Im using KDE and Manjaro newest Stable and there was 2-4 Packages yesterday only 2mb size if i remember right, i downloaded something like libpacmanager or so, my system was up to date and always stable. Since i updated 3 days ago the newest stable i experience some strange KDE desktop bugs also but i had no problem with Smplayer, i also never experienced a crash with Smplayer since im using Manjaro 16 month and daily use with SMPlayer, but after the small update the smplayer crashed again and again… when im using VLC Player and starting Smplayer its run stable for a while… Thats really strange behavior.
But yesterday and today this application crashed atleast 8 times and restarting PC/Linux don’t help either.
Here is my journal:
Mar 04 23:07:51 koboldx-z170 systemd-coredump[1588]: [🡕] Process 1525 (smplayer) of user 1000 dumped core.
Module /usr/bin/smplayer with build-id aa531664ed478d9da2df96057e9f1d2e>
Stack trace of thread 1525:
#0 0x00007f82cdd9c48d n/a (n/a + 0x0)
â–‘â–‘ Subject: Process 1525 (smplayer) dumped core
â–‘â–‘ Defined-By: systemd
â–‘â–‘ Support: https://forum.manjaro.org/c/support
â–‘â–‘ Documentation: man:core(5)
â–‘â–‘
â–‘â–‘ Process 1525 (smplayer) crashed and dumped core.
â–‘â–‘
â–‘â–‘ This usually indicates a programming error in the crashing program and
â–‘â–‘ should be reported to its vendor as a bug.
Mar 04 23:17:03 koboldx-z170 systemd-coredump[2516]: [🡕] Process 2509 (smplayer) of user 1000 dumped core.
Stack trace of thread 2509:
#0 0x00007f70e974e942 n/a (n/a + 0x0)
â–‘â–‘ Subject: Process 2509 (smplayer) dumped core
lines 1-28...skipping...
Module /usr/bin/smplayer with build-id aa531664ed478d9da2df96057e9f1d2e6edcc818
â–‘â–‘
â–‘â–‘
â–‘â–‘
â–‘â–‘ Process 2509 (smplayer) crashed and dumped core.
â–‘â–‘
Mar 05 03:30:31 koboldx-z170 sudo[45274]: koboldx : a password is required ; PWD=/home/koboldx ; USER=root ; COMMAND=/usr/sbin/uptime
Mar 05 04:29:02 koboldx-z170 systemd-coredump[61655]: [🡕] Process 19842 (smplayer) of user 1000 dumped core.
Stack trace of thread 19842:
#0 0x00007fbd98ae748d n/a (n/a + 0x0)
â–‘â–‘ Subject: Process 19842 (smplayer) dumped core
â–‘â–‘
â–‘â–‘ Process 19842 (smplayer) crashed and dumped core.
â–‘â–‘
Mar 05 04:29:55 koboldx-z170 systemd-coredump[61896]: [🡕] Process 61819 (smplayer) of user 1000 dumped core.
Stack trace of thread 61819:
#0 0x00007f91cb25d942 n/a (n/a + 0x0)
â–‘â–‘ Subject: Process 61819 (smplayer) dumped core
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
security=apparmor resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f
udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
RAM: total: 15.58 GiB used: 5.67 GiB (36.4%)
RAM Report:
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4500 high: 4501 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4501 2: 4499 3: 4500
4: 4500 5: 4500 6: 4500 7: 4500 8: 4500 bogomips: 64026
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (21.0x11.9")
s-diag: 613mm (24.1")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.57 TiB used: 54.74 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.72 GiB (97.87%) used: 26.49 GiB (30.5%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 189.7 MiB (94.84%)
used: 105.7 MiB (55.7%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.82 GiB (98.13%)
used: 10.86 GiB (3.3%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 17.26 GiB (27.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 21.2 MiB (0.7%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: a44dd3c4-f5f1-4587-8934-6f7413d28d4f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
uuid: AE7EDC0696B158FD
ID-2: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: System-reserviert uuid: B2286A122869D5BF
ID-3: /dev/sda2 maj-min: 8:2 size: 293.16 GiB fs: ntfs label: win10
uuid: 5E60C09860C077F3
ID-4: /dev/sda3 maj-min: 8:3 size: 515 MiB fs: ntfs label: N/A
uuid: 20E8D914E8D8E954
ID-5: /dev/sda4 maj-min: 8:4 size: 585.94 GiB fs: ntfs label: games
uuid: 165692E31D7ADAF2
ID-6: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
label: N/A uuid: N/A
ID-7: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-13:2 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-5:2 info: Samsung Portable SSD T5 type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 04e8:61f5 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 247 Uptime: 20h 56m wakeups: 6 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1371
pacman: 1365 lib: 407 flatpak: 6 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
