Hey, thanks so much for your reply. I updated bios and removed pipewire. Also updated kernel to 5.14, no luck.
Pulseaudio --dump-conf confirms it is using the correct config in my user config folder:
(note i’ve tried avoid-resampling true and false, doesn’t seem to matter; I’ve had sound working either way)
but the audio is still muted sometimes despite the RUNNING state. Any suggestions to further look into this CORKED state? Sometimes it seems touching volume adjustments puts me in the soundless state, sometimes volume adjustment works as expected.
I will try and get it in a working state, and check sink-input again to see what the corked state is.
edit: Ok when working, flags/state is as above, START_CORKED and RUNNING. Since amixer -D pulse sset Master toggle
is key to getting it working, along with turning the dac on/off and reselecting the output device, is there any logs I can check while the sound is working to see what is the key change? I don’t really understand what the sset Master toggle is doing.
Another discovery: if I run alsamixer, the ‘item’ is listed as Master. Adjusting the volume affects the output sound volume. Muting it breaks the audio (ie unmute says it unmutes, but no sound comes from the speakers). If I run alsamixer -c 1 (which is the DAC), adjusting the volume does nothing, but muting also breaks sound. Muting did not seem to set either state to CORKED now, but still the issue persists. I can reliably fix it now by making sure when I run amixer -D pulse sset Master toggle, the output includes ON not OFF, then turn off/on dac, reslect output as it reverts to HDMI output, and play. Boom it works. I just need to get that to happen always.
pulseaudio -v
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: [pulseaudio] core-util.c: Failed to acquire high-priority scheduling: Permission denied
I: [pulseaudio] main.c: This is PulseAudio 15.0
I: [pulseaudio] main.c: Page size is 4096 bytes
I: [pulseaudio] main.c: Machine ID is c714d2e0b0514640b9d86741821e3540.
I: [pulseaudio] main.c: Session ID is 3.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/ben/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-15.0/modules.
I: [pulseaudio] main.c: Running in system mode: no
I: [pulseaudio] main.c: System supports high resolution timers
I: [pulseaudio] cpu-x86.c: CPU flags: CMOV MMX SSE SSE2 SSE3 SSSE3 SSE4_1 SSE4_2
I: [pulseaudio] svolume_mmx.c: Initialising MMX optimized volume functions.
I: [pulseaudio] remap_mmx.c: Initialising MMX optimized remappers.
I: [pulseaudio] svolume_sse.c: Initialising SSE2 optimized volume functions.
I: [pulseaudio] remap_sse.c: Initialising SSE2 optimized remappers.
I: [pulseaudio] sconv_sse.c: Initialising SSE2 optimized conversions.
I: [pulseaudio] svolume_orc.c: Initialising ORC optimized volume functions.
I: [pulseaudio] database.c: Successfully opened 'device-volumes' database file '/home/ben/.config/pulse/c714d2e0b0514640b9d86741821e3540-device-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-device-restore" (index: #0; argument: "").
I: [pulseaudio] database.c: Successfully opened 'stream-volumes' database file '/home/ben/.config/pulse/c714d2e0b0514640b9d86741821e3540-stream-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-stream-restore" (index: #1; argument: "").
I: [pulseaudio] database.c: Successfully opened 'card-database' database file '/home/ben/.config/pulse/c714d2e0b0514640b9d86741821e3540-card-database.tdb'.
I: [pulseaudio] module.c: Loaded "module-card-restore" (index: #2; argument: "").
I: [pulseaudio] module.c: Loaded "module-augment-properties" (index: #3; argument: "").
I: [pulseaudio] module.c: Loaded "module-switch-on-port-available" (index: #4; argument: "").
I: [pulseaudio] (alsa-lib)parser.c: UCM is not supported for this HDA model (HDA ATI HDMI at 0xfbe60000 irq 46)
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:0 use case configuration -6
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HDA ATI HDMI use case configuration -6
I: [pulseaudio] alsa-ucm.c: UCM not available for card HDA ATI HDMI
I: [pulseaudio] alsa-util.c: Error opening PCM device front:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround40:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround51:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:0: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:0
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:0: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-0.conf
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0,1 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-1.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,1: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0,2 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-2.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,2: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0,3 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-3.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,3: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0,4 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-4.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,4: No such file or directory
I: [pulseaudio] alsa-util.c: Device hdmi:0,5 doesn't support sample format s24le, changed to s32le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-5.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,5: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,10: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hw:0: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_03_00.1.
I: [pulseaudio] card.c: alsa_card.pci-0000_03_00.1: active_profile: off
I: [pulseaudio] module-card-restore.c: Profile '' was previously automatically selected for card alsa_card.pci-0000_03_00.1.
I: [pulseaudio] card.c: Created 0 "alsa_card.pci-0000_03_00.1"
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-0 (3).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-1 (7).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-2 (8).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-3 (9).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-4 (10).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-5 (11).
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #6; argument: "device_id="0" name="pci-0000_03_00.1" card_name="alsa_card.pci-0000_03_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:02.0/0000:03:00.1/sound/card0 (alsa_card.pci-0000_03_00.1) module loaded.
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:1 use case configuration -2
I: [pulseaudio] (alsa-lib)main.c: error: failed to import ARC AMP DAC use case configuration -2
I: [pulseaudio] alsa-ucm.c: UCM not available for card ARC AMP DAC
I: [pulseaudio] alsa-util.c: Device front:1 doesn't support sample format s24le, changed to s16le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:1'
I: [pulseaudio] alsa-util.c: Device iec958:1 doesn't support sample format s24le, changed to s16le.
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-input.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf
I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround21:1': Invalid argument
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround40:1': Invalid argument
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround41:1': Invalid argument
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround50:1': Invalid argument
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround51:1': Invalid argument
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:SLAVE='surround71:1': Invalid argument
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-output.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:1
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:1: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.0:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)conf.c: function snd_func_refer returned error: No such file or directory
I: [pulseaudio] (alsa-lib)conf.c: Evaluate error: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.1:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,1: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.2:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,2: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.3:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,3: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,3: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.4:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,4: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,4: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.5:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,5: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,5: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.6:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,6: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.7:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,7: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.8:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,8
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,8: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.9:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,9
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,9: No such file or directory
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.1.pcm.hdmi.10:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,10
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,10: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.
I: [pulseaudio] card.c: alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00: active_profile: output:analog-stereo+input:analog-stereo
I: [pulseaudio] module-card-restore.c: Profile '' was previously automatically selected for card alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.
I: [pulseaudio] card.c: Created 1 "alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00"
I: [pulseaudio] alsa-util.c: Cannot disable ALSA period wakeups
I: [pulseaudio] alsa-util.c: ALSA period wakeups were not disabled
I: [pulseaudio] alsa-sink.c: Successfully opened device front:1.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Analog Stereo' (analog-stereo).
I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] sink.c: Created sink 0 "alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo" with sample spec s24le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: alsa.resolution_bits = "24"
I: [pulseaudio] sink.c: device.api = "alsa"
I: [pulseaudio] sink.c: device.class = "sound"
I: [pulseaudio] sink.c: alsa.class = "generic"
I: [pulseaudio] sink.c: alsa.subclass = "generic-mix"
I: [pulseaudio] sink.c: alsa.name = "USB Audio"
I: [pulseaudio] sink.c: alsa.id = "USB Audio"
I: [pulseaudio] sink.c: alsa.subdevice = "0"
I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] sink.c: alsa.device = "0"
I: [pulseaudio] sink.c: alsa.card = "1"
I: [pulseaudio] sink.c: alsa.card_name = "ARC AMP DAC"
I: [pulseaudio] sink.c: alsa.long_card_name = "Mayflower Electronics ARC AMP DAC ARC AMP DAC at usb-0000:00:1d.0-1.8, full spe"
I: [pulseaudio] sink.c: alsa.driver_name = "snd_usb_audio"
I: [pulseaudio] sink.c: device.bus_path = "pci-0000:00:1d.0-usb-0:1.8:1.0"
I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/sound/card1"
I: [pulseaudio] sink.c: udev.id = "usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00"
I: [pulseaudio] sink.c: device.bus = "usb"
I: [pulseaudio] sink.c: device.vendor.id = "0493"
I: [pulseaudio] sink.c: device.vendor.name = "MAG Technology Co., Ltd"
I: [pulseaudio] sink.c: device.product.id = "4170"
I: [pulseaudio] sink.c: device.product.name = "ARC AMP DAC"
I: [pulseaudio] sink.c: device.serial = "Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF"
I: [pulseaudio] sink.c: device.string = "front:1"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "576000"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "288000"
I: [pulseaudio] sink.c: device.access_mode = "mmap+timer"
I: [pulseaudio] sink.c: device.profile.name = "analog-stereo"
I: [pulseaudio] sink.c: device.profile.description = "Analog Stereo"
I: [pulseaudio] sink.c: device.description = "ARC AMP DAC Analog Stereo"
I: [pulseaudio] sink.c: module-udev-detect.discovered = "1"
I: [pulseaudio] sink.c: device.icon_name = "audio-card-usb"
I: [pulseaudio] source.c: Created source 0 "alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo.monitor" with sample spec s24le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of ARC AMP DAC Analog Stereo"
I: [pulseaudio] source.c: device.class = "monitor"
I: [pulseaudio] source.c: alsa.card = "1"
I: [pulseaudio] source.c: alsa.card_name = "ARC AMP DAC"
I: [pulseaudio] source.c: alsa.long_card_name = "Mayflower Electronics ARC AMP DAC ARC AMP DAC at usb-0000:00:1d.0-1.8, full spe"
I: [pulseaudio] source.c: alsa.driver_name = "snd_usb_audio"
I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:1d.0-usb-0:1.8:1.0"
I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/sound/card1"
I: [pulseaudio] source.c: udev.id = "usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00"
I: [pulseaudio] source.c: device.bus = "usb"
I: [pulseaudio] source.c: device.vendor.id = "0493"
I: [pulseaudio] source.c: device.vendor.name = "MAG Technology Co., Ltd"
I: [pulseaudio] source.c: device.product.id = "4170"
I: [pulseaudio] source.c: device.product.name = "ARC AMP DAC"
I: [pulseaudio] source.c: device.serial = "Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF"
I: [pulseaudio] source.c: device.string = "1"
I: [pulseaudio] source.c: module-udev-detect.discovered = "1"
I: [pulseaudio] source.c: device.icon_name = "audio-card-usb"
I: [pulseaudio] alsa-sink.c: Using 2.0 fragments of size 288000 bytes (1000.00ms), buffer size is 576000 bytes (2000.00ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20.00ms
I: [pulseaudio] alsa-sink.c: Successfully enabled deferred volume.
I: [pulseaudio] alsa-sink.c: Hardware volume ranges from -25.00 dB to 6.00 dB.
I: [pulseaudio] alsa-sink.c: Fixing base volume to -6.00 dB
I: [pulseaudio] alsa-sink.c: Using hardware volume control. Hardware dB scale supported.
I: [pulseaudio] alsa-sink.c: Using hardware mute control.
I: [alsa-sink-USB Audio] util.c: Failed to acquire real-time scheduling: Permission denied
I: [alsa-sink-USB Audio] alsa-sink.c: Starting playback.
I: [pulseaudio] core.c: default_source: (unset) -> alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo.monitor
I: [pulseaudio] core.c: default_sink: (unset) -> alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo
I: [pulseaudio] alsa-source.c: Successfully opened device front:1.
I: [pulseaudio] alsa-source.c: Selected mapping 'Analog Stereo' (analog-stereo).
I: [pulseaudio] alsa-source.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-source.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] source.c: Created source 1 "alsa_input.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo" with sample spec s16le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] source.c: alsa.resolution_bits = "16"
I: [pulseaudio] source.c: device.api = "alsa"
I: [pulseaudio] source.c: device.class = "sound"
I: [pulseaudio] source.c: alsa.class = "generic"
I: [pulseaudio] source.c: alsa.subclass = "generic-mix"
I: [pulseaudio] source.c: alsa.name = "USB Audio"
I: [pulseaudio] source.c: alsa.id = "USB Audio"
I: [pulseaudio] source.c: alsa.subdevice = "0"
I: [pulseaudio] source.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] source.c: alsa.device = "0"
I: [pulseaudio] source.c: device.string = "front:1"
I: [pulseaudio] source.c: device.buffering.buffer_size = "384000"
I: [pulseaudio] source.c: device.buffering.fragment_size = "192000"
I: [pulseaudio] source.c: device.access_mode = "mmap+timer"
I: [pulseaudio] source.c: device.profile.name = "analog-stereo"
I: [pulseaudio] source.c: device.profile.description = "Analog Stereo"
I: [pulseaudio] source.c: device.description = "ARC AMP DAC Analog Stereo"
I: [pulseaudio] alsa-source.c: Using 2.0 fragments of size 192000 bytes (1000.00ms), buffer size is 384000 bytes (2000.00ms)
I: [pulseaudio] alsa-source.c: Time scheduling watermark is 30.00ms
I: [pulseaudio] alsa-source.c: Successfully enabled deferred volume.
I: [pulseaudio] alsa-source.c: Hardware volume ranges from -32.00 dB to 32.00 dB.
I: [pulseaudio] alsa-source.c: Fixing base volume to -32.00 dB
I: [pulseaudio] alsa-source.c: Using hardware volume control. Hardware dB scale supported.
I: [pulseaudio] alsa-source.c: Using hardware mute control.
I: [alsa-source-USB Audio] util.c: Failed to acquire real-time scheduling: Permission denied
I: [alsa-source-USB Audio] alsa-source.c: Starting capture.
I: [pulseaudio] core.c: default_source: alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo.monitor -> alsa_input.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #7; argument: "device_id="1" name="usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00" card_name="alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/sound/card1 (alsa_card.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00) module loaded.
I: [pulseaudio] module-udev-detect.c: Found 2 cards.
I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: "").
I: [pulseaudio] module.c: Loaded "module-jackdbus-detect" (index: #8; argument: "channels=2").
I: [pulseaudio] module.c: Loaded "module-bluetooth-policy" (index: #9; argument: "").
I: [pulseaudio] module.c: Loaded "module-bluez5-discover" (index: #11; argument: "").
I: [pulseaudio] module.c: Loaded "module-bluetooth-discover" (index: #10; argument: "").
I: [pulseaudio] module.c: Loaded "module-dbus-protocol" (index: #12; argument: "").
I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #13; argument: "").
I: [pulseaudio] module.c: Loaded "module-gsettings" (index: #14; argument: "").
I: [pulseaudio] module-default-device-restore.c: Restoring default sink 'alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo'.
I: [pulseaudio] core.c: configured_default_sink: (unset) -> alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo
I: [pulseaudio] module-default-device-restore.c: Restoring default source 'alsa_input.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo'.
I: [pulseaudio] core.c: configured_default_source: (unset) -> alsa_input.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo
I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #15; argument: "").
I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #16; argument: "").
I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #17; argument: "").
I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #18; argument: "").
I: [pulseaudio] module.c: Loaded "module-console-kit" (index: #19; argument: "").
I: [pulseaudio] client.c: Created 0 "Login Session 3"
I: [pulseaudio] core.c: exit_idle_time: 20 -> 0
I: [pulseaudio] client.c: Created 1 "Login Session 1"
I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #20; argument: "").
I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #21; argument: "").
I: [pulseaudio] module.c: Loaded "module-role-cork" (index: #22; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #23; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #24; argument: "").
W: [pulseaudio] cli-command.c: stat('/etc/pulse/default.pa.d'): No such file or directory
I: [pulseaudio] main.c: Daemon startup complete.
I: [pulseaudio] client.c: Created 2 "Native client (UNIX socket client)"
I: [pulseaudio] protocol-native.c: Got credentials: uid=1000 gid=1000 success=1
I: [pulseaudio] source-output.c: Trying to change sample spec
I: [alsa-sink-USB Audio] alsa-sink.c: Device suspended...
I: [pulseaudio] alsa-sink.c: Sink does not support sample format of float32le, set it to a verified value
I: [pulseaudio] source.c: Reconfigured successfully
I: [pulseaudio] sink.c: Reconfigured successfully
I: [alsa-sink-USB Audio] alsa-sink.c: Trying resume...
I: [alsa-sink-USB Audio] alsa-util.c: Cannot disable ALSA period wakeups
I: [alsa-sink-USB Audio] alsa-util.c: ALSA period wakeups were not disabled
I: [alsa-sink-USB Audio] alsa-sink.c: Time scheduling watermark is 20.00ms
I: [alsa-sink-USB Audio] alsa-sink.c: Resumed successfully...
I: [pulseaudio] remap.c: Using stereo to mono remapping
I: [pulseaudio] source-output.c: Created output 0 "Peak detect" on alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo.monitor with sample spec float32le 1ch 25Hz and channel map mono
I: [pulseaudio] source-output.c: media.name = "Peak detect"
I: [pulseaudio] source-output.c: application.name = "PulseAudio Volume Control"
I: [pulseaudio] source-output.c: native-protocol.peer = "UNIX socket client"
I: [pulseaudio] source-output.c: native-protocol.version = "35"
I: [pulseaudio] source-output.c: application.id = "org.PulseAudio.pavucontrol"
I: [pulseaudio] source-output.c: application.icon_name = "audio-card"
I: [pulseaudio] source-output.c: application.version = "5.0"
I: [pulseaudio] source-output.c: application.process.id = "2628"
I: [pulseaudio] source-output.c: application.process.user = "ben"
I: [pulseaudio] source-output.c: application.process.host = "Hex"
I: [pulseaudio] source-output.c: application.process.binary = "pavucontrol"
I: [pulseaudio] source-output.c: application.language = "en_US.utf8"
I: [pulseaudio] source-output.c: window.x11.display = ":0.0"
I: [pulseaudio] source-output.c: application.process.machine_id = "c714d2e0b0514640b9d86741821e3540"
I: [pulseaudio] source-output.c: application.process.session_id = "1"
I: [pulseaudio] source-output.c: module-stream-restore.id = "source-output-by-application-id:org.PulseAudio.pavucontrol"
I: [pulseaudio] protocol-native.c: Final latency 80.00 ms = 40.00 ms + 40.00 ms
I: [alsa-source-USB Audio] alsa-source.c: Device suspended...
I: [pulseaudio] alsa-source.c: Source does not support sample format of float32le, set it to a verified value
I: [alsa-source-USB Audio] alsa-source.c: Trying resume...
I: [alsa-source-USB Audio] alsa-util.c: Cannot disable ALSA period wakeups
I: [alsa-source-USB Audio] alsa-util.c: ALSA period wakeups were not disabled
I: [alsa-source-USB Audio] alsa-source.c: Time scheduling watermark is 30.00ms
I: [alsa-source-USB Audio] alsa-source.c: Resumed successfully...
I: [pulseaudio] source-output.c: Created output 1 "Peak detect" on alsa_input.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo with sample spec float32le 1ch 25Hz and channel map mono
I: [pulseaudio] client.c: Created 3 "Native client (UNIX socket client)"
I: [pulseaudio] sink-input.c: Trying to change sample spec
I: [pulseaudio] sink.c: Cannot update sample spec, monitor source is RUNNING
I: [pulseaudio] module-stream-restore.c: Restoring volume for sink input sink-input-by-application-name:Firefox.
I: [pulseaudio] resampler.c: Forcing resampler 'copy', because of fixed, identical sample rates.
I: [pulseaudio] sink-input.c: Created input 0 "AudioStream" on alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo with sample spec float32le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] sink-input.c: media.name = "AudioStream"
I: [pulseaudio] sink-input.c: application.name = "Firefox"
I: [pulseaudio] sink-input.c: native-protocol.peer = "UNIX socket client"
I: [pulseaudio] sink-input.c: native-protocol.version = "35"
I: [pulseaudio] sink-input.c: application.process.id = "2008"
I: [pulseaudio] sink-input.c: application.process.user = "ben"
I: [pulseaudio] sink-input.c: application.process.host = "Hex"
I: [pulseaudio] sink-input.c: application.process.binary = "firefox"
I: [pulseaudio] sink-input.c: application.language = "en_US.utf8"
I: [pulseaudio] sink-input.c: window.x11.display = ":0.0"
I: [pulseaudio] sink-input.c: application.process.machine_id = "c714d2e0b0514640b9d86741821e3540"
I: [pulseaudio] sink-input.c: application.process.session_id = "1"
I: [pulseaudio] sink-input.c: application.icon_name = "firefox"
I: [pulseaudio] sink-input.c: module-stream-restore.id = "sink-input-by-application-name:Firefox"
I: [pulseaudio] protocol-native.c: Requested tlength=200.00 ms, minreq=25.00 ms
I: [pulseaudio] protocol-native.c: Final latency 200.00 ms = 75.00 ms + 2*25.00 ms + 75.00 ms
I: [pulseaudio] source.c: Cannot update sample spec, SOURCE_IS_RUNNING, will keep using s24le and 48000 Hz
I: [pulseaudio] source-output.c: Created output 2 "Peak detect" on alsa_output.usb-Mayflower_Electronics_ARC_AMP_DAC_ARC_AMP_DAC_FFFFFFFEFFFF-00.analog-stereo.monitor with sample spec float32le 1ch 25Hz and channel map mono
I: [pulseaudio] client.c: Created 4 "Native client (UNIX socket client)"
I: [pulseaudio] module-stream-restore.c: Storing volume/mute for stream sink-input-by-application-name:Firefox.
I: [pulseaudio] module-stream-restore.c: Synced.
E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
I’m using a bluetooth keyboard that works fine, not sure if the bluez error at the end there is relevant
