One for the WTF department…
I admit to being a total Bluetooth noob, but I don’t see why this should happen. I recently added Bluetooth earphones to my XFCE-based Manjaro system. Twice now, with a reboot in between, the earphones had a glitch (sound went out on one ear or playback was jittering) and my USB keyboard got no response, even after I quit the mpv player. The mouse plugged into the hub on my keyboard kept working the whole time, too. This is on a Tanix/Intel mini pc, pulse audio driver.
This is the output of inxi -Fazy
Kernel: 5.11.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=c8e669d6-890c-431a-9083-a5bee720d372 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Mini-pc System: IP3 Tech product: TX95 v: N/A serial: <filter>
Mobo: IP3 model: AB1A serial: <filter> UEFI: American Megatrends v: 0.02
date: 06/30/2020
Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 5C (92) stepping: 9 microcode: 40 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
Speed: 806 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 806 2: 1031
3: 1668 4: 1651
Type: spec_store_bypass status: Not affected
Device-1: Intel HD Graphics 500 driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5a85 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60
OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:0e.0 chip ID: 8086:5a98 class ID: 0403
Sound Server: ALSA v: k5.11.1-1-MANJARO
driver: r8169 v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8168
class ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
bus ID: 02:00.0 chip ID: 8086:3165 class ID: 0280
IF-ID-1: nordlynx state: unknown speed: 10 Mbps duplex: full mac: N/A
bus ID: 1-7:3 chip ID: 8087:0a2a class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 250.47 GiB used: 85.61 GiB (34.2%)
ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: HP model: DF4128 size: 116.48 GiB
block size: physical: 512 B logical: 512 B rotation: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-2: /dev/sdc maj-min: 8:32 type: USB model: Genesys SD USB3 Reader
size: 119.08 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1206 scheme: GPT
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: DataTraveler 102 size: 14.9 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: PMAP scheme: GPT
ID-1: / raw size: 118.79 GiB size: 116.87 GiB (98.39%)
used: 17.67 GiB (15.1%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 195 Uptime: 48m wakeups: 1 Memory: 7.63 GiB
used: 1.54 GiB (20.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1259 lib: 394 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01
