Hi all, the problem with the Wi-Fi is a bit strange in my opinion, at first everything was running fine, but the interface found only the first Wi-Fi ( in my house I have two of them) and when I rebooted in another part of my house only the other was shown, it seems that for some reason my computer can’t handle more than one Wi-Fi in memory, also sometimes it shows no Wi-Fi at all.
Please post the output of inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=8b9270bc-e32d-4fd4-9962-1713174c001c rw quiet apparmor=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: 1215N v: x.x serial: <filter> Chassis:
type: 10 v: x.x serial: <filter>
Mobo: ASUSTeK model: 1215N v: x.xx serial: <filter>
BIOS: American Megatrends v: 0902 date: 05/05/2011
ID-1: BAT0 charge: 52.7 Wh condition: 52.7/56.2 Wh (94%) volts: 12.5/10.8
model: ASUS 1215N type: Li-ion serial: N/A status: Full
Info: Dual Core model: Intel Atom D525 bits: 64 type: MT MCP arch: Bonnell
family: 6 model-id: 1C (28) stepping: A (10) microcode: 107
L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 14407
Speed: 1800 MHz min/max: N/A Core speeds (MHz): 1: 1800 2: 1803 3: 1800
4: 1800
Type: spec_store_bypass status: Not affected
Type: spectre_v1 status: Not affected
Type: spectre_v2 status: Not affected
Device-1: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:a001
Device-2: NVIDIA GT218M [ION 2] vendor: ASUSTeK driver: nouveau v: kernel
bus ID: 04:00.0 chip ID: 10de:0a76
Device-3: IMC Networks UVC VGA Webcam type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 13d3:5702 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 129 size: 270x150mm (10.6x5.9")
diag: 309mm (12.2")
OpenGL: renderer: Mesa DRI Intel Pineview v: 1.4 Mesa 20.2.3
direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:27d8
Device-2: NVIDIA High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 04:00.1 chip ID: 10de:0be3
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet
vendor: ASUSTeK Eee PC 1015PX driver: atl1c v: kernel port: dc00
bus ID: 01:00.0 chip ID: 1969:2062
IF: enp1s0 state: down mac: <filter>
Device-2: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
Adapter
vendor: AzureWave driver: wl v: kernel modules: bcma port: dc00
bus ID: 02:00.0 chip ID: 14e4:4727
IF: wlp2s0 state: dormant mac: <filter>
Local Storage: total: 465.76 GiB used: 20.25 GiB (4.3%)
ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: MBR
ID-1: / raw size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 20.25 GiB (4.4%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 50.0 C
Processes: 212 Uptime: 1d 8h 36m Memory: 2.85 GiB used: 935.4 MiB (32.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1266 lib: 372
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
In manjaro settings it says that is installed “network-Broadcom-wl”
Hi, @GMpeep
I also think you have the linux-firmware package too.
Please, consider to read this post.
https://forum.manjaro.org/t/update-to-5-8-low-resolution-and-slow-performance/40197/2
Regards
So you recommend to install kernel 5.4?
