777 798 -hsync -vsync (47.9 kHz eP)
But there is no other file:
ls -l ~/.xsession-errors* ✔
zsh: no matches found: /home/mykhailoh/.xsession-errors*
I still can see ridges, but they seems not as prominent. For example on this site top image. There is a gradient. And I can see ridges between different color brightnesses. Those ridges just seems not as visible as before especially on video.
Yeah, those ridges are still the problem. Also it seems that they change between restarts… very weird.
pacman -Ss xf86-video-intel
this should be installed - but I’m not sure you have it
if you don’t have it:
sudo pacman -Syyu xf86-video-intel
This will likely trigger a big update - but there is no way to just install that driver by itself.
I’m not actually familiar with the way video drivers are installed or how to check for what is and should be installed.
Somewhere in your Settings there should be the Manjaro Settings Manager with which you can do this more properly.
If the issue comes down to this, someone else needs to advise - I’m just not familiar with it.
I did what you said. It launched big update, but nothing changed. I can’t see related options in Manjaro settings. Unfortunately the problem is still persists. But thank you for your help.
This is one line in Xorg.0.log: 24 Bit colour depth. All OK.
Then this must be something in the settings of the used GUI.
What GUI are you using ?
What do you mean by GUI? I am using GNOME Xorg now.
GUI=graphics user interface.
In your case Gnome.
I tried looking the problem in the settings even before I post this topic. I didn’t find anything. Display and Color tabs do not show me anything useful, at least from my perspective. I don’t know what I can change to fix it.
From that I deduce that you where not looking at the Manjaro settings manager - but at the settings for the Gnome desktop.
Two different things …
