[Testing Update] 2019-04-29 - mostly kernels
update
testing
#1
Same as Unstable Update 2019-04-29
[Unstable Update] 2019-04-29 - mostly kernels
#2
Hi community,
I have now rebuilt new point releases for all our kernels (except 4.20).
Apart from that of course also some other updated packages have arrived as usual.
Afaik nothing particularly exciting to report in that area ... so far :wink:
Detailed list of updated packages can be found here
Current supported Kernels
  • linux316 3.16.65
  • linux318 3.18.139 [EOL]
  • linux44 4.4.179 - ! see here !
  • linux49 4.9.171
  • linux414 4.14.114
  • linux419 4.19.37
  • linux420 4.20.17
  • linux50 5.0.10
  • linux51rc 5.1rc1.d0317.g9e98c67 (experimental. no extramodules, yet)
  • linux419-rt 4.19.31_rt18
  • linux50-rt 5.0.5_rt3
0 voters
#3
@oberon, we should forward this this to testing as some people claim of broken kernel in Stable.
#4
Are you referring to this? I'd have considered this an individual problem on a specific install, especially since the issue happened with two different kernels - likely an abortion while post transaction hook was running.
But sure, we can test all this in testing. It's just kernels, anyway and maybe good to forward the bundle before more upstream packages arrive :wink:
#5
I concur with your view about this kernel issue but sure I'll test the new kernels released today. I didn't experience any breakage across two completely different hardware configurations so aren't expecting to find any difference with these. I'll let you know anyway :man_shrugging:
EDIT - I tried both linux50 and linux419. No panics with either so it does look machine/pebkac specific
so far so good
uname -a
Linux 5.0.9-2-MANJARO #1 SMP PREEMPT Sun Apr 21 07:11:08 UTC 2019 x86_64 GNU/Linux
journalctl -p 3
Apr 29 15:50:42  kernel: nouveau 0000:08:00.0: bios: OOB 1 d7500086 d7500086
Apr 29 15:51:10  colord-sane[516]: io/hpmud/pp.c 627: unable to read device-id ret=-1
#7
that's not the current kernel from this set of updates:
uname -mrs
Linux 5.0.10-2-MANJARO x86_64
#8
there were a lot of lib32 Packages...
i'll have to wait..
did just..
sudo pacman -Syyu
[sudo] Passwort für user:
:: Synchronisiere Paketdatenbanken...
 core                     149,4 KiB  1607K/s 00:00 [######################] 100%
 extra                   1812,0 KiB  1252K/s 00:01 [######################] 100%
 community                  5,2 MiB  1230K/s 00:04 [######################] 100%
 multilib                 184,1 KiB  1574K/s 00:00 [######################] 100%
:: Starte vollständige Systemaktualisierung...
 Es gibt nichts zu tun / nothing to do..
#9
Check the mirrors you use on repo.manjaro.org, they don't appear to be synchronised yet then and try again later at some point but if you don't get the panic either then it's further indication there was nothing wrong with the packages released yesterday to Stable
#10
Ahh you mean Last Sync of Generated on 2019-04-24 10:03
should be like 2019-04-29 17:46 ..
Edit: Funny just at this moment...
#11
No problemo
#12
no, he means that you probably use one of the red or yellow lined mirrors, that have not yet synced with the recent update from the master server.
Try sudo pacman-mirrors -f5 to make sure that you use an updated mirror.
#13
Ahh ok, i thought this command would mess up my server countries, which i've set. But it did not. It took the fastest of my preset country,
update is rolling
Pakete (10) linux414-4.14.114-1  linux419-4.19.37-1  linux50-5.0.10-2
            llvm-libs-8.0.0-2  perl-alien-build-1.69-1
            perl-ffi-checklib-0.24-1  python-psutil-5.6.2-1  qpdf-8.4.1-1
            unrar-1:5.7.5-1  vulkan-icd-loader-1.1.107-1
thanx
#14
so far so good 2.0 (-;
uname -a
Linux 5.0.10-2-MANJARO #1 SMP PREEMPT Sat Apr 27 11:22:26 UTC 2019 x86_64 GNU/Linux
journalctl - p 3
Apr 29 18:29:18  kernel: nouveau 0000:08:00.0: bios: OOB 1 d7500086 d7500086
Apr 29 18:29:46  colord-sane[469]: io/hpmud/pp.c 627: unable to read device-id ret=-1
#15
question:
xfwm4 --version
This is xfwm4 version 4.13.1git.UNKNOWN (revision UNKNOWN) for Xfce 4.13
Released under the terms of the GNU General Public License.
Compiled against GTK+-3.24.5, using GTK+-3.24.8.
inxi -Fxzc0
System: Host: Kernel: 5.0.10-2-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Xfce 4.13.3git-UNKNOWN
Distro: Manjaro Linux
#16
Can you please update linux51? It is still on rc1.
#17
All good.:+1:
Host: xxx-pc Kernel: 5.0.10-2-MANJARO x86_64 bits: 64
compiler: gcc v: 8.3.0 Desktop: LXQt 0.14.1
Thanks!
#18
all fine on both machines
#19
Update good...I'm still seeing a small issue related to scroll bars in context menus, but this is already been reported to gnome upstream (some weird activity on that bug being closed/reopened :confused:)
I've also got a question for @oberon or @philm, since we're about a month away from gtk3-classic (link) being without a maintainer, what's the roadmap look like for this item? Are we eventually going to have to switch over to gtk3 proper and deal with styling efforts and gtk3 fixes ourselves?
#20
Maybe little out of place, not sure where else to ask this, but any idea on ETA of Kernel 5.1 stable release?
I'm really waiting for this one getting out of experimental phase, as it claims to have full RME Fireface UCX support finally :upside_down_face:
