pamac info wpa_supplicant
Version : 2:2.10-8
Description : A utility providing key negotiation for WPA wireless networks
Licenses : GPL
Repository : core
Installed Size : 6.6 MB
Groups : --
Depends On : openssl libdbus readline libnl pcsclite
Optional Dependencies : --
Required By : networkmanager
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Sat 17 Dec 2022 08:54:17 AM CST
Install Date : Tue 21 Feb 2023 11:35:35 AM CST
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
when I set up a hotsopt via NetworkManager or linux-wifi-hotspot (GitHub - lakinduakash/linux-wifi-hotspot: Feature-rich wifi hotspot creator for Linux which provides both GUI and command-line interface. It is also able to create a hotspot using the same wifi card which is connected to an AP already ( Similar to Windows 10).) (both of them use wpa_supplicant under the ground) with password, I can made the hotsopt SSID up, but none of my 5 phone or other WIFI device can connect to it ,neither of my colleague‘s
replace a new wlan card was also tried.
When I set the hotsopt SSID to open/without password, it works fine.
When I switch to IWD
use this package https://aur.archlinux.org/packages/networkmanager-iwd-overlay
,everything works fine,All my device can connect to the hotsopt with password under the combination of NetworkManager+IWD
I think there is some problem with the builtin wpa_supplicant
this should be easily be recurrent
similarly posts:
https://forum.manjaro.org/t/hosting-hotspot-not-working-after-system-upgrade/105003/3?u=ihipop
