Nachlese:
mhwd --listhardware
mhwd --listhardware
gives
> PCI devices:
TYPE BUS CLASS VENDOR DEVICE CONFIGS
Bridge 0000:02:07.0 0604 1022 43b4 0
Bridge 0000:00:08.0 0600 1022 1452 0
Bridge 0000:00:18.3 0600 1022 15eb 0
Bridge 0000:00:01.2 0604 1022 15d3 0
Multimedia controller 0000:07:00.6 0403 1022 15e3 0
Bridge 0000:00:18.1 0600 1022 15e9 0
Bridge 0000:00:01.0 0600 1022 1452 0
Serial bus controller 0000:07:00.4 0c03 1022 15e1 0
Mass storage controller 0000:08:00.0 0106 1022 7901 0
Bridge 0000:01:00.2 0604 1022 43b3 0
Bridge 0000:00:14.3 0601 1022 790e 0
Encryption controller 0000:07:00.2 1080 1022 15df 0
Serial bus controller 0000:01:00.0 0c03 1022 43bc 0
Bridge 0000:02:06.0 0604 1022 43b4 0
Display controller 0000:07:00.0 0300 1002 15d8 3
Generic system peripheral 0000:00:00.2 0806 1022 15d1 0
Bridge 0000:00:18.6 0600 1022 15ee 0
Bridge 0000:00:00.0 0600 1022 15d0 0
Bridge 0000:00:08.1 0604 1022 15db 0
Bridge 0000:00:18.4 0600 1022 15ec 0
Bridge 0000:00:18.2 0600 1022 15ea 0
Bridge 0000:02:05.0 0604 1022 43b4 0
Network controller 0000:05:00.0 0200 10ec 8168 1
Bridge 0000:00:18.0 0600 1022 15e8 0
Serial bus controller 0000:07:00.3 0c03 1022 15e0 0
Mass storage controller 0000:01:00.1 0106 1022 43b8 0
Multimedia controller 0000:07:00.1 0403 1002 15de 0
Bridge 0000:00:18.7 0600 1022 15ef 0
Serial bus controller 0000:00:14.0 0c05 1022 790b 0
Bridge 0000:02:04.0 0604 1022 43b4 0
Bridge 0000:00:08.2 0604 1022 15dc 0
Bridge 0000:00:18.5 0600 1022 15ed 0
> USB devices:
Keyboard 3-3:1.0 10800 045e 0750 0
Hub 6-0:1.0 10a00 1d6b 0003 0
Mouse 1-6:1.0 10503 046d c52f 0
Hub 3-0:1.0 10a00 1d6b 0002 0
Unclassified device 3-3:1.1 0000 045e 0750 0
Hub 4-0:1.0 10a00 1d6b 0003 0
Hub 1-0:1.0 10a00 1d6b 0002 0
Unclassified device 1-6:1.1 0000 046d c52f 0
Hub 5-0:1.0 10a00 1d6b 0002 0
Hub 2-0:1.0 10a00 1d6b 0003 0
So the Network Controller is a PCI device.
inxi -Fazy
suggested by @cscs gives
Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=08dcec6a-3100-41db-9705-afdd84060972 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5409
date: 01/07/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1977 high: 3693 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3693 2: 1400
3: 1418 4: 1399 bogomips: 28756
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 49.0 C
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ GW2780 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 15.0.7 DRM 3.52 6.4.6-1-MANJARO) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.6-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.051.02-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 344.68 GiB used: 188.03 GiB (54.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: WDC WDS250G2B0A
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 90WD scheme: GPT
ID-1: / raw-size: 51.75 GiB size: 50.64 GiB (97.84%) used: 40.65 GiB (80.3%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
used: 6.4 MiB (2.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 116.44 GiB size: 114.06 GiB (97.95%)
used: 66.33 GiB (58.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 8 GiB used: 1.02 GiB (12.8%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 49.6 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 223 Uptime: 8m wakeups: 2 Memory: total: 16 GiB note: est.
available: 13.57 GiB used: 3.02 GiB (22.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 2187 pm: dpkg pkgs: 0 pm: pacman pkgs: 2184 libs: 397
tools: pamac,trizen,yay pm: flatpak pkgs: 0 pm: snap pkgs: 3 Shell: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.28
It appears that the Network device is indeed seen and assigned a bus ID.
Moreover,
lspci
gives
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43bc (rev 02)
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43b8 (rev 02)
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43b3 (rev 02)
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c9)
07:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
08:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61)
Could the recent kernel upgrade have made it necessary to install some firmware package?
