After several minutes connecting to any WiFi (tested with a lot of different Access Points) my laptop has no internet access anymore. The WiFi signal is good, so that’s not the reason.
wolf@wolf-aspire:~$ ping google.de
PING google.de(fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003)) 56 Datenbytes
64 Bytes von fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003): icmp_seq=1 ttl=56 Zeit=634 ms
64 Bytes von fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003): icmp_seq=2 ttl=56 Zeit=573 ms
64 Bytes von fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003): icmp_seq=3 ttl=56 Zeit=85260 ms
64 Bytes von fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003): icmp_seq=4 ttl=56 Zeit=337 ms
64 Bytes von fra16s53-in-x03.1e100.net (2a00:1450:4001:813::2003): icmp_seq=5 ttl=56 Zeit=429 ms
^C
--- google.de ping-Statistik ---
6 Pakete übertragen, 5 empfangen, 16.6667% packet loss, time 5005ms
rtt min/avg/max/mdev = 337.459/17446.591/85260.237/33906.983 ms
ping: google.de: Temporärer Fehler bei der Namensauflösung
it’s German terminal, so the translation is “Temporary error during name resolution”
This is the /etc/resolv.conf and the inxi output while the problem persists:
wolf@wolf-aspire:~$ cat /etc/resolv.conf
# Generated by NetworkManager
search home
nameserver 192.168.1.1
nameserver fe80::1%wlp2s0
wolf@wolf-aspire:~$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=/dev/mapper/lvm_aspire1-root rw
cryptdevice=UUID=fc42caff-dd03-4fe1-a8ba-600665f12a51:lvm_aspire1 quiet
udev.log_priority=3
resume=/dev/disk/by-uuid/6c21d177-2c43-4562-9899-d09f48afddfb
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire ES1-131 v: V1.20
serial: <superuser required>
Mobo: Acer model: Garp_BA v: V1.20 serial: <superuser required>
UEFI: Insyde v: 1.20 date: 11/13/2015
ID-1: BAT1 charge: 30.4 Wh (100.0%) condition: 30.4/37.8 Wh (80.4%)
volts: 12.7 min: 11.4 model: SIMPLO AC14B18J type: Li-ion serial: <filter>
status: full
RAM: total: 3.75 GiB used: 2.51 GiB (67.1%)
RAM Report:
Info: model: Intel Pentium N3700 bits: 64 type: MCP arch: Airmont family: 6
model-id: 0x4C (76) stepping: 3 microcode: 0x368
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1619 high: 2400 min/max: 480/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 980 2: 696 3: 2400
4: 2400 bogomips: 12805
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 04f2:b47f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x235c built: 2013 res: 1366x768
hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (BSW) v: 4.6 Mesa 21.3.8
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Use of uninitialized value $args in concatenation (.) or string at /usr/bin/inxi line 2586.
Use of uninitialized value in concatenation (.) or string at /usr/bin/inxi line 2586.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:00:21 --:--:-- 0curl: (6) Could not resolve host: whatismyip.akamai.com
0 0 0 0 0 0 0 0 --:--:-- 0:00:23 --:--:-- 0curl: (6) Could not resolve host: icanhazip.com
0 0 0 0 0 0 0 0 --:--:-- 0:00:23 --:--:-- 0curl: (6) Could not resolve host: smxi.org
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Foxconn driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8168 v: 8.049.02-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0
WAN IP: No WAN IP found. Connected to web? SSL issues?
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-5:4
chip-ID: 0489:e095 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Message: Unable to run lvs. Root privileges required.
Device-1: lvm_aspire1 maj-min: 254:0 type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: sda3 maj-min: 8:3 size: 1.82 TiB
Local Storage: total: 1.82 TiB used: 552.71 GiB (29.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 2T00
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-1: / raw-size: 50 GiB size: 49.09 GiB (98.18%) used: 26.04 GiB (53.1%)
fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: lvm_aspire1-root label: N/A
uuid: N/A
ID-2: /boot raw-size: 488.3 MiB size: 464.5 MiB (95.14%)
used: 160.3 MiB (34.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4b8fa0de-4b76-4e6b-b9e7-2055995760ed
ID-3: /boot/efi raw-size: 488.3 MiB size: 487.3 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: AEF3-0754
ID-4: /home raw-size: 1.77 TiB size: 1.74 TiB (98.42%)
used: 526.17 GiB (29.5%) fs: ext4 dev: /dev/dm-3 maj-min: 254:3
mapped: lvm_aspire1-home label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 952 MiB used: 352 MiB (37.0%)
priority: -2 dev: /dev/dm-2 maj-min: 254:2 mapped: lvm_aspire1-swap
label: N/A uuid: 6c21d177-2c43-4562-9899-d09f48afddfb
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-4:2 info: Chicony VGA Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b47f
Device-2: 1-5:4 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e095
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 251 Uptime: 22h 32m wakeups: 3 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 Packages: 1681 pacman: 1671 lib: 466
flatpak: 0 snap: 10 Shell: Bash v: 5.1.16 running-in: tilda inxi: 3.3.15
When I manually reconnect to the same WiFi network the name resolution is working again.
No idea what is the problem and when it started exactly.
