Hello everyone,
both in the Manjaro settings manager and in the options in Texmaker the font color has nearly the same color as the background:
This is, as you might see, quite annoying. Do you have any idea what the reason for that could be?
Thanks in advance!
David
PS:
Here is some information about my software and hardware:
(base) manjaro% inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=66d75c2d-755b-4b7b-a0bf-f1d712c4597c rw quiet splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: P8B75-M LX PLUS v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 0501 date: 10/10/2012
Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23953
Speed: 1596 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1596 2: 1596
3: 1596 4: 1596
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0152 class ID: 0380
Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Gigabyte driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:11c6
class ID: 0300
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 650 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20 class ID: 0403
Device-2: NVIDIA GK106 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
driver: rtl8192ce v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8178
class ID: 0280
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: c000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 53.05 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010DLE630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A650 scheme: GPT
ID-1: / raw size: 48.83 GiB size: 47.81 GiB (97.92%) used: 15.31 GiB (32.0%)
fs: ext4 dev: /dev/sda9 maj-min: 8:9
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw size: 50.63 GiB size: 49.59 GiB (97.94%)
used: 37.73 GiB (76.1%) fs: ext4 dev: /dev/sda10 maj-min: 8:10
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 251 Uptime: 3h 26m wakeups: 0 Memory: 7.64 GiB
used: 4.74 GiB (62.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1414 lib: 395 flatpak: 0 Shell: Zsh v: 5.8
running in: io.elementary.t inxi: 3.3.01
(base) manjaro% mhwd -l [optional: detailed view] [optional: --pci or --usb connection]
zsh: bad pattern: [optional:
> 0000:01:00.0 (0300:10de:11c6) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0380:8086:0152) Display controller Intel Corporation:
