[Testing Update] 2020-05-02 - Kernels, Gnome Extensions, LibreOffice, ICU
Hello community,
here is another Testing Update for you:
... get our minimal ISOs if you want to have no bullsht shipped withit ...*
Some feature-updates:
  • Most of our Kernels got updated
  • We updated some Gnome Extensions
  • LibreOffice is at 6.3.6
  • ICU rebuilds
  • The usual upstream updates including Haskell and Python
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out stable release of Manjaro Lysia 20.0! XFCE, KDE and Gnome You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
  • linux316 3.16.83
  • linux44 4.4.220
  • linux49 4.9.220
  • linux414 4.14.177
  • linux419 4.19.119
  • linux54 5.4.37
  • linux55 5.5.19 EOL
  • linux56 5.6.9
  • linux57 5.7-rc3
  • linux54-rt 5.4.28_rt19
  • linux56-rt 5.6.4_rt3
Package Changes (Sat May 2 13:10:26 CEST 2020)
  • testing community x86_64: 413 new and 463 removed package(s)
  • testing core x86_64: 10 new and 11 removed package(s)
  • testing extra x86_64: 253 new and 252 removed package(s)
  • testing multilib x86_64: 9 new and 9 removed package(s)
:: Different overlay package(s) in repository community x86_64
                             PACKAGE           2020-05-01           2020-05-02
                               cpu-x3.2.4.r229.g5d77dd4-13.2.4.r233.g8030be7-1
 gnome-shell-extension-dash-to-panel     v31+5+g769a484-1     v37+7+g595a083-1
gnome-shell-extension-desktop-icons-ng           0.10.0-1             0.11.0-1
     gnome-shell-extension-gsconnect                 36-1                 37-1
gnome-shell-extension-nightshellswitcher 17.r1.g6cd0fd2-1     20.r1.ge08d19a-1
gnome-shell-extension-nightthemeswitcher 21.r0.ge29cd0d-1     25.r0.gcd423c2-1
         gnome-shell-extension-unite     37.r5.g2948e5f-1     41.r2.g490dbc1-1
               manjaro-arm-installer             1.2.16-1             1.2.17-1
                        mycroft-core             20.2.1-1             20.2.2-1
                           seamonkey             2.53.1-0           2.53.1-0.1
             vte-notification-common             0.60.2-1             0.60.2-2
                   vte3-notification             0.60.2-1             0.60.2-2
                                 yay              9.4.6-1              9.4.7-2
                 pop-shell-shortcuts                    -                0.1-1
:: Different sync package(s) in repository community x86_64
                                 0ad              a23.1-8              a23.1-9
                          adapta-kde           20180828-1                    -
                             aegisub             3.2.2-38             3.2.2-39
                                agda             2.6.1-32             2.6.1-33
                                 agg                2.5-9                    -
                                aide             0.16.2-2                    -
                                anki             2.1.15-1             2.1.23-1
                             arc-kde           20180614-3                    -
                                arch             1.3.5-12                    -
                                avfs              1.1.1-1              1.1.2-1
                                 bar                1.4-6                    -
                         bluegriffon               3.1-10               3.1-11
                 bluegriffon-i18n-cs               3.1-10               3.1-11
                 bluegriffon-i18n-de               3.1-10               3.1-11
              bluegriffon-i18n-es-es               3.1-10               3.1-11
                 bluegriffon-i18n-fi               3.1-10               3.1-11
                 bluegriffon-i18n-fr               3.1-10               3.1-11
                 bluegriffon-i18n-gl               3.1-10               3.1-11
                 bluegriffon-i18n-he               3.1-10               3.1-11
                 bluegriffon-i18n-hu               3.1-10               3.1-11
                 bluegriffon-i18n-it               3.1-10               3.1-11
                 bluegriffon-i18n-ja               3.1-10               3.1-11
                 bluegriffon-i18n-ko               3.1-10               3.1-11
                 bluegriffon-i18n-nl               3.1-10               3.1-11
                 bluegriffon-i18n-pl               3.1-10               3.1-11
                 bluegriffon-i18n-ru               3.1-10               3.1-11
                 bluegriffon-i18n-sl               3.1-10               3.1-11
                 bluegriffon-i18n-sr               3.1-10               3.1-11
              bluegriffon-i18n-sv-se               3.1-10               3.1-11
              bluegriffon-i18n-zh-cn               3.1-10               3.1-11
              bluegriffon-i18n-zh-tw               3.1-10               3.1-11
                         bomberclone             0.11.9-7                    -
                                c2hs            0.28.6-85            0.28.6-86
                       cabal-install            3.2.0.0-3            3.2.0.0-5
                             calibre             4.14.0-1             4.14.0-2
                      calibre-common             4.14.0-1             4.14.0-2
                     calibre-python3             4.14.0-1             4.14.0-2
                              ccfits                2.5-4                2.5-5
                          cellwriter              1.3.6-1                    -
                               cgrep            6.6.32-22            6.6.32-23
                             couchdb              2.3.1-3              2.3.1-4
                                croc              8.0.7-1              8.0.9-1
                             cryptol            2.8.0-103            2.8.0-105
                               darcs           2.14.2-218             2.14.3-1
                              dcfldd                1.7-1                    -
                                 dee              1.2.7-7              1.2.7-8
                        deepin-music              5.0.1-2              5.0.1-3
                               dhall            1.31.1-17            1.31.1-18
                          dhall-bash            1.0.29-21            1.0.29-22
                          dhall-json             1.6.3-21             1.6.3-22
                                dino              0.1.0-3              0.1.0-4
                             dovecot             2.3.10-1             2.3.10-2
                             dumb-a4              2.0.3-1                    -
                                dune              2.3.0-1              2.3.1-1
                              dwdiff              2.1.2-3              2.1.2-4
                          easystroke             0.6.0-22                    -
                      eclipse-common               4.15-1                    -
                         eclipse-cpp               4.15-1                    -
                        eclipse-java               4.15-1                    -
                  eclipse-javascript               4.15-1                    -
                         eclipse-jee               4.15-1                    -
                         eclipse-php               4.15-1                    -
                        eclipse-rust               4.15-1                    -
                            electron              8.2.3-1              8.2.5-1
                           electron4             4.2.12-4             4.2.12-5
                           electron5             5.0.13-3             5.0.13-4
                           electron6              6.1.9-3              6.1.9-4
                           electron7             7.1.14-3             7.1.14-4
                               esmtp                1.2-7                    -
                         fcitx5-rime     0.0.0.20200402-1     0.0.0.20200501-1
                              firrtl              1.2.5-1              1.3.0-1
                           flickcurl               1.26-8               1.26-9
                           fwbuilder              5.3.7-5              5.3.7-6
                       gambas3-devel            3.14.3-10            3.14.3-13
                     gambas3-gb-args            3.14.3-10            3.14.3-13
                    gambas3-gb-cairo            3.14.3-10            3.14.3-13
                    gambas3-gb-chart            3.14.3-10            3.14.3-13
                  gambas3-gb-clipper            3.14.3-10            3.14.3-13
                  gambas3-gb-complex            3.14.3-10            3.14.3-13
                 gambas3-gb-compress            3.14.3-10            3.14.3-13
                    gambas3-gb-crypt            3.14.3-10            3.14.3-13
                     gambas3-gb-data            3.14.3-10            3.14.3-13
                       gambas3-gb-db            3.14.3-10            3.14.3-13
                  gambas3-gb-db-form            3.14.3-10            3.14.3-13
                 gambas3-gb-db-mysql            3.14.3-10            3.14.3-13
                  gambas3-gb-db-odbc            3.14.3-10            3.14.3-13
            gambas3-gb-db-postgresql            3.14.3-10            3.14.3-13
               gambas3-gb-db-sqlite3            3.14.3-10            3.14.3-13
                     gambas3-gb-dbus            3.14.3-10            3.14.3-13
                  gambas3-gb-desktop            3.14.3-10            3.14.3-13
            gambas3-gb-desktop-gnome            3.14.3-10            3.14.3-13
              gambas3-gb-desktop-x11            3.14.3-10            3.14.3-13
           gambas3-gb-eval-highlight            3.14.3-10            3.14.3-13
                     gambas3-gb-form            3.14.3-10            3.14.3-13
              gambas3-gb-form-dialog            3.14.3-10            3.14.3-13
              gambas3-gb-form-editor            3.14.3-10            3.14.3-13
                 gambas3-gb-form-mdi            3.14.3-10            3.14.3-13
               gambas3-gb-form-stock            3.14.3-10            3.14.3-13
            gambas3-gb-form-terminal            3.14.3-10            3.14.3-13
                      gambas3-gb-gmp            3.14.3-10            3.14.3-13
                      gambas3-gb-gsl            3.14.3-10            3.14.3-13
                      gambas3-gb-gtk            3.14.3-10            3.14.3-13
               gambas3-gb-gtk-opengl            3.14.3-10            3.14.3-13
                     gambas3-gb-gtk3            3.14.3-10            3.14.3-13
                    gambas3-gb-httpd            3.14.3-10            3.14.3-13
                    gambas3-gb-image            3.14.3-10            3.14.3-13
             gambas3-gb-image-effect            3.14.3-10            3.14.3-13
              gambas3-gb-image-imlib            3.14.3-10            3.14.3-13
                 gambas3-gb-image-io            3.14.3-10            3.14.3-13
                  gambas3-gb-inotify            3.14.3-10            3.14.3-13
                   gambas3-gb-libxml            3.14.3-10            3.14.3-13
                  gambas3-gb-logging            3.14.3-10            3.14.3-13
                      gambas3-gb-map            3.14.3-10            3.14.3-13
                 gambas3-gb-markdown            3.14.3-10            3.14.3-13
                    gambas3-gb-media            3.14.3-10            3.14.3-13
               gambas3-gb-media-form            3.14.3-10            3.14.3-13
                gambas3-gb-memcached            3.14.3-10            3.14.3-13
                     gambas3-gb-mime            3.14.3-10            3.14.3-13
                    gambas3-gb-mysql            3.14.3-10            3.14.3-13
                  gambas3-gb-ncurses            3.14.3-10            3.14.3-13
                      gambas3-gb-net            3.14.3-10            3.14.3-13
                 gambas3-gb-net-curl            3.14.3-10            3.14.3-13
                 gambas3-gb-net-pop3            3.14.3-10            3.14.3-13
                 gambas3-gb-net-smtp            3.14.3-10            3.14.3-13
                   gambas3-gb-openal            3.14.3-10            3.14.3-13
                   gambas3-gb-opengl            3.14.3-10            3.14.3-13
              gambas3-gb-opengl-glsl            3.14.3-10            3.14.3-13
               gambas3-gb-opengl-glu            3.14.3-10            3.14.3-13
               gambas3-gb-opengl-sge            3.14.3-10            3.14.3-13
                  gambas3-gb-openssl            3.14.3-10            3.14.3-13
                   gambas3-gb-option            3.14.3-10            3.14.3-13
                     gambas3-gb-pcre            3.14.3-10            3.14.3-13
                      gambas3-gb-pdf            3.14.3-10            3.14.3-13
                      gambas3-gb-qt5            3.14.3-10            3.14.3-13
               gambas3-gb-qt5-opengl            3.14.3-10            3.14.3-13
               gambas3-gb-qt5-webkit            3.14.3-10            3.14.3-13
                   gambas3-gb-report            3.14.3-10            3.14.3-13
                  gambas3-gb-scanner            3.14.3-10            3.14.3-13
                      gambas3-gb-sdl            3.14.3-10            3.14.3-13
                gambas3-gb-sdl-sound            3.14.3-10            3.14.3-13
                     gambas3-gb-sdl2            3.14.3-10            3.14.3-13
               gambas3-gb-sdl2-audio            3.14.3-10            3.14.3-13
                 gambas3-gb-settings            3.14.3-10            3.14.3-13
                   gambas3-gb-signal            3.14.3-10            3.14.3-13
                     gambas3-gb-term            3.14.3-10            3.14.3-13
                     gambas3-gb-util            3.14.3-10            3.14.3-13
                 gambas3-gb-util-web            3.14.3-10            3.14.3-13
                      gambas3-gb-v4l            3.14.3-10            3.14.3-13
                       gambas3-gb-vb            3.14.3-10            3.14.3-13
                      gambas3-gb-web            3.14.3-10            3.14.3-13
                 gambas3-gb-web-feed            3.14.3-10            3.14.3-13
                 gambas3-gb-web-form            3.14.3-10            3.14.3-13
                      gambas3-gb-xml            3.14.3-10            3.14.3-13
                 gambas3-gb-xml-html            3.14.3-10            3.14.3-13
                  gambas3-gb-xml-rpc            3.14.3-10            3.14.3-13
                 gambas3-gb-xml-xslt            3.14.3-10            3.14.3-13
                         gambas3-ide            3.14.3-10            3.14.3-13
                     gambas3-runtime            3.14.3-10            3.14.3-13
                      gambas3-script            3.14.3-10            3.14.3-13
                                gdal              3.0.4-7              3.0.4-9
                            gimp-dbp              1.1.9-6                    -
                         gimp-nufraw             0.43.3-1             0.43.3-2
                   gimp-plugin-fblur              3.2.6-6                    -
                     gimp-plugin-lqr              0.7.2-3                    -
         gimp-plugin-wavelet-denoise              0.3.1-5                    -
                        gimp-refocus              0.9.0-5                    -
                           git-annex        8.20200330-21         8.20200501-1
                          git-repair        1.20200102-74        1.20200102-75
                              gitlab            12.10.1-1            12.10.2-1
                       gitlab-gitaly            12.10.0-1            12.10.2-1
                               glide             0.13.3-1                    -
                               glitz              0.5.6-7                    -
                             gnucash                3.9-1                3.9-2
                          gnunet-gtk             0.12.0-1                    -
                        gnustep-base             1.26.0-4             1.27.0-1
                        gnustep-make              2.7.0-3              2.8.0-1
      golang-github-stretchr-testify              1.5.0-1              1.5.1-1
                              gopass              1.8.6-4              1.9.0-1
                   gtk-theme-switch2              2.1.0-5                    -
                           gvm-tools              1.4.1-3                    -
                                gvmd              8.0.1-1                    -
                       haskell-aeson            1.4.7.1-7            1.4.7.1-8
         haskell-aeson-better-errors          0.9.1.0-171          0.9.1.0-172
                haskell-aeson-compat             0.3.9-89             0.3.9-90
                  haskell-aeson-diff           1.1.0.8-92           1.1.0.8-94
                haskell-aeson-pretty             0.8.8-36             0.8.8-37
                    haskell-aeson-qq             0.8.3-49             0.8.3-50
                  haskell-aeson-yaml           1.0.6.0-23           1.0.6.0-24
                  haskell-alsa-mixer             0.3.0-31             0.3.0-32
                haskell-authenticate            1.3.5-105            1.3.5-106
          haskell-authenticate-oauth           1.6.0.1-83           1.6.0.1-84
                 haskell-auto-update             0.1.6-52             0.1.6-53
                         haskell-aws              0.22-37              0.22-38
            haskell-binary-instances            1.0.0.1-8            1.0.0.1-9
               haskell-binary-tagged               0.2-56               0.2-57
                  haskell-bower-json          1.0.0.1-169          1.0.0.1-170
                       haskell-■■■■■             0.52.1-9               0.53-1
            haskell-bsb-http-chunked           0.0.0.4-91           0.0.0.4-92
                         haskell-bz2           1.0.0.2-20           1.0.0.2-21
                 haskell-casa-client             0.0.1-26             0.0.1-27
                  haskell-casa-types             0.0.1-22             0.0.1-23
                       haskell-cborg           0.2.2.1-14           0.2.2.1-15
                  haskell-cborg-json           0.2.2.0-14           0.2.2.0-15
                  haskell-cheapskate           0.1.1.2-75           0.1.1.2-76
               haskell-clash-prelude              1.2.1-3              1.2.1-4
                  haskell-config-ini          0.2.4.0-103          0.2.4.0-104
                   haskell-criterion           1.5.6.2-41           1.5.6.2-43
       haskell-criterion-measurement           0.1.2.0-39           0.1.2.0-40
                         haskell-dav             1.3.4-88             1.3.4-89
                        haskell-dbus             1.2.13-8             1.2.14-1
               haskell-dbus-hslogger           0.1.0.1-31           0.1.0.1-32
                 haskell-descriptive            0.9.5-102            0.9.5-103
                         haskell-dns             4.0.1-20             4.0.1-21
                   haskell-doclayout                0.3-9               0.3-10
                haskell-doctemplates              0.8.2-3              0.8.2-4
                   haskell-esqueleto           3.3.3.0-12           3.3.3.0-13
                 haskell-fast-logger             3.0.1-27             3.0.1-28
                  haskell-fdo-notify            0.3.1-283            0.3.1-284
                    haskell-fsnotify           0.3.0.1-94           0.3.0.1-95
           haskell-ghc-lib-parser-ex           8.10.0.1-1           8.10.0.2-1
                     haskell-githash           0.1.4.0-14           0.1.4.0-15
                      haskell-gnuidn            0.2.2-159            0.2.2-160
            haskell-hackage-security           0.6.0.1-10           0.6.0.1-11
             haskell-haddock-library             1.8.0-52             1.8.0-53
                      haskell-hakyll           4.13.3.0-9          4.13.3.0-12
                       haskell-hasql             1.4.2-13             1.4.2-14
                  haskell-hasql-pool             0.5.1-87             0.5.1-88
           haskell-hasql-transaction           1.0.0.1-17           1.0.0.1-18
                    haskell-hedgehog             1.0.2-29             1.0.2-30
                        haskell-here           1.2.13-123           1.2.13-124
              haskell-hi-file-parser           0.1.0.0-34           0.1.0.0-35
                haskell-hjsonpointer             1.5.0-86             1.5.0-87
                 haskell-hledger-lib            1.17.1-11            1.17.1-12
                    haskell-hopenpgp             2.9.4-68             2.9.4-69
                       haskell-hpack           0.33.0-117           0.33.0-118
                   haskell-hspec-wai            0.10.1-24            0.10.1-25
              haskell-hspec-wai-json            0.10.1-28            0.10.1-29
                haskell-hsyaml-aeson           0.2.0.0-31           0.2.0.0-32
                        haskell-http        4000.3.14-174        4000.3.14-176
                 haskell-http-client           0.6.4.1-43           0.6.4.1-45
             haskell-http-client-tls          0.3.5.3-224          0.3.5.3-225
                haskell-http-conduit          2.3.7.3-116          2.3.7.3-117
               haskell-http-download           0.2.0.0-43           0.2.0.0-45
                haskell-http-streams           0.8.7.1-87           0.8.7.1-89
                       haskell-http2              2.0.4-6              2.0.4-7
                  haskell-httpd-shed          0.4.1.1-103          0.4.1.1-105
                         haskell-hxt          9.3.1.18-66          9.3.1.18-67
   haskell-insert-ordered-containers            0.2.3.1-3            0.2.3.1-4
                 haskell-interpolate            0.2.0-140            0.2.0-141
    haskell-interpolatedstring-perl6             1.0.2-38             1.0.2-39
                       haskell-ipynb              0.1-174              0.1-176
                        haskell-jose           0.8.2.0-86            0.8.2.1-1
                   haskell-js-jquery            3.3.1-413            3.3.1-415
                  haskell-lens-aeson               1.1-28               1.1-29
                haskell-lifted-async           0.10.0.6-3           0.10.0.6-4
             haskell-microlens-aeson           2.3.0.4-51           2.3.0.4-52
                 haskell-microstache          1.0.1.1-146          1.0.1.1-147
                haskell-monad-logger            0.3.32-24            0.3.32-25
                    haskell-mustache             2.3.1-88             2.3.1-89
                 haskell-network-uri           2.6.3.0-70           2.6.3.0-72
             haskell-optparse-simple          0.1.1.2-181          0.1.1.2-182
                haskell-pandoc-types              1.20-32              1.20-33
                      haskell-pantry           0.4.0.1-36           0.4.0.1-38
                        haskell-path             0.7.0-14             0.7.0-15
                     haskell-path-io             1.6.0-22             1.6.0-23
                  haskell-persistent          2.10.5.2-26          2.10.5.2-27
               haskell-persistent-qq           2.9.1.1-78           2.9.1.1-79
           haskell-persistent-sqlite          2.10.6.2-53          2.10.6.2-54
         haskell-persistent-template           2.8.2.3-30           2.8.2.3-31
             haskell-persistent-test           2.0.3.1-24           2.0.3.1-25
                  haskell-pipes-http            1.0.6-136            1.0.6-137
           haskell-postgresql-binary            0.12.2-43            0.12.2-44
                      haskell-resolv           0.1.1.3-13            0.1.2.0-1
                       haskell-retry            0.8.1.2-1            0.8.1.2-2
                         haskell-rio           0.1.15.0-3           0.1.15.1-1
                 haskell-rio-orphans          0.1.1.0-106          0.1.1.0-108
             haskell-rio-prettyprint           0.1.0.0-57           0.1.0.0-59
                       haskell-sandi              0.5-106              0.5-107
                         haskell-sbv               8.6-62               8.6-64
                   haskell-serialise           0.2.2.0-14           0.2.2.0-15
                     haskell-servant              0.17-31              0.17-32
              haskell-servant-server              0.17-34              0.17-35
             haskell-servant-swagger             1.1.8-37             1.1.8-39
                       haskell-shake            0.18.5-77            0.18.5-78
                 haskell-shakespeare            2.0.24-25            2.0.24-26
                      haskell-shelly            1.8.1-104            1.8.1-105
                  haskell-singletons                2.7-2                2.7-3
                 haskell-skylighting           0.8.3.4-12           0.8.3.4-13
            haskell-skylighting-core           0.8.3.4-13           0.8.3.4-14
                   haskell-snap-core           1.0.4.1-77           1.0.4.1-78
                 haskell-snap-server          1.1.1.1-197          1.1.1.1-198
                   haskell-sourcemap            0.1.6-177            0.1.6-178
                    haskell-src-exts             1.23.0-4             1.23.0-5
               haskell-src-exts-util             0.2.5-50             0.2.5-51
                    haskell-src-meta             0.8.5-10             0.8.5-11
                  haskell-statistics          0.15.2.0-16          0.15.2.0-17
                    haskell-swagger2               2.5-15                2.6-1
       haskell-tamarin-prover-theory             1.4.1-79             1.4.1-80
              haskell-tasty-discover             4.2.1-12             4.2.1-13
                haskell-tasty-golden            2.3.3.1-2            2.3.3.2-1
              haskell-tasty-hedgehog           1.0.0.2-29           1.0.0.2-30
                    haskell-tasty-th            0.1.7-100            0.1.7-101
           haskell-test-framework-th             0.2.4-25             0.2.4-26
                     haskell-texmath           0.12.0.2-5           0.12.0.2-6
                    haskell-text-icu           0.7.0.1-31           0.7.0.1-32
                haskell-time-manager             0.0.0-49             0.0.0-50
         haskell-tls-session-manager             0.0.4-39             0.0.4-40
                   haskell-tree-diff               0.1-84               0.1-85
                          haskell-tz           0.1.3.3-28           0.1.3.3-29
                      haskell-tzdata    0.1.20190911.0-23    0.1.20190911.0-24
              haskell-uri-bytestring           0.3.2.2-48           0.3.2.2-49
                  haskell-uri-encode           1.5.0.5-77           1.5.0.5-78
              haskell-wai-app-static           3.1.7.1-81           3.1.7.1-82
                   haskell-wai-extra          3.0.29.1-43          3.0.29.1-44
          haskell-wai-handler-launch           3.0.3.1-47           3.0.3.1-48
                  haskell-wai-logger             2.3.6-72             2.3.6-73
                        haskell-warp            3.3.10-10            3.3.10-12
                    haskell-warp-tls            3.2.11-66            3.2.11-67
                        haskell-wreq          0.5.3.2-188          0.5.3.2-189
                  haskell-xml-hamlet           0.5.0.1-79           0.5.0.1-80
                haskell-xss-sanitize            0.3.6-114            0.3.6-115
                        haskell-yaml          0.11.3.0-17          0.11.3.0-18
                       haskell-yesod           1.6.0.1-88           1.6.0.1-89
                  haskell-yesod-auth            1.6.10-26            1.6.10-27
                  haskell-yesod-core            1.6.18-16            1.6.18-17
               haskell-yesod-default            1.2.0-726            1.2.0-727
                  haskell-yesod-form            1.6.7-167            1.6.7-168
            haskell-yesod-persistent          1.6.0.4-112          1.6.0.4-113
                haskell-yesod-static          1.6.0.1-369          1.6.0.1-370
                  haskell-yesod-test            1.6.9-128            1.6.9-129
                           hedgewars             1.0.0-61             1.0.0-62
                             hledger          1.17.1.1-14          1.17.1.1-15
                          hledger-ui          1.17.1.1-20          1.17.1.1-22
                         hledger-web            1.17.1-32            1.17.1-33
                               hlint            2.2.11-44            2.2.11-46
                              hoogle         5.0.17.15-41         5.0.17.15-42
                      hopenpgp-tools            0.23.1-29            0.23.1-30
                               idris            1.3.2-127            1.3.2-128
                               ifuse              1.1.3-6                    -
                              igraph              0.8.2-1              0.8.2-2
                                 imv              4.1.0-1              4.1.0-2
                          javasqlite           20150419-2                    -
                             kbibtex            1:0.9.2-1            1:0.9.2-2
                            keycloak              9.0.3-1              9.0.3-2
                              keynav       0.20110708.0-3       0.20180821.0-1
                              kstars            1:3.4.2-1            1:3.4.2-2
                             kubectx              0.8.0-1              0.9.0-1
                             labplot              2.7.0-3              2.7.0-4
                              ledger              3.1.3-5              3.2.0-1
                      libcurl-compat             7.69.1-1             7.70.0-1
                      libcurl-gnutls             7.69.1-1             7.70.0-1
                             libindi              1.8.5-1              1.8.5-2
                      libmodsecurity            1:3.0.4-1            1:3.0.4-2
                             libsass              3.6.3-1              3.6.4-1
                             libvips              8.9.0-2              8.9.0-3
                                lshw            B.02.18-3          B.02.19.2-1
                        luminancehdr              2.6.0-5              2.6.0-6
                                maim              5.6.3-1              5.6.3-2
                              mapnik             3.0.23-1             3.0.23-2
               matrix-appservice-irc             0.16.0-5             0.17.0-1
                              minbif              1.0.5-8                    -
                            mod_wsgi              4.6.8-1                    -
                      mongo-c-driver             1.16.2-1             1.16.2-2
                              monica                3.7-6                    -
                     mysql-workbench             8.0.20-2             8.0.20-3
                             ncmpcpp             0.8.2-11             0.8.2-12
                             neomutt           20200424-1           20200501-1
                             netplan               0.98-1               0.99-1
                              nodejs             14.1.0-1             14.1.0-2
                  nodejs-lts-dubnium            10.20.1-1            10.20.1-2
                   nodejs-lts-erbium            12.16.2-1            12.16.3-1
                        oath-toolkit              2.6.2-7              2.6.2-8
                              octave              5.2.0-2              5.2.0-3
                             openttd             1.10.1-1             1.10.1-2
                             openvas              6.0.1-2                    -
                              packer              1.5.5-1              1.5.6-1
                              pandoc           2.9.2.1-25           2.9.2.1-27
                     pandoc-citeproc              0.17-85              0.17-88
                     pandoc-crossref           0.3.6.2-81           0.3.6.2-83
                  papirus-icon-theme           20200405-1           20200430-1
                            pdf2djvu             0.9.17-2             0.9.17-3
                               pdftk              3.1.0-1              3.1.1-1
                               peony              2.1.2-1              2.1.2-2
                         php-mongodb              1.7.4-1              1.7.4-2
                               pinta                1.6-4                    -
                              podman              1.9.0-2              1.9.1-1
                       podman-docker              1.9.0-2              1.9.1-1
                              poedit              1:2.3-1              1:2.3-2
                           postgrest             7.0.0-21             7.0.0-24
                          processing              3.5.4-1                    -
                         python-gdal              3.0.4-7              3.0.4-9
           python-importlib-metadata              1.5.1-1              1.5.2-1
                       python-orjson              2.6.6-1              3.0.0-1
                  python-progressbar             3.51.1-1             3.51.2-1
                       python-pyglet              1.5.4-1              1.5.4-2
                        python-pyicu              2.4.3-1              2.4.3-2
                     python-pyinsane             2.0.13-2                    -
                        python-sword              1.8.1-8              1.8.1-9
                     python-tenacity              6.1.0-1              6.2.0-1
          python2-importlib-metadata              1.5.1-1              1.5.2-1
                              qtspim             9.1.21-1                    -
                              recoll             1.26.6-1             1.26.6-2
                              remacs              1:0.1-1                    -
                      rime-cantonese     0.0.0.20200430-1     0.0.0.20200501-1
                                root            6.20.04-3            6.20.04-5
                           root-cuda            6.20.04-3            6.20.04-5
                           ropgadget                6.2-1                6.3-1
                              rspamd                2.5-1                2.5-2
                             scribus              1.5.5-9             1.5.5-11
                          shellcheck              0.7.1-4              0.7.1-6
                             shotgun              2.2.0-1              2.2.0-2
                simplescreenrecorder              0.4.0-1              0.4.1-1
                                slop                7.5-2                7.5-3
                               stack            2.3.0.1-8           2.3.0.1-11
                            steghide              0.5.1-9                    -
                          strawberry              0.6.9-1             0.6.10-1
                     stylish-haskell          0.11.0.0-19          0.11.0.0-20
                                surf                2.0-2                    -
                         sweethome3d                6.2-1                6.3-1
                              tabbed                0.6-3                    -
                      tamarin-prover            1.4.1-331            1.4.1-332
                           tarantool              2.4.0-1              2.4.0-2
                             taskell           1.9.2.0-85           1.9.2.0-87
                    telegram-desktop              2.1.0-1              2.1.1-1
         terraform-provider-keycloak             1.16.0-1             1.18.0-1
                           tesseract              4.1.1-1              4.1.1-2
                             traefik              2.2.0-1              2.2.1-1
                         transset-df                  6-6                    -
                            tuxpaint             0.9.23-2                    -
                     tuxpaint-config             0.0.14-1                    -
                     tuxpaint-stamps         2018.09.01-1                    -
                          unarchiver             1.10.1-8            1.10.1-10
         v2ray-domain-list-community       202004300409-1       202005010407-1
                               vault              1.3.4-1              1.4.1-1
                      vim-jellybeans                1.7-1                    -
                        vim-nerdtree              6.4.6-1              6.5.0-1
                              waybar              0.9.2-1              0.9.2-2
                              wcslib                7.2-1                7.2-2
                           widelands                 20-8                 20-9
                                wren              0.1.0-2                    -
                           xbindkeys              1.8.6-3                    -
                                 xca              2.2.1-1              2.3.0-1
                            xcircuit            3.10.12-1            3.10.24-1
                              xmobar              0.33-42              0.33-44
                                 yaz             5.30.2-1             5.30.2-2
                               zapcc         7.0.325000-3                    -
                                zeal            1:0.6.1-1                    -
                                 znc              1.7.5-4              1.7.5-5
             zsh-theme-powerlevel10k              1.6.0-1              1.7.0-1
                             hacksaw                    -              1.0.4-1
                    python-typeguard                    -              2.7.1-1
:: Different overlay package(s) in repository core x86_64
                             linux54             5.4.36-1             5.4.37-1
                     linux54-headers             5.4.36-1             5.4.37-1
                             linux56              5.6.8-1              5.6.9-1
                     linux56-headers              5.6.8-1              5.6.9-1
:: Different sync package(s) in repository core x86_64
                          cryptsetup              2.3.1-3              2.3.2-1
                                curl             7.69.1-1             7.70.0-1
                            iana-etc           20200401-1           20200428-1
                                 icu               65.1-3               67.1-1
                              netctl               1.21-2               1.22-1
                              s-nail            14.9.18-1            14.9.19-1
                            xfsprogs              5.6.0-1              5.6.0-2
:: Different overlay package(s) in repository extra x86_64
                               boxit              2.1.3-5              2.1.3-6
                            boxit-32              2.1.3-1              2.1.3-2
                     boxit-32-server              2.1.3-1              2.1.3-2
                           boxit-arm              2.1.3-3              2.1.3-4
                        boxit-server              2.1.3-3              2.1.3-6
                gnome-control-center           3.36.1-1.1           3.36.2-1.1
                   linux54-acpi_call             1.1.0-42             1.1.0-43
                    linux54-bbswitch               0.8-42               0.8-43
                 linux54-broadcom-wl      6.30.223.271-42      6.30.223.271-43
                 linux54-ndiswrapper              1.62-42              1.62-43
                linux54-nvidia-340xx           340.108-34           340.108-35
                linux54-nvidia-390xx           390.132-42           390.132-43
                linux54-nvidia-418xx           418.113-42           418.113-43
                linux54-nvidia-430xx            430.64-42            430.64-43
                linux54-nvidia-435xx            435.21-42            435.21-43
                linux54-nvidia-440xx             440.82-9            440.82-10
                    linux54-nvidiabl              0.88-42              0.88-43
                       linux54-r8168           8.048.02-2           8.048.02-3
                   linux54-rtl8723bu           20200405-6           20200405-7
                    linux54-tp_smapi              0.43-42              0.43-43
                 linux54-vhba-module          20200106-27          20200106-28
    linux54-virtualbox-guest-modules              6.1.6-6              6.1.6-7
     linux54-virtualbox-host-modules              6.1.6-6              6.1.6-7
                         linux54-zfs             0.8.3-26             0.8.3-27
                   linux56-acpi_call             1.1.0-10             1.1.0-11
                    linux56-bbswitch               0.8-10               0.8-11
                 linux56-broadcom-wl      6.30.223.271-10      6.30.223.271-11
                 linux56-ndiswrapper              1.62-10              1.62-11
                linux56-nvidia-340xx           340.108-10           340.108-11
                linux56-nvidia-390xx           390.132-10           390.132-11
                linux56-nvidia-418xx           418.113-10           418.113-11
                linux56-nvidia-430xx            430.64-10            430.64-11
                linux56-nvidia-435xx            435.21-10            435.21-11
                linux56-nvidia-440xx             440.82-8             440.82-9
                       linux56-r8168           8.048.02-2           8.048.02-3
                   linux56-rtl8723bu          20200405-10          20200405-11
                    linux56-tp_smapi              0.43-10              0.43-11
                 linux56-vhba-module          20200106-10          20200106-11
    linux56-virtualbox-guest-modules              6.1.6-6              6.1.6-7
     linux56-virtualbox-host-modules              6.1.6-6              6.1.6-7
                         linux56-zfs             0.8.3-10             0.8.3-11
            manjaro-settings-manager              0.5.6-7              0.5.6-8
        manjaro-settings-manager-kcm              0.5.6-7              0.5.6-8
  manjaro-settings-manager-knotifier              0.5.6-7              0.5.6-8
   manjaro-settings-manager-notifier              0.5.6-7              0.5.6-8
                            qt5-base             5.14.2-1             5.14.2-2
             qt5-xcb-private-headers             5.14.2-1             5.14.2-2
                               xfwm4           4.14.1-1.1           4.14.2-1.1
                    boxit-arm-server                    -              2.1.3-4
:: Different sync package(s) in repository extra x86_64
                         389-ds-base            1.4.3.4-2            1.4.3.4-3
                     accountsservice             0.6.55-1             0.6.55-2
                               boost             1.72.0-1             1.72.0-2
                          boost-libs             1.72.0-1             1.72.0-2
                              brltty                6.0-8                6.0-9
                            calligra              3.2.0-1              3.2.0-2
                            cbindgen             0.14.1-1             0.14.2-1
                             cfitsio             1:3.47-1             1:3.48-1
                            chromium      81.0.4044.129-1      81.0.4044.129-2
               evolution-data-server             3.36.2-1             3.36.2-2
                               gl2ps              1.4.0-1              1.4.1-1
                gnome-control-center             3.36.1-1             3.36.2-1
                            gtkglext             1.2.0-11             1.2.0-12
                            gwenview            20.04.0-1            20.04.0-2
                            harfbuzz              2.6.5-1              2.6.5-2
                        harfbuzz-icu              2.6.5-1              2.6.5-2
                            inkscape             0.92.5-1                1.0-2
                          kbookmarks             5.69.0-1             5.69.0-2
                                 kdb              3.2.0-2              3.2.0-4
                          kitinerary            20.04.0-1            20.04.0-2
                                 ldb            1:2.1.1-1            1:2.1.2-1
                              libcdr              0.1.6-1              0.1.6-2
                           libe-book              0.1.3-6              0.1.3-7
                             libical              3.0.8-1              3.0.8-2
                            libmspub              0.1.4-6              0.1.4-7
                      libphonenumber             8.11.5-1             8.11.5-2
                        libqalculate            3.9.0.a-1            3.9.0.a-2
                              libqxp              0.0.2-3              0.0.2-4
                   libreoffice-fresh              6.4.3-1              6.4.3-3
               libreoffice-fresh-sdk              6.4.3-1              6.4.3-3
                   libreoffice-still              6.3.5-4              6.3.6-1
                libreoffice-still-af              6.3.5-1              6.3.6-1
                libreoffice-still-am              6.3.5-1              6.3.6-1
                libreoffice-still-ar              6.3.5-1              6.3.6-1
                libreoffice-still-as              6.3.5-1              6.3.6-1
               libreoffice-still-ast              6.3.5-1              6.3.6-1
                libreoffice-still-be              6.3.5-1              6.3.6-1
                libreoffice-still-bg              6.3.5-1              6.3.6-1
                libreoffice-still-bn              6.3.5-1              6.3.6-1
             libreoffice-still-bn-in              6.3.5-1              6.3.6-1
                libreoffice-still-bo              6.3.5-1              6.3.6-1
                libreoffice-still-br              6.3.5-1              6.3.6-1
               libreoffice-still-brx              6.3.5-1              6.3.6-1
                libreoffice-still-bs              6.3.5-1              6.3.6-1
                libreoffice-still-ca              6.3.5-1              6.3.6-1
       libreoffice-still-ca-valencia              6.3.5-1              6.3.6-1
                libreoffice-still-cs              6.3.5-1              6.3.6-1
                libreoffice-still-cy              6.3.5-1              6.3.6-1
                libreoffice-still-da              6.3.5-1              6.3.6-1
                libreoffice-still-de              6.3.5-1              6.3.6-1
               libreoffice-still-dgo              6.3.5-1              6.3.6-1
                libreoffice-still-dz              6.3.5-1              6.3.6-1
                libreoffice-still-el              6.3.5-1              6.3.6-1
             libreoffice-still-en-gb              6.3.5-1              6.3.6-1
             libreoffice-still-en-za              6.3.5-1              6.3.6-1
                libreoffice-still-eo              6.3.5-1              6.3.6-1
                libreoffice-still-es              6.3.5-1              6.3.6-1
                libreoffice-still-et              6.3.5-1              6.3.6-1
                libreoffice-still-eu              6.3.5-1              6.3.6-1
                libreoffice-still-fa              6.3.5-1              6.3.6-1
                libreoffice-still-fi              6.3.5-1              6.3.6-1
                libreoffice-still-fr              6.3.5-1              6.3.6-1
                libreoffice-still-ga              6.3.5-1              6.3.6-1
                libreoffice-still-gd              6.3.5-1              6.3.6-1
                libreoffice-still-gl              6.3.5-1              6.3.6-1
                libreoffice-still-gu              6.3.5-1              6.3.6-1
                libreoffice-still-he              6.3.5-1              6.3.6-1
                libreoffice-still-hi              6.3.5-1              6.3.6-1
                libreoffice-still-hr              6.3.5-1              6.3.6-1
                libreoffice-still-hu              6.3.5-1              6.3.6-1
                libreoffice-still-id              6.3.5-1              6.3.6-1
                libreoffice-still-is              6.3.5-1              6.3.6-1
                libreoffice-still-it              6.3.5-1              6.3.6-1
                libreoffice-still-ja              6.3.5-1              6.3.6-1
                libreoffice-still-ka              6.3.5-1              6.3.6-1
                libreoffice-still-kk              6.3.5-1              6.3.6-1
                libreoffice-still-km              6.3.5-1              6.3.6-1
          libreoffice-still-kmr-latn              6.3.5-1              6.3.6-1
                libreoffice-still-kn              6.3.5-1              6.3.6-1
                libreoffice-still-ko              6.3.5-1              6.3.6-1
               libreoffice-still-kok              6.3.5-1              6.3.6-1
                libreoffice-still-ks              6.3.5-1              6.3.6-1
                libreoffice-still-lb              6.3.5-1              6.3.6-1
                libreoffice-still-lo              6.3.5-1              6.3.6-1
                libreoffice-still-lt              6.3.5-1              6.3.6-1
                libreoffice-still-lv              6.3.5-1              6.3.6-1
               libreoffice-still-mai              6.3.5-1              6.3.6-1
                libreoffice-still-mk              6.3.5-1              6.3.6-1
                libreoffice-still-ml              6.3.5-1              6.3.6-1
                libreoffice-still-mn              6.3.5-1              6.3.6-1
               libreoffice-still-mni              6.3.5-1              6.3.6-1
                libreoffice-still-mr              6.3.5-1              6.3.6-1
                libreoffice-still-my              6.3.5-1              6.3.6-1
                libreoffice-still-nb              6.3.5-1              6.3.6-1
                libreoffice-still-ne              6.3.5-1              6.3.6-1
                libreoffice-still-nl              6.3.5-1              6.3.6-1
                libreoffice-still-nn              6.3.5-1              6.3.6-1
                libreoffice-still-nr              6.3.5-1              6.3.6-1
               libreoffice-still-nso              6.3.5-1              6.3.6-1
                libreoffice-still-oc              6.3.5-1              6.3.6-1
                libreoffice-still-om              6.3.5-1              6.3.6-1
                libreoffice-still-or              6.3.5-1              6.3.6-1
             libreoffice-still-pa-in              6.3.5-1              6.3.6-1
                libreoffice-still-pl              6.3.5-1              6.3.6-1
                libreoffice-still-pt              6.3.5-1              6.3.6-1
             libreoffice-still-pt-br              6.3.5-1              6.3.6-1
                libreoffice-still-ro              6.3.5-1              6.3.6-1
                libreoffice-still-ru              6.3.5-1              6.3.6-1
                libreoffice-still-rw              6.3.5-1              6.3.6-1
             libreoffice-still-sa-in              6.3.5-1              6.3.6-1
               libreoffice-still-sat              6.3.5-1              6.3.6-1
                libreoffice-still-sd              6.3.5-1              6.3.6-1
               libreoffice-still-sdk              6.3.5-4              6.3.6-1
                libreoffice-still-si              6.3.5-1              6.3.6-1
               libreoffice-still-sid              6.3.5-1              6.3.6-1
                libreoffice-still-sk              6.3.5-1              6.3.6-1
                libreoffice-still-sl              6.3.5-1              6.3.6-1
                libreoffice-still-sq              6.3.5-1              6.3.6-1
                libreoffice-still-sr              6.3.5-1              6.3.6-1
           libreoffice-still-sr-latn              6.3.5-1              6.3.6-1
                libreoffice-still-ss              6.3.5-1              6.3.6-1
                libreoffice-still-st              6.3.5-1              6.3.6-1
                libreoffice-still-sv              6.3.5-1              6.3.6-1
             libreoffice-still-sw-tz              6.3.5-1              6.3.6-1
                libreoffice-still-ta              6.3.5-1              6.3.6-1
                libreoffice-still-te              6.3.5-1              6.3.6-1
                libreoffice-still-tg              6.3.5-1              6.3.6-1
                libreoffice-still-th              6.3.5-1              6.3.6-1
                libreoffice-still-tn              6.3.5-1              6.3.6-1
                libreoffice-still-tr              6.3.5-1              6.3.6-1
                libreoffice-still-ts              6.3.5-1              6.3.6-1
                libreoffice-still-tt              6.3.5-1              6.3.6-1
                libreoffice-still-ug              6.3.5-1              6.3.6-1
                libreoffice-still-uk              6.3.5-1              6.3.6-1
                libreoffice-still-uz              6.3.5-1              6.3.6-1
                libreoffice-still-ve              6.3.5-1              6.3.6-1
                libreoffice-still-vi              6.3.5-1              6.3.6-1
                libreoffice-still-xh              6.3.5-1              6.3.6-1
             libreoffice-still-zh-cn              6.3.5-1              6.3.6-1
             libreoffice-still-zh-tw              6.3.5-1              6.3.6-1
                libreoffice-still-zu              6.3.5-1              6.3.6-1
                          libsynctex         2019.51075-8        2019.51075-10
                            libvisio              0.1.7-2              0.1.7-3
                             libxml2             2.9.10-1             2.9.10-2
                              libzmf              0.0.2-7              0.0.2-8
                            m17n-lib              1.8.0-6              1.8.0-7
                                 mpd            0.21.23-3            0.21.23-4
                                ovmf           1:202002-1                    -
                       pangox-compat   0.0.2+2+gedb9e09-3                    -
                perl-async-interrupt               1.25-3               1.26-1
                          perl-clone               0.44-1               0.45-1
                                 php              7.4.5-1              7.4.5-2
                          php-apache              7.4.5-1              7.4.5-2
                             php-cgi              7.4.5-1              7.4.5-2
                           php-dblib              7.4.5-1              7.4.5-2
                           php-embed              7.4.5-1              7.4.5-2
                         php-enchant              7.4.5-1              7.4.5-2
                             php-fpm              7.4.5-1              7.4.5-2
                              php-gd              7.4.5-1              7.4.5-2
                            php-imap              7.4.5-1              7.4.5-2
                            php-intl              7.4.5-1              7.4.5-2
                            php-odbc              7.4.5-1              7.4.5-2
                           php-pgsql              7.4.5-1              7.4.5-2
                          php-phpdbg              7.4.5-1              7.4.5-2
                          php-pspell              7.4.5-1              7.4.5-2
                            php-snmp              7.4.5-1              7.4.5-2
                          php-sodium              7.4.5-1              7.4.5-2
                          php-sqlite              7.4.5-1              7.4.5-2
                            php-tidy              7.4.5-1              7.4.5-2
                             php-xsl              7.4.5-1              7.4.5-2
                            pipewire              0.3.2-1              0.3.4-1
                       pipewire-docs              0.3.2-1              0.3.4-1
                       pipewire-jack              0.3.2-1              0.3.4-1
                      pipewire-pulse              0.3.2-1              0.3.4-1
                             poppler             0.87.0-1             0.88.0-1
                        poppler-glib             0.87.0-1             0.88.0-1
                         poppler-qt5             0.87.0-1             0.88.0-1
                             postfix              3.5.1-1              3.5.1-2
                          postgresql               12.2-2               12.2-3
                     postgresql-docs               12.2-2               12.2-3
                     postgresql-libs               12.2-2               12.2-3
              postgresql-old-upgrade               11.7-1               11.7-2
                      python-wstools              0.4.8-4              0.4.9-1
                     python2-wstools              0.4.8-4              0.4.9-1
                        qt5-location             5.14.2-1             5.14.2-2
                       qt5-webengine             5.14.2-1             5.14.2-2
                          qt5-webkit      5.212.0alpha4-3      5.212.0alpha4-4
                                   r              4.0.0-1              4.0.0-2
                              raptor            2.0.15-12            2.0.15-13
                               samba             4.12.1-1             4.12.2-3
                           smbclient             4.12.1-1             4.12.2-3
                         texlive-bin         2019.51075-8        2019.51075-10
                         thunderbird             68.7.0-1             68.7.0-2
                             tracker              2.3.4-1              2.3.4-2
                      tracker-miners              2.3.3-1              2.3.3-2
                          vte-common             0.60.2-1             0.60.2-2
                                vte3             0.60.2-1             0.60.2-2
                          webkit2gtk             2.28.2-1             2.28.2-2
                        wxgtk-common              3.0.4-2              3.0.5-1
                              wxgtk2              3.0.4-2              3.0.5-1
                              wxgtk3              3.0.4-2              3.0.5-1
                               xfwm4             4.14.1-1             4.14.2-1
                              xmlsec             1.2.30-1             1.2.30-2
                               xterm                354-1                355-1
                           edk2-ovmf                    -             202002-7
                          edk2-shell                    -             202002-7
:: Different sync package(s) in repository multilib x86_64
                          lib32-curl             7.69.1-1             7.70.0-1
                      lib32-harfbuzz              2.6.5-1              2.6.5-2
                  lib32-harfbuzz-icu              2.6.5-1              2.6.5-2
                           lib32-icu               65.1-3               67.1-1
                       lib32-libcups              2.3.1-1              2.3.3-1
                lib32-libcurl-compat             7.69.1-1             7.70.0-1
                lib32-libcurl-gnutls             7.69.1-1             7.70.0-1
                       lib32-libxml2             2.9.10-1             2.9.10-2
          lib32-simplescreenrecorder              0.4.0-1              0.4.1-1
0 voters
Known issues and solutions
Thunderbird might throw an error of older version available.
Use $ thunderbird --allow-downgrade from a terminal to fix it.
Older issues
HP Device Manager
Pamac stuck at "Preparing..."
Users have reported issues with the recent release candidate of Pamac 9.4.0 when initiating transactions, being stuck at "Preparing..." without being able to cancel the transaction and quit Pamac normally.
For now, it is recommended to use pacman to do package management until this issue is solved and Pamac become usable again. Please test out upcoming updates for Pamac to see if the issue becomes solved or not.
If you are stuck in "Preparing...", you will have to manually kill the pamac-managerprocess.
Reported on Gitlab:
https://gitlab.manjaro.org/applications/pamac/issues/757
Upgrading firewalld package to 0.8.1-2 requires manual intervention
Please read this announcement if you have file conflicts when trying to upgrade firewalld package to 0.8.1-2.
Firewalld requires manual intervention
khotkeys identified as an orphaned package
You can remove that package, but might loose some functionality with your key-bindings. We made it now optional to be installed.
Weird font glitches (see screenshots below).
If you have weird glitches like below...
Screenshots
string3
strings%20mismatch
... have you tried turning it off and on again?
More seriously, so far, people that reported to have such issue noticed that the problem goes away at next boot.
Installing xorgproto (2019.2-2) breaks dependency of a package
If you run into an issue because of xorgproto please DON'T follow the Arch suggestion as Manjaro uses the xorgproto-transfer package to make this automatic. If you have an issue, please report and wait for an update from us!
AUR Rebuilds required after updating python 3.7 to 3.8
Packages that depend on python from the AUR will need to be rebuilt after everything else has been updated. You can rebuild some of them with the following:
sudo pacman -S --needed --noconfirm expac yay
yay -S --rebuildtree $(pacman -Qmq $(expac %N python))
You can find other packages that need to be rebuilt by looking at the folders/files in
/usr/lib/python3.7/site-packages/
To find out what package owns a folder/file in that, you can use the following:
pacman -Qo folder_or_filename
If no package owns a file, it can probably be ignored.
System Settings and kinfocenter crash when entering Night Color settings randomly
Remove entire [NightColor] section of ~/.config/kwinrc
No solution yet ─ please edit as soon as a workaround is found.
xfce4-power-manager does not open / upower fails
Install kernel 4.14 or higher (4.14, 4.19, 5.2 [EOL], 5.3)
There is an issue with upower 0.99.11-1 on kernels 4.4 and 4.9.
xfce4-terminal / guake / gnome-terminal does not open
Update to vte3 0.58.2-1 or install kernel 4.14 or higher (4.14, 4.19, 5.2 [EOL], 5.3)
There is an issue with vte3 0.58.1-1 on kernels 4.4 and 4.9.
Replace linux52 with community/linux-latest ?
linux52 is EOL and has been removed from the repositories. It will be replaced by a metapackage which will from now on keep you on a maintained kernel.
If you want to keep the old kernel and modules then include them in your pacman.conf's IgnorePkg.
Pamac-Qt is not compatible to 9.0 API of Pamac
Pamac Qt 0.3 pre-RC: Towards the release, needs help in testing
the pkgver 19.10.1 ship with an hook to remove the capability from gnome-shell. A message is present during install but essentially you need to reboot the system to show correctly the icons in the desktop. More info here
Now I got the warning:
[2020-05-02T18:23:12+0200] [ALPM] warning: directory permissions differ on /etc/sudoers.d/
filesystem: 755  package: 750
Shall we change it back to 750 (recursive)? I got a little confused...
all good here on my Manjaro awesome.
Was gufw fixed upstream ? I just downgraded like philm posted in the wiki, removed gufw completely afterwards from the system and then reinstalled gufw 20. Seems to work. All icons are here.
Is fixed in this update:
Should be 750 as it was before
... because I changed it there.
I still don't know if this shall be changed for all files in that directory or only for the folder.
I'm on 26-04-2020 stable and here folder is 750 and files are 440
I would say that a recursive change of permissions is (almost) always a very bad idea, it is a better choice to evaluate the situation on a per-file basis.
yay gets an update. Yay!
I'm getting the following:
Total Installed Size:  1849.59 MiB
Net Upgrade Size:         5.79 MiB
:: Proceed with installation? [Y/n] y
(87/87) checking keys in keyring                                   [#####################################] 100%
(87/87) checking package integrity                                 [#####################################] 100%
(87/87) loading package files                                      [#####################################] 100%
(87/87) checking for file conflicts                                [#####################################] 100%
error: failed to commit transaction (conflicting files)
gufw: /usr/share/applications/gufw.desktop exists in filesystem
I went to /usr/share/applications and removed gufw and gufw.desktop, then ran upate again.
It seems to work here. - Checked version, it`s v. 20 and all icons are here.
Thanks for that I was removing the copy in /.local/share/applications/ alls good now. Installing now.
Yes, the firewall gufw icon has returned to it's place on my Menu after this update. Nice fast work.
Manjaro Gnome, Arc Menu.
Unable to launch Arc Menu Settings though. I click and nothing opens. Also Dash to Panel Settings.
I still have issues with the manjaro-kde-settings package.
remove it then, you don't actually need to keep it on an installed and setup system
( 3/52) upgrading accountsservice                                  [#####################################] 100%
warning: directory permissions differ on /var/lib/AccountsService/icons/
filesystem: 755  package: 775
gufw fixed
The fix is absolutely correct. And works.
The Klickibunti-Version (gufw_20.04.1-1_all.deb)
is a little bit different from manjaro-Version: /usr/lib/python3.8 is not in the .deb-archiv
because Klickibunti uses a separate packet for phyton. As Manjaro does too - I know.
((Fun/on:) But Attention is the mother of the Porcelain box (dont Troll me, I am not a Herrenmensch) :fish:
(Fun/(should never be) off))
The team did a really good job! :+1: :100:
I wonder why eclipse got removed.
(Not mad about it, just curious)
