Add missing addons feature for flatpak packages
Hey there guys I wanted to make a suggestion to add flatpak plugin support like Gnome Software has in Fedora for example but is missing in Pamac, the only way you can install them is to use the terminal flatpak search/install command to find and install them and there is a lot of plugins for different apps like OBS, Gimp and Steam for example.
These screenshots are from my friends Fedora 39 installation
It would be awesome to also have those add-ons on the repo packages as it would be very convenient to easily install those addons
Those packages, with the exception of Steam, already exist in the official repos (flatpak versions are not required):
[~]$ pacman -Si gimp
Repository      : extra
Version         : 2.10.36-1
Description     : GNU Image Manipulation Program
Architecture    : x86_64
URL             : https://www.gimp.org/
Licenses        : GPL  LGPL
Groups          : None
Provides        : None
Depends On      : babl  cairo  fontconfig  freetype2  gcc-libs  gdk-pixbuf2  gegl  glib2  glibc  gtk2  harfbuzz  hicolor-icon-theme  iso-codes  json-glib  lcms2  libgexiv2  libmypaint  libunwind  mypaint-brushes1  pango  zlib  bzip2
                  libgudev  libheif  libjpeg-turbo  libjxl  libmng  libpng  librsvg  libtiff  libwebp  libwmf  libx11  libxcursor  libxext  libxfixes  libxmu  libxpm  openexr  openjpeg2  poppler-data  poppler-glib  xz
Optional Deps   : alsa-lib: for MIDI event controller module
                  ghostscript: for PostScript support
                  gutenprint: for sophisticated printing only as gimp has built-in cups print support
                  gvfs: for HTTP/S support (and many other schemes)
Conflicts With  : gimp-plugin-wavelet-decompose
Replaces        : gimp-plugin-wavelet-decompose
Download Size   : 20.12 MiB
Installed Size  : 113.11 MiB
Packager        : Christian Hesse <eworm@archlinux.org>
Build Date      : Mon 06 Nov 2023 22:12:08
Validated By    : MD5 Sum  SHA-256 Sum  Signature
[~]$ pacman -Si obs-studio
Repository      : extra
Version         : 30.0.0-1
Description     : Free, open source software for live streaming and recording
URL             : https://obsproject.com
Licenses        : GPL2
Groups          : None
Provides        : None
Depends On      : ffmpeg  jansson  libxinerama  libxkbcommon-x11  mbedtls  rnnoise  pciutils  qt6-svg  curl  jack  gtk-update-icon-cache  pipewire  libxcomposite
Optional Deps   : libfdk-aac: FDK AAC codec support
                  libva-intel-driver: hardware encoding
                  libva-mesa-driver: hardware encoding
                  luajit: scripting support
                  python: scripting support
                  sndio: Sndio input client
                  v4l2loopback-dkms: virtual camera support
Conflicts With  : None
Replaces        : None
Download Size   : 5.77 MiB
Installed Size  : 21.65 MiB
Packager        : Jonathan Steel <jsteel@archlinux.org>
Build Date      : Mon 13 Nov 2023 04:59:37
As to specific addons, my opinion is that the existing mechanisms are likely sufficient. If you know the addon(s) you want, one can always search for them via pamac or pacman, otherwise, the respective website of a particular application might be the best port of call.
I have seen an instance of Discover used only for addons (for KDE, I think); albeit not in Manjaro. Something like that might be a nice touch.
Hi @gameslayer9999,
Pamac already has a flatpak feature. It’s just a separaate plugin for libpamac that neeeds to be installed, called libpamac-flatpak-plugin:
$ pamac search pamac flatpak
libpamac-flatpak-plugin  11.6.3-1        extra
Flatpak plugin for Pamac
libpamac-flatpak  11.4.1-1        AUR
Library for Pamac package manager based on libalpm - flatpak support enabled
libpamac-debug  11.6.3-1        extra
Detached debugging symbols for libpamac
$ pamac info libpamac-flatpak-plugin
Version               : 11.6.3-1
Description           : Flatpak plugin for Pamac
URL                   : https://gitlab.manjaro.org/applications/libpamac
Licences              : GPL3
Repository            : extra
Installed Size        : 71.6 kB
Groups                : --
Depends On            : flatpak libpamac
Optional Dependencies : --
Provides              : libpamac-flatpak.so=11 pamac-flatpak-plugin
Replaces              : pamac-flatpak-plugin
Conflicts With        : --
Packager              : Mark Wagie <mark@manjaro.org>
Build Date            : Sat 02 Dec 2023 19:28:35
And it already is in the extra repository, so you should be able to install it with:
pamac install libpamac-flatpak-plugin
Hope this helps!
y’all … they are talking about ‘add-ons’ for flatpak packages.
pamac does not support this feature.
Frankly … I’m not very familiar with it … and I cant find any equal in documentation, or on a source like flathub … so I wonder whats actually at play there.
Edit.
Doh, it is there on fltahub. Just had to look a bit harder (bottom tabs beginning with ‘Information’).
Example OBS link:
for regular repo packages that is great but it would be nice to have the plugins show up under the specific app to be easily found and for better presentation
This idea suggestion is mainly for flatpak in pamac but it would be good for consistency to have both :slight_smile:
Yeah my suggestion would be to add this feature as it would complete pamac and add this missing feature
I’m pretty sure pamac gets developed by roughly the one person. When it comes to major changes anyways.
Humbly pinging @guinux
Oh wow really? :open_mouth:
Well I understand a project like this being a lot of work for one person and they have done a very good job, it would be a nice have feature and just a suggestion :slight_smile:
Yes… mostly… it looks like its been touched by a few people here and there over the years. But mostly just guinux.
I humbly submit that a link to the user manual might be a worthwhile feature, if it doesn’t already exist.
However, access to addons for any particular application might best be handled by a feature within that particular application, in my opinion.
This isn’t intended to minimise the OPs suggestion; but seems more practical.
it doesn’t need to, the flatpak add-ons are already there but don’t have a graphical way in pamac to see them or install them which is why I made the suggestion to complete the flatpak support in Pamac :slight_smile:
Why I suggest that it’s probably better handled by the individual application is that [in some instances] there could potentially be hundreds of addons available for any given application. One example was the Atom Text Editor (which has been retired), however, there are many apps that thrive on addons, and that’s not necessarily a bad thing.
What I’d be concerned about is the possible overhead for Pamac. Remember, it’s not just your favourite apps with addons to be considered; if this feature was incorporated into Pamac, it opens the door for every popular app with addons to also be incorporated into Pamac. I think that could be a nightmare from a management perspective; not to mention, from a one-man development perspective.
Also, any such feature should/would be for all applications with collections of addons, more than likely. Specifying that it be only for flatpak apps is rather pointless considering flatpak is only [technically] for packages not available in the official repos. Regrettably, ignorance of this seems rampant as more (newer) users choose flatpak before anything else; and often wonder why they have issues.
Note, this doesn’t mean I dislike the idea, but that it’s probably better addressed from the application level; and by the development teams that are most familiar with the addons available for their respective projects.
Just my 2 cents. Spend it wisely. Cheers.
The Addons already exist on flathub so all that needs to be done is add support to list those add-ons and there wouldn’t be any overhead since it’s all applied from flathub. It wouldn’t be any different for repo packages because they also already exist in the repo, the only difference would be they would just show up under the application.
Also most applications don’t manage their own plugins are are usually just in the repo or flatpak but the feature itself is missing and would solve this problem and make pamac feature completely especially for flatpak packages. All the features does is lists the already existing flatpak or repo plugins for packages on package page for convenience that’s it. :slightly_smiling_face:
I think you are thinking of this in terms of something like firefox addons … where these are more like ‘additional libraries provided by the software distribution framework’.
Its hard to make a comparison because there isnt an equivalent in pacman. Well … pamac has ‘software mode’ … so … yeah, its a bit like if the flatpak plugin was only working in ‘software mode’ - it will provide major packages but not their accessories.
No no I am literally referring to the feature Gnome Software has that Pamac is missing for flatpak packages or even repo packages and just listing those addon packages on the package exactly like Gnome software does :smile:
Please create an upstream libpamac issue for greater visibility. @guinux doesn’t spend much time on the forum.
Sure :+1:
I need to have my account accepted and is pending, I do find it annoying that I already had a account and it got deleted for inactivity when it shouldn’t do that…
my username is corey_bruce
