The capacity of the manjaro gnome ssd is not defined in the system properties
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=ab258e1e-94b0-4c88-bd84-0419c5669d26 rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro base: Arch Linux
  Type: Mini-pc Mobo: GMKtec model: GMKtec v: Version 1.0 serial: <filter>
    part-nu: K12-001 uuid: 594ad380-8261-11f0-acd0-34ced5e25d00 Firmware: UEFI
    vendor: American Megatrends LLC. v: NucBox_K12 1.07 date: 07/24/2025
  System RAM: total: 32 GiB available: 28.19 GiB used: 3.24 GiB (11.5%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 5600 MT/s volts: curr: 1.1 min: 1.1
    max: 1.1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: TDS5DSAG08-56TB46C serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 H 255 w/ Radeon 780M Graphics socket: FP8 bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA70520A
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1373 min/max: 405/4967 boost: enabled
    base/boost: 3800/4950 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1373 2: 1373 3: 1373 4: 1373
    5: 1373 6: 1373 7: 1373 8: 1373 9: 1373 10: 1373 11: 1373 12: 1373 13: 1373
    14: 1373 15: 1373 16: 1373 bogomips: 121373
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse pse36
    rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
    svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic
    x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 driver: amdgpu
    v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1 bus-ID: 65:00.0
    chip-ID: 1002:1900 class-ID: 0300 temp: 35.0 C
  Device-2: HP HP Webcam HD 2300
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 03f0:e207
    class-ID: 0300
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: gpu: amdgpu display-ID: :0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 model: Philips PHL 226E9Q serial: <filter> built: 2018
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix ACO DRM 3.64 6.18.18-1-MANJARO) device-ID: 1002:1900
    memory: 2.93 GiB unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    bus-ID: 65:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-3: HP HP Webcam HD 2300
    class-ID: 0300
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: n/a (root, process) with:
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  Device-3: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0e8d:0616
  Local Storage: total: 931.51 GiB used: 16.35 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000E100SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: VDCR4005 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 16.35 GiB (1.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: ab258e1e-94b0-4c88-bd84-0419c5669d26
    used: 664 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 2F5D-BC3B
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /swap raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-5: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-6: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-3:2 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 1ea7:0066 class-ID: 0301
  Device-2: 1-5:3 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: HP HP Webcam HD 2300 type: video,audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
    chip-ID: 03f0:e207 class-ID: 0300
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 41.0 C mobo: 36.0 C gpu: amdgpu temp: 35.0 C
  Fan Speeds (rpm): N/A
  Processes: 471 Power: uptime: 50m states: freeze,mem,disk suspend: s2idle
    image: 11.21 GiB services: gsd-power, power-profiles-daemon, upowerd
    Init: systemd v: 259 default: graphical tool: systemctl
  Packages: 1260 pm: pacman pkgs: 1248 libs: 341
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 12 Compilers: gcc: 15.2.1
    Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.9 running-in: kgx
    inxi: 3.3.4
Mod edit: made inxi output visible - it had originally been posted between the template tags
Mod edit: removed duplicated inxi output
Please use the preformatted text function for the inxi output. It will make it much more readable.
In addition, please give some more information about what the issue is.
@Wishmaster You probably won’t get a lot of help until you post some details about the issue, as was requested earlier:
For example, is it causing an actual issue with your system? Or is it just a warning appearing in the logs?
If it is causing an issue, please describe the issue. It will very much help the volunteers here in working out how to fix it.
I can see 1.8% taken on your 1TB “gnome ssd”. Leaving you 98.2% left on your (usable) 931.22 GiB btrfs file system.
But there are much more efficient ways to get that information.
  • The SSD capacity is actually defined, but not in a way you might expect.
You have a Crucial NVMe SSD CT1000E100SSD8 listed with a total sze of 931.51 GiB… which makes it a 1TB drive, difference being decimal vs binary units).
only 16 GiB is currently in use.
Was that all? If this is the entire query, then please let us know if it’s answered with a big :white_check_mark: (otherwise I won’t get paid :cry: )
My problem is that the system properties do not display the disk size.
I can see it using the terminal, but it’s not in the system section of Gnome
Disks aren’t managed through system settings, and there is no “right click/properties” like Windows.
Gnome does come with Gnome Disks, but it does not do a whole lot. But you will certainly see things like capacities.
gparted comes with all Manjaro desktop environments, but this is for advanced partition and file system management. Use with care.
Shoutout to Conky here:
The time 11:59:06 is the last update time - you can adjust the timer to suit.
disks.conky
conky.config = {
-- Conky settings
	background = true,
	update_interval = 23,
	double_buffer = true,
	no_buffers = true,
-- Window specifications
	alignment = 'br',
	gap_x = 5,
	gap_y = 5,
	own_window = true,
	own_window_transparent = false,
	own_window_argb_visual = true,
	own_window_argb_value = 55,
	own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
	own_window_class = 'conky',
-- Text
	use_xft = true,
	xftalpha = 0.1,
	font = 'Noto Sans Mono :size=9',
	font = 'Droid Sans Mono :size=10',
	default_color = '#CDCDB0',
conky.text = [[${color #3da5ba}${fs_bar 4,200 /}${color #968ea1ff}
${font :bold:italic:size=9}${time %H:%M:%S}$font ${color #83a8ba}${goto 75}Evo ${goto 100}| ${fs_free_perc /}% free	${alignr}${fs_free /}${color #7199ba}
${if_existing /dev/sdc}${fs_bar 8,60 /mnt/W4} ${goto 75}W4  ${goto 100}| ${fs_free_perc /mnt/W4}% free		${alignr}${fs_free /mnt/W4}${endif}${color #9E9E9E}
${if_existing /dev/sdb}${fs_bar 8,60 /mnt/T4} ${goto 75}T4  ${goto 100}| ${fs_free_perc /mnt/T4}% free		${alignr}${fs_free /mnt/T4}${endif}${color #7199ba}
${if_existing /dev/sdd}${fs_bar 4,60 /mnt/W2} ${goto 75}W2  ${goto 100}| ${fs_free_perc /mnt/W2}% free		${alignr}${fs_free /mnt/W2}${endif}]];
Thank you all for your help and support. I’m trying to understand why one of my computers can display information (attached screenshot) about the disk capacity, but the other cannot. The OS version is the same, the kernel is the same, but the first computer has a hard drive, while the second computer has an SSD. For some reason, the information is not displayed.
![7301|690x462](upload://prvl947TSPfopirUebZGs4y2dH9.png
Best way is to open a terminal and type:
lsblk
The output should look like this example:
[user@system ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 476,9G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
├─nvme0n1p2 259:2 0 444,4G 0 part /
└─nvme0n1p3 259:3 0 32G 0 part [SWAP]
[user@system ~]$
You can see the complete size of your disk and the sizes of your partitions on the disk.
He has clearly stated what his concerns are.
How about df -h / for example?:
df -h /
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda4        49G   40G  7.3G  85% /
Add the paths accordingly:
df -h /home
/dev/sda5        49G   14G   33G  30% /home
or
df -h /home/$USER
… does this show results …? (I know, I need to clear some stuff off my /). :roll_eyes:
Oh! In Settings :right_arrow: System :right_arrow: About. The Disk Capacity field.
Mine comes up as 15 TB. And I don’t even have my NAS mounted, so it’s not even working for me. There could be bugs with this and btrfs. So I would not trust this.
If you want a GUI, that also comes with Gnome, to see how your data is distributed among your drives, or folders. You might like: Disk Usage Analyzer.
Thank you all for your participation and advice. There is no solution. The conclusion is that you should not pay attention to this if the ssd works properly when you access it through the terminal. I thought that the problem could be solved by reassembling udisks2 with Ubuntu patches, as is done in AltLinux. Unfortunately, I do not know how to do this myself. If you can help me, I will be very grateful. However, this topic has been closed. With deep respect to all the participants.
