philm
21 October 2022 12:41
1
Hello community,
Another testing branch update with some usual package updates for you.
Additional Info
Info about AUR packages
AUR (Arch User Repository ) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
You may need to rebuild any AUR packages that install files to site-packages …
Get our latest daily developer images now from Github: Plasma , GNOME , XFCE . You can get the latest stable releases of Manjaro from CDN77 .
Our current supported kernels
linux419 4.19.261
linux54 5.4.219
linux510 5.10.149
linux515 5.15.74
linux519 5.19.16
linux60 6.0.2
linux515-rt 5.15.73_rt52
linux519-rt 5.19.0_rt10
Package changes (Fri Oct 21 09:02:59 CEST 2022)
testing community x86_64: 223 new and 205 removed package(s)
testing core x86_64: 8 new and 8 removed package(s)
testing extra x86_64: 204 new and 205 removed package(s)
testing kde-unstable x86_64: 231 new and 231 removed package(s)
testing multilib x86_64: 6 new and 8 removed package(s)
A list of all package changes can be found here .
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
philm
21 October 2022 12:42
2
Known issues and solutions
2022-10-21
2022-10-18
Firefox 106.0 may have issues with screen sharing on GNOME with Wayland
2022-09-23
Nvidia 3060RTX cards may have issues with the 515.76 driver (fixed with 520.56.06)
Removing python2 from the repositories
2022-09-23 - Jelle van der Waa
Python 2 went end of life January 2020. Since then we have been actively cutting down the number of projects depending on python2
in our repositories, and we have finally been able to drop it from our distribution. If you still have python2
installed on your system consider removing it and any python2 package.
If you still require the python2 package you can keep it around, but please be aware that there will be no security updates. If you need a patched package please consult the AUR, or use an unofficial user repository .*
– Arch Linux - News: Removing python2 from the repositories
* Note: Unofficial user repositories are not supported
2022-08-27
Changes with Back In Time packages
backintime
has been renamed to backintime-qt
backintime-cli
After replacing backintime-cli
with backintime
, you will need to install backintime-qt
manually if you want the Qt frontend installed again.
2022-08-23
electron12, electron13, electron14 & electron16 have been dropped to the AUR
Unsupported Electron packages have been dropped from the official repos to the AUR. They no longer receive security updates and nothing in the repos depend on them.
If you have AUR packages depending on those versions, install the binary version from the AUR to replace them; i.e., electron16-bin
See FS#75490 - electron12, electron13, electron14, electron16 are unsupported and vulnerable packages
End of Support for 15.x.y and 16.x.y
Electron 15.x.y and 16.x.y has reached end-of-support. As per Electron’s new 8-week cadence , we were supporting the latest four versions of Electron until May 2022. With this Electron 19 release, we’ll return to supporting the latest three major versions, as well as the alpha, beta, and nightly releases.
– Release electron v19.0.0 · electron/electron · GitHub
2022-08-12
element-desktop dependency error (fixed with 1.11.4)
:: installing electron (20.0.0-1) breaks dependency 'electron19' required by element-desktop
The upstream package was already flagged out of date (it needs to be rebuilt against latest electron).
Workaround for now:
sudo pacman -Syy electron electron19 --asdeps
sudo pacman -Su
2022-08-04
Glibc 2.36 update will break EasyAntiCheat within Proton (should be fixed with glibc 2.36-2)
Temporary workaround for now is to use the flatpak version of steam:
sudo pacman -S flatpak --needed --noconfirm
sudo flatpak install com.valvesoftware.Steam -y
You can use flatseal (another flatpak app) to grant it access to your existing game library so you don’t have to re-download your games (add the game library install path under “Other files” under “Filesystem”).
sudo flatpak install com.github.tchx84.Flatseal -y
For advanced users (not recommended by us): patched glibc
and lib32-glibc
are available here . They remove the commit that broke EAC.
2022-07-27
Fixed: Pamac shows archlinux-keyring (20220713-2) and manjaro-keyring (20220514-2) as orphans
sudo pacman -D --asexplicit archlinux-keyring manjaro-keyring
Resolved: w/ base 3-2 Revert changes:
sudo pacman -D --asdeps archlinux-keyring manjaro-keyring
2022-07-16
wxWidgets 3.2 update may need manual intervention
Packages have been renamed from wxgtk- to wxwidgets- . The GTK2 frontend is no longer provided. If you have wxgtk2 installed, the upgrade will fail with:
In such case, uninstall wxgtk2
first and then proceed with the upgrade.
2022-07-13
Linux518: could not insert 'amd_pstate': No such device
With Kernel 5.18.11 there was added a regression to AMD P-State driver preventing it from loading.
2022-07-08
Wireplumber 0.4.11 may crash for GDM users
Currently there is an issue with 0.4.11 and GDM crashing on boot-up. More in the upstream bugtracker issue: wireplumber segfault: system boot and could see in my dmesg (#305) · Issues · PipeWire / wireplumber · GitLab
2022-06-07
Locale file changes
C.UTF8 locale is now included in glibc
Credits @diabonas for this change. Systemd wants us to include C.UTF8 by default and it seems the locale may be in included by glibc upstream in the future. To fix building and avoid nasty fixing in devtools, we include the locale in the package. See systemd/systemd#23252 (comment) FS#74864 : [systemd] >= 251 breaks devtools' locale
There is a pacsave for /etc/locale.conf
as it has been removed from the filesystem
package.
UPDATE : With filesystem
2022.06.08-2, it will automatically restore /etc/locale.conf
if it did not already exist.
There is a pacnew for /etc/locale.gen
. Please review it and regenerate your locale if necessary.
Hi there! I noticed after this upgrade that the first key I press after I open the Activities Overview screen in Gnome after pressing the super key gets duplicated. I recorded the screen to make the explanation a bit clearer.
Inxi
Kernel: 5.10.149-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=20705b87-eec6-4fb3-8353-031c51df1cac ro quiet splash apparmor=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
status: discharging
RAM: total: 15.6 GiB used: 4.73 GiB (30.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2538 high: 3593
min/max: 2200/6442:6146:5994:5846:6294:4950:5698:5102:5398:5250:5550
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 3593 2: 2874 3: 2873 4: 2213 5: 2481 6: 2602 7: 2189 8: 2196 9: 2195
10: 2194 11: 2193 12: 2194 13: 3592 14: 2875 15: 2869 16: 2873 17: 2874
18: 2875 19: 2190 20: 2195 21: 2196 22: 2192 23: 2194 24: 2191
bogomips: 177342
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Nanjing Magewell Eco Capture Dual HDMI M.2 vendor: SafeNet
driver: Eco Capture v: N/A alternate: MWEcoCapture pcie: gen: 2
speed: 5 GT/s lanes: 4 bus-ID: 04:00.0 chip-ID: 1cd7:0051 class-ID: 0400
Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.0 chip-ID: 10de:2182
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: gnome-shell driver: X: loaded: nvidia gpu: Eco Capture,nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5440x1080 s-dpi: 96 s-size: 1439x286mm (56.65x11.26")
s-diag: 1467mm (57.76")
Monitor-1: DP-0 pos: right res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-2 pos: center res: 1920x1080 hz: 60 dpi: 166
size: 294x166mm (11.57x6.54") diag: 338mm (13.29") modes: N/A
Monitor-3: DP-4 pos: primary,left res: 1600x900 hz: 60 dpi: 92
size: 443x249mm (17.44x9.8") diag: 508mm (20.01") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
driver: Eco Capture alternate: MWEcoCapture bus-ID: 7-3:3 pcie:
chip-ID: 0951:16ed class-ID: 0300 gen: 2 serial: <filter> speed: 5 GT/s
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Kingston HyperX Cloud Alpha S type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.10.149-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-ac907f97584b state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: veth7dac270 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 585 GiB used: 323.7 GiB (55.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: SSK SSK Storage
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0212 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 317.82 GiB
(69.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 20705b87-eec6-4fb3-8353-031c51df1cac
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6206-C799
ID-3: /run/media/acyment/Ventoy raw-size: 119.21 GiB size: 119.21 GiB
(100.00%) used: 5.88 GiB (4.9%) fs: exfat dev: /dev/sda1 maj-min: 8:1
label: Ventoy uuid: D296-EC10
ID-1: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: ADC2-5F11
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: JMicron / USA SSK Storage type: Mass Storage
driver: uas interfaces: 1 rev: 3.2 speed: 10 Gb/s power: 896mA
chip-ID: 152d:a583 class-ID: 0806 serial: <filter>
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 7-3:3 info: Kingston HyperX Cloud Alpha S type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16ed class-ID: 0300
serial: <filter>
Hub-9: 7-4:4 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2734 class-ID: 0900
Hub-10: 7-4.2:5 info: Microchip (formerly SMSC) Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2412 class-ID: 0900
Device-1: 7-4.2.1:11 info: Melfas LGD AIT Touch Controller type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1fd2:6103 class-ID: 0300
Device-2: 7-4.4:6 info: Apple Magic Trackpad 2 type: HID,Mouse
driver: magicmouse,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 05ac:0265 class-ID: 0300 serial: <filter>
Device-3: 7-4.5:8 info: Microchip (formerly SMSC) Hub Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:274c class-ID: 0300
Hub-11: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-12: 8-4:2 info: Microchip (formerly SMSC) USB5734 ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5734 class-ID: 0900
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 502 Uptime: 23h 28m wakeups: 17 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1848 pm: dpkg pkgs: 0 pm: pacman pkgs: 1836 libs: 447
tools: gnome-software,pacaur,pamac pm: flatpak pkgs: 5 pm: snap pkgs: 7
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.22
Thanks!
Alan
Perhaps off topic, but it looks like you have PulseAudio and PipeWire running simultaneously?
Also, is it possible to temporarily reassign the key to have the preferences overwritten?
Boy, tks, I thought I had uninstalled Pipewire.
You mean the super key?
It is not possible to uninstall all PipeWire packages on GNOME due to dependency issues
But PipeWire service can be disabled to prevent any conflict with PulseAudio
systemctl --user mask pipewire.socket; systemctl --user mask pipewire.service
Hanzel
26 October 2022 16:02
7
I have these entries in my log:
okt 25 16:12:57 gid kernel: amdgpu 0000:09:00.0: amdgpu: RAP: Failed to initialize RAP
okt 26 17:42:32 gid kernel: amdgpu: Move buffer fallback to memcpy unavailable
okt 26 17:42:32 gid kernel: amdgpu 0000:09:00.0: amdgpu: 000000000f24dc13 pin failed
okt 26 17:42:32 gid kernel: amdgpu 0000:09:00.0: amdgpu: (-19) kernel bo pin failed
okt 26 17:42:32 gid kernel: amdgpu 0000:09:00.0: amdgpu: DTM: Failed to initialize DTM
okt 26 17:42:32 gid kernel: amdgpu 0000:09:00.0: amdgpu: RAP: Failed to initialize RAP
Kernel: 6.0.2-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 09:00.0 chip-ID: 1002:73ff
class-ID: 0300
This seems related and should resolve itself with newer kernels.
No crashes or failing to wake up like described in the linked issue, just log entries.
Takei
26 October 2022 16:21
8
It does not always happen for me aswell. As a notice for others, the fix should be included in Kernel version 6.0.4.
