Hi. This is my first post so forgive my english.
Just installed manjaro alongside windows on my ssd. I dont know if it matters but the swap and home partitions are on my hdd.
Anyways it worked fine at first but now after the grub the system wont start.
Error:
dev/sda5: clean, 287014/2621440 files, 1878918/10485504 blocks [FAILED] Failed to start Load Save Screen Backlight Brightness of backlight:acpi_video. [FAILED] Failed to mount home. (DEPEND] Dependency failed for Local File Systems You are in emergency mode. After logging in, type "journalctl -xb" to view susten logs, "systenctl reboot" to reboot, "sustemctl default" or "exit"! to boot into default mode. Contraseña de root para manteniniento (o pulse Control-D para continuar):
Thank you.
