Need a phone? We got you covered! PinePhone will ship with Manjaro#stayhome, #staysafe, #stayhealthy
We updated most of our Kernels
Pamac got another point-release with needed fixes
Calamares supports now Swap-files
Alsa stack got renewed
Usual Python and Haskell package updates and rebuilds
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our latest Manjaro Nibia 20.2 preview release! KDE and Gnome
Our current supported kernels
linux44 4.4.240
linux49 4.9.240
linux414 4.14.202
linux419 4.19.152
linux54 5.4.72
linux57 5.7.19 [EOL]
linux58 5.8.16
linux59 5.9.1
linux54-rt 5.4.66_rt38
linux56-rt 5.6.19_rt12
Packages Changes (Mon Oct 19 11:22:26 CEST 2020)
testing community x86_64: 834 new and 824 removed package(s)
testing core x86_64: 16 new and 16 removed package(s)
testing extra x86_64: 170 new and 170 removed package(s)
testing multilib x86_64: 5 new and 5 removed package(s)
A detailed list of all package changes can be found here.
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
nvidia 455.28 is incompatible with linux >= 5.9
2020-10-21 - Sven-Hendrik Haase
nvidia is currently partially incompatible with linux >= 5.9 [1][2]. While graphics should work fine, CUDA, OpenCL, and likely other features are broken. Users who’ve already upgraded and need those features are advised to switch to the linux-lts kernel for the time being until a fix for nvidia is available.
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally, pam_tally2 and pam_cracklib got deprecated. Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel option “systemd.unit=rescue.target”, then proceed into /etc/pam.d and merge “system-auth” and “system-auth.pacnew”
System takes a long time to boot
If you’ve got errors like Failed to start Network Manager Wait Online. you can try removing systemd from passwd and group in /etc/nsswitch.conf as described here Update: If you can see the line dbus-daemon[1453]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 45146ms)
in in your dbus log ( journalctl -b -u dbus ), the new/better workaround is to switch cups from service to socket as described here: systemctl disable org.cups.cupsd.service systemctl enable org.cups.cupsd.socket
I think I’ve some font problems
With the update of fontconfig some major rules how fonts get applied changed. Make sure that your system has ttf-dejavu installed. A more in depth explanation can be found here.
Gnome-shell-extension-pop-shell is currently incompatible with wayland
… and causes the system to freeze when the first window is tiled and can render it unbootable. Solution is a hard reset and disabling either pop shell or wayland. If the system becomes unbootable, use a live USB to edit /etc/gdm/custom.conf to disable wayland and reboot.
Not sure if its related to the latest update or not but I’m having issues with screenshot now. If I take a screenshot I only get the top left hand quarter of the screen, the other 3/4 are just blank.
Edit. It’s only gnome screenshot, pantheon screenshot works fine.
Everything seems OK (//EDIT: kernel 5.8, Nvidia 455), but it is the second consecutive update erasing my custom GRUB theme GRUB_THEME="/boot/grub/themes/pacbang/theme.txt", is this something I’ll have to revert regularly now? Maybe if it can be possible, do not override this line if it is not the default Manjaro theme already?
Pamac threw this error (and put up an error window):
Detecting snapshots ...
Info: Separate boot partition not detected
No snapshots found.
If you think an error has occurred , please file a bug report at " https://github.com/Antynea/grub-btrfs "
Error while configuring
Nothing to do. Abort.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Will send bug report to btrfs at github (IF there is a bug) as it recommends.
Edit:
I just rebooted, everything seems to be OK, so I guess this error was nothing to worry about.
Info Center -> SMART still has the non sense French translation saying THE EXACT OPPOSITE of the original English version… It is telling me all my peripherals seem to not work properly, when in the original version it is telling me the opposite, all me peripherals seem to work as intended.
It happens all the time that there are updates without announcement, Manjaro team doesn’t create a new thread when some packages got updated, and again, you’re twisting the chronology, the information of the issue being about Stable branch was not there at all, when I started trying to figure it out, when a user posted information about an issue in the Testing branch thread. I don’t have a crystal ball.
