Hello, I have an issue with dual boot of Manjaro that controls boot to Manjaro KDE Plasma or Windows 10. I had installed Manjaro XFCE previously but decided to switch to KDE Plasma I installed Plasma on a separate SSD and have Windows 10 on a another separate SSD. I did not want or configure to dual boot, I left each OS separated. Plasma decided to install a dual boot grub which prevented Windows 10 from booting or using a recovery DVD for Windows on the PC. The PC boots into the Manjaro dual boot utility each time to choose Manjaro or Windows 10. When I boot to Windows 10, I get a boot record error and Windows 10 wants the repair utility on DVD. I have two questions for now. Did the dual boot modify the Windows boot record, and if not where is the dual boot functioning from or at? 2: How can I delete or modify the dual boot in Plasma, I have looked into this but I cannot locate the dual boot utility in Plasma.
Dual boot with windows:
How to increase your chances of solving your issue:
Please provide Information:
Plasma decides nothing during an install.
@kokanee we need to know more about your system to be able to help.
could you please let us know if your system boots with UEFI or with BIOS/Legacy
It’s important to know this as it will greatly change the advice given.
Please post the output of
inxi --admin --verbosity=7 --filter --width
I have a legacy BIOS system with an AMD four core processor on a AMD motherboard with two SSD hard drives, two GPU video cards, 8 Gigabytes RAM. I do not have UEFI gui boot.Windows 10 is installed on one hard drive and Manjaro is installed on the other hard drive. I internationally had the two OS separate, one hard drive Windows 10 and the other hard drive Linux. For this reason that is why I am questioning why Manjaro decided to implement the dual boot option. The Windows 10 has a boot error now and is requiring repair with a OS installation DVD. I am unable to boot the repair DVD due to the dual boot option installed by Manjaro. I am now in the process of attempting to add Gparted to Manjaro so I remove the MSDOS partitions for Windows 10 in the Manjaro boot partition, however this is not going well. Gparted will not install with an error message of “target not found: pangomm”. I have checked out the KDE Partition Manager however it is not intuitive or self explanatory on how to use it and its actions. I am now attempting to locate the pangomm package to allow Gparted to install. As of now I am encountering issues with locating pangomm package. Thank you andreas85 for posting the Dual boot with windows tutorial, it was a great help and informative. My goal now is to repair the Windows 10 boot error by obtaining Gparted or check out Manjaro dual boot for a method to allow booting from repair DVD. At this time i is not going well to install Gparted, help or suggestions for booting from a DVD from Manjaro dual boot would be appreciated.
@kokanee
Please follow instructions given rather than writing out a page of text.
it sounds like you have an MBR based boot setup, which means that you’ll need to install a package called “os-prober” for grub to be able to detect your windows installation and add it to your boot options.
as for not being able to boot from a windows 10 DVD, that would be down to how your BIOS is configured, that has nothing to do with manjaro
I do not want the Manjaro to dual boot as it is now. At this point I want to disable or modify the dual boot in Manjaro so I may boot the repair DVD for Windows 10. Presently I cannot boot to the repair DVD due to the dual boot option that has been enabled by Manjaro.
@kokanee
Manjaro cannot stop you from booting the windows DVD, especially if you’re booting with MBR.
You need to change the boot priority in your BIOS and set your optical drive as the first boot device
I have tried changing the the boot order in BIOS to DVD and it boots the DVD, the DVD loads and then it boots the Windows hard drive in the dual boot Manjaro option, I never see the DVD menu.
this is getting a little off topic as it’s no longer manjaro support,
however if you are able to boot into windows, you should be able to use bootrec.exe as administrator to restore the windows bootloader (and remove grub)
I cannot run that command until I am able utilize the DVD repair tool. Windows 10 will not let me in because it is in distress, it displays only the repair with DVD option. The dual boot in Manjaro overrides anything I try to boot as first choice on the PC and I end up on the Windows 10 hard drive with the repair with DVD option.
@kokanee
Please post as many screenshots as you can (take photo’s with your phone?)
I would like you to boot into manjaro so that you can post some information about your system from the command line.
If you won’t do this, then we cannot help
Ready. What screen shots?
first lets run some commands, then we’ll go back and do screenshots of the errors you’re getting when you try to boot winblows
I need the output of these commands
lsblk
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=52b9841d-2a1c-4751-8dc3-6be910d96a0b rw quiet apparmor=1
security=apparmor resume=UUID=e2a9afae-d11f-4681-ae93-817f51762251
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M4A89TD PRO USB3 v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1902
date: 02/17/2011
RAM: total: 7.76 GiB used: 795.4 MiB (10.0%)
RAM Report:
Info: model: AMD Phenom II X4 965 bits: 64 type: UP arch: K10
family: 0x10 (16) model-id: 4 stepping: 3 microcode: 0x10000C8
Topology: cpus: 1x cores: 1 smt: <unsupported> cache: L1: 128 KiB
desc: d-1x64 KiB; i-1x64 KiB L2: 512 KiB desc: 1x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): 3685 min/max: N/A core: 1: 3685 bogomips: 7371
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb
pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm
svm_lock syscall tsc vme vmmcall wdt
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Juniper PRO [Radeon HD 5750] vendor: PC Partner Limited
driver: radeon v: kernel bus-ID: 02:00.0 chip-ID: 1002:68be class-ID: 0300
Device-2: AMD Juniper PRO [Radeon HD 5750] vendor: PC Partner Limited
driver: radeon v: kernel bus-ID: 05:00.0 chip-ID: 1002:68be class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
Device-1: AMD Juniper HDMI Audio [Radeon HD 5700 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 02:00.1
chip-ID: 1002:aa58 class-ID: 0403
Device-2: AMD Juniper HDMI Audio [Radeon HD 5700 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: d800 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 585 GiB used: 10.1 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB01
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 11.8 MiB (0.0%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21 label: root
uuid: 52b9841d-2a1c-4751-8dc3-6be910d96a0b
ID-2: /boot raw-size: 8 GiB size: 7.98 GiB (99.80%) used: 66.2 MiB (0.8%)
fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: BOOT uuid: 36E2-E194
ID-3: /home raw-size: 80 GiB size: 78.19 GiB (97.74%)
used: 436.7 MiB (0.5%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22 label: home
uuid: d1a6a76a-a856-4ce8-b81a-cbc039635ca1
ID-4: /opt raw-size: 89.99 GiB size: 88.03 GiB (97.81%)
used: 1000.5 MiB (1.1%) fs: ext4 dev: /dev/sdb10 maj-min: 8:26 label: N/A
uuid: bfe98b9f-9cd3-42c6-ac7c-0daad5974dfc
ID-5: /srv raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 32 KiB (0.0%)
fs: ext4 dev: /dev/sdb8 maj-min: 8:24 label: N/A
uuid: 8f380170-67cc-4972-919b-4e2da59e586b
ID-6: /usr raw-size: 90 GiB size: 88.03 GiB (97.81%) used: 8.11 GiB (9.2%)
fs: ext4 dev: /dev/sdb9 maj-min: 8:25 label: N/A
uuid: f66d6af4-fb8e-49f6-9b9a-e9339f7d0ba8
ID-7: /var raw-size: 60 GiB size: 58.76 GiB (97.93%)
used: 592.5 MiB (1.0%) fs: ext4 dev: /dev/sdb7 maj-min: 8:23 label: N/A
uuid: 791d2d52-531c-4e6c-af2a-cd1d4f66870d
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: swap
uuid: e2a9afae-d11f-4681-ae93-817f51762251
ID-1: /dev/sda1 maj-min: 8:1 size: 106.76 GiB fs: ntfs label: DRV1_VOL1
uuid: 9D5C7F1DE18BD4FB
ID-2: /dev/sda2 maj-min: 8:2 size: 567 MiB fs: ntfs label: N/A
uuid: 8C6C7CCC6C7CB296
ID-3: /dev/sdb3 maj-min: 8:19 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Device-1: 5-1:2 info: Logitech MX700 Cordless Mouse Receiver type: Mouse
driver: hid-generic,usbhid interfSystem:
udev.log_priority=3
date: 02/17/2011
RAM Report:
desc: 1x6 MiB
Type: spectre_v2
scheme: MBR
dev-links: cdrom
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 50mA chip-ID: 046d:c506 class-ID: 0301
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-3:2 info: HP HP Wireless Keyboard Kit type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 03f0:140c class-ID: 0301
Hub-8: 8-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 9-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 33.0 C mobo: 22.0 C
Fan Speeds (RPM): cpu: 1095 psu: 681600 case-1: 1397 case-2: 1424
GPU: device: radeon temp: 39.0 C devSystem:
udev.log_priority=3
date: 02/17/2011
RAM Report:
desc: 1x6 MiB
Type: spectre_v2
scheme: MBR
dev-links: cdrom
chip-ID: 1d6b:00System:
udev.log_priority=3
date: 02/17/2011
RAM Report:
desc: 1x6 MiB
Type: spectre_v2
scheme: MBR
dev-links: cdrom
GPU: device: radeon temp: 39.0 C device: radeon temp: 31.0 C
Power: 12v: 12.11 5v: N/A 3.3v: 3.38 vbat: N/A
Processes: 162 Uptime: 11m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1207 lib: 332
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
01 class-ID: 0900
inxi: 3.3.12
inxi: 3.3.12
inxi: 3.3.12
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 119.2G 0 disk
├─sda1 8:1 0 106.8G 0 part
└─sda2 8:2 0 567M 0 part
sdb 8:16 0 465.8G 0 disk
├─sdb1 8:17 0 8G 0 part /boot
├─sdb2 8:18 0 8G 0 part [SWAP]
├─sdb3 8:19 0 1K 0 part
├─sdb5 8:21 0 60G 0 part /
├─sdb6 8:22 0 80G 0 part /home
├─sdb7 8:23 0 60G 0 part /var
├─sdb8 8:24 0 60G 0 part /srv
├─sdb9 8:25 0 90G 0 part /usr
└─sdb10 8:26 0 90G 0 part /opt
sdc 8:32 1 14.4G 0 disk
└─sdc1 8:33 1 14.4G 0 part /run/media/kokanee/MUSHKIN
sr0 11:0 1 4G 0 rom
@kokanee now that I have a better idea of how your system is laid out, can you please also post the output of
sudo fdisk -l /dev/sda
sudo fdisk -l /dev/sdb
This will show me which partition is marked as the boot partition.
Disk /dev/sda: 119.24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: Samsung SSD 850
Disklabel type: dos
Disk identifier: 0x972c562e
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 223899412 223897365 106.8G 7 HPFS/NTFS/exFAT
/dev/sda2 223899648 225060863 1161216 567M 27 Hidden NTFS WinRE
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: WDC WDS500G2B0A
Disklabel type: dos
Disk identifier: 0xfef66a2f
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectorsDisk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
/dev/sdb1 * 2048 16779263 16777216 8G c W95 FAT32 (LBA)
/dev/sdb2 16779264 33556479 16777216 8G 82 Linux swap / SolarisDisk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
/dev/sdb3 33556480 956303359 922746880 440G 5 Extended
/dev/sdb5 33558528 159387647 125829120 60G 83 Linux
/dev/sdb6 159389696 327161855 167772160 80G 83 Linux
/dev/sdb7 327163904 452993023 125829120 60G 83 Linux
/dev/sdb8 452995072 578824191 125829120 60G 83 Linux
/dev/sdb9 578826240 767569919 188743680 90G 83 Linux
/dev/sdb10 767571968 956303359 188731392 90G 83 Linu
Disklabel type: dos
ok…
I’m going to put a massive warning here.
THESE NEXT STEPS MAY RESULT IN NO BOOTABLE OPERATING SYSTEM, I TAKE NO LIABILITY IF YOU CANNOT ACCESS MANJARO OR WINDOWS
the next thing we’re going to do, and only if you’re sure you want to do it, is to disable the bootloader for manjaro, this should hopefully result in your BIOS defaulting to your windows bootloader.
Your windows install looks like it should just boot if manjaro is out of the way, but see my warning above.
run the below command
sudo fdisk /dev/sdb
then press the following keys
x a 1 w q
The other way of doing this, is to set the boot priority correctly in your BIOS
Well, to tell you the truth, I have set the boot priority correctly in BIOS on previous attempts as well every other way I could think of in order to get it to function. Thank you. I been fighting this issue for 3 days now so if I can get Manjaro out of the way I am confident I can repair Windows if it is still distressed. I can always reinstall Manjaro if it is necessary. Thank you for the outstanding help!
