The best way to install Monjaro and the best interface for my device xfce, plasma,Gnome
I want to delete Windows and use Linux without dual booting. Do I have to reinstall Manjaro or is there another way to do it. And what distribution is suitable for my device
  Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=a829b463-146c-4746-b99d-f090d5093505 rw quiet splash apparmor=1
    security=apparmor resume=UUID=bff42f8e-a7c8-4119-9f28-a5bd904b9451
    udev.log_priority=3
  Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop System: FUJITSU product: ESPRIMO P920 v: N/A
    serial: <superuser required> Chassis: type: 6 v: C$WX02
  Mobo: FUJITSU model: D3222-A1 v: S26361-D3222-A1
    serial: <superuser required> UEFI: FUJITSU // American Megatrends v: 4.6.5.4
    R1.46.0 for D3222-A1x date: 08/29/2018
  RAM: total: 7.65 GiB used: 3.07 GiB (40.1%)
  Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 925 high: 1300 min/max: 800/3600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 800 4: 1300
    bogomips: 25554
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Fujitsu Solutions driver: i915 v: kernel arch: Gen-5.75
    process: Intel 45nm built: 2010 ports: active: HDMI-A-1
    empty: DP-1,HDMI-A-2,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1680x1050 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung SMS22A450
    serial: <filter> built: 2011 res: 1680x1050 hz: 60 dpi: 93 gamma: 1.2
    size: 459x296mm (18.07x11.65") diag: 558mm (22") ratio: 16:10, 3:2 modes:
    max: 1680x1050 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Fujitsu Solutions driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Fujitsu Solutions driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.64 running: yes
  Device-1: Intel Ethernet I217-LM vendor: Fujitsu Solutions driver: e1000e
    v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
    driver: N/A bus-ID: 3-7:5 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
    driver: btusb v: 0.8 bus-ID: 3-2:3 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.47 TiB used: 295.43 GiB (19.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDT721064SLA360
    size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A36A scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721032CLA362
    size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A3EA scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD5000AAKX-003CA0 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15
    scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3160212SCE
    size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: <filter> rev: F scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GHB0N rev: UF03
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 70.07 GiB size: 68.41 GiB (97.64%) used: 24.96 GiB (36.5%)
    fs: ext4 dev: /dev/sdd5 maj-min: 8:53 label: root
    uuid: a829b463-146c-4746-b99d-f090d5093505
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sdd6 maj-min: 8:54 label: BOOT LINUX
    uuid: 094A-F3A6
  ID-3: /run/media/mohamed/Home pc raw-size: 298.09 GiB
    size: 298.09 GiB (100.00%) used: 270.47 GiB (90.7%) fs: ntfs dev: /dev/sdb1
    maj-min: 8:17 label: Home pc uuid: 01D7077EF036DCC0
  ID-1: swap-1 type: partition size: 8.69 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdd7 maj-min: 8:55 label: swap
    uuid: bff42f8e-a7c8-4119-9f28-a5bd904b9451
  ID-1: /dev/sda1 maj-min: 8:1 size: 596.17 GiB fs: ntfs label: New
    uuid: 01D8D103A3E2DA90
  ID-2: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: Local Disk 1
    uuid: 01D8A86EED8C6660
  ID-3: /dev/sdd1 maj-min: 8:49 size: 100 MiB fs: vfat label: N/A
    uuid: CE1D-7C5E
  ID-4: /dev/sdd2 maj-min: 8:50 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdd3 maj-min: 8:51 size: 69.37 GiB fs: ntfs label: win 10
    uuid: 0CF23425F2341584
  ID-6: /dev/sdd4 maj-min: 8:52 size: 530 MiB fs: ntfs label: N/A
    uuid: 4402A68A02A68092
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 3-1:2 info: HP Elite Keyboard type: Keyboard,HID
    power: 100mA chip-ID: 03f0:034a class-ID: 0300
  Device-2: 3-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Device-3: 3-5:4 info: ShenZhen ShanWan Twin USB Joystick type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
    chip-ID: 2563:0555 class-ID: 0300
  Device-4: 3-7:5 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
    type: WiFi driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-5: 3-14:7 info: Primax USB Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA
    chip-ID: 0461:4dfb class-ID: 0301
  Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 57.0 C pch: 58.0 C mobo: 29.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Power: 12v: 11.98 5v: N/A 3.3v: 3.38 vbat: 3.08
  Processes: 225 Uptime: 1h 33m wakeups: 0 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1367 libs: 402 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24-
How to install monjaro in the best way and what is the swap
Hello @MOemad :wink:
Then do so. Open Gparted for example and remove the windows partitions. Run update-grub and windows is removed there also. If the EFI Partition is shared with Windows, then mount it and remove the Windows folder there.
Why should you reinstall it? No, not necessary.
Manjaro is a Distribution. Which one you prefer outside in the world is your choice. Try them.
The best way to install Manjaro is with the installer. There is usually a desktop icon which is called “Install Manjaro”, although you can do everything by hand.
A swap is a partition or a file which swaps pages from the RAM to the disk when RAM is full. It is also used for hibernation. If no swap is there, then applications can crash or the whole desktop will be laggy, when the RAM is full.
