OK, thanks.
But flatpack is not installed on my system. So perhaps should it be a gnucash’s dependency now
Ehm, no: guncash should definitely not depend on flatpak.
It just happens, that the flatpak package tries to extend the XDG_DATA_DIRS variable and therefore sets/exports it. It’s the only package on my system that does the export, but there are numerous counts of code trying to evaluate/use that variable - most with fallbacks like seen here:
${XDG_DATA_DIRS:-/usr/local/share:/usr/share}
guncash should implement a similar fallback where it tries to use $XDG_DATA_DIRS - that’s all.
You can remedy your problem for the time being by ensuring XDG_DATA_DIRS is set on your system:
$ echo 'export XDG_DATA_DIRS="${XDG_DATA_DIRS:-/usr/local/share:/usr/share}"' | sudo tee /etc/profile.d/xdg-data-dirs-for-gnucash.sh
The Issue was with configuration of pulseaudio-sink-always-suspended - https://unix.stackexchange.com/questions/114602/pulseaudio-sink-always-suspended
Started getting issues with certificates and pacman after this update. Kernel 5.14
On every database sync, pacman errors with
error: failed retrieving file ‘community.db’ from mirrors.manjaro.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file ‘multilib.db’ from mirrors.manjaro.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file ‘core.db’ from mirrors.manjaro.org : SSL certificate problem: unable to get local issuer certificate
error: failed retrieving file ‘extra.db’ from mirrors.manjaro.org : SSL certificate problem: unable to get local issuer certificate
warning: too many errors from mirrors.manjaro.org, skipping for the remainder of this transaction
Then switch to a different mirror.
Thanks for the update! watchdog problem fixed!
Issue: pamac-gui has a big keyboard-delay when searching for packages
It is probably not a “keyboard delay”, I submitted a bug report last month Pamac windows unresponsive while searching when bandwidth saturated (#1097) · Issues · Applications / pamac · GitLab basically the interface hangs when it searches, and you can exacerbate this behavior when bandwidth is saturated.
Done, Thanks !
One thing i’m noticing since this update is that my HDDs are spinning up once in a while without using data on them. That didn’t happen before.
I can’t seem to figure out how to monitor which process is accessing these drives - iotop can’t be narrowed to just one disk, using lsof /mountpoint when i hear the disk spin up seems to be too slow - maybe someone has an idea on how to narrow it down? ^^
This is fixed now
I remember you posting about it in an old testing update thread last month, and I forgot to ask you about it by the time it closed. In my own experience, I stopped those annoying “watchdog did not stop” messages and the occasional shutdown/reboot hang by blacklisting sp5100_tco and iTCO_wdt per the ArchWiki. Did you fix it yourself or did the update solve that for you?
No vhba-module for kernel 515. Is this an error or not? If so - where should i report it?
3 posts were split to a new topic: Can’t install package without signature with Pacman
