Regrettably no idea why this solved the issue on your specific system.
I’m in the testing branch. I updated my profile. I already tried everything I could to connect the mouse. The only option is to downgrade and restart the bluetooth service.
UPDATE: This is the bug: A Logitech M240 bluetooth mouse turns unusable with the transition from 5.79 to 5.80 · Issue #1138 · bluez/bluez · GitHub. The proposed workaround works.
nvidia-settings works now, but the link in the app menu does not work. I changed it already and cannot remember it exactly but the path is wrong (something like UTILS_PATH/nvidia-settings). I just deleted the first part.
Something like this? ![]()
❯ grep UTILS_PATH /usr/share/applications/nvidia-settings.desktop
Exec=__UTILS_PATH__/nvidia-settings
Whoops. I had to do something completely different to fix the previous issue, apparently I missed something.
I’ll fix it with nvidia-settings 570.133.07-2.2 here soon.
3 posts were split to a new topic: Issue with NVIDIA driver versions after switching to testing branch
Hey, just wanted to note that I resolved my heif-image-problem by downgrading libheif to 1.19.5-1
Don’'t know why I did not check downgrading earlier…
