[Testing Update] 2018-12-02 - Kernels, Pamac, Thunderbird, Texlive
update
testing
#21
Is anyone noticing any issues with Western European update servers… Trying to install 4.14 kernel is timing out and sudo pacman -Syyuu is taking forever.
error: failed retrieving file ‘linux414-4.14.83-1-x86_64.pkg.tar.xz’ from manjaro.chocomint.co : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds.
This is on 1Gig FTTH connection. Speedtest giving me 700Mbps.
#22
Each mirror is independently run as far as I know. pacman-mirrors is your friend.
#23
Thanks for that, I recently reinstalled and forgot to update them to reflect my location… All done now, and speed is back to normal. Thanks again.:+1:
#24
Why
-Syyuu
sudo pacman -Syu
is the correct command!
From the man page:
pacman -Syu
Update package list and upgrade all packages afterwards.
#25
yy forces refresh, useful after mirror change…
#26
…and afaik uu forces downgrades (?)
#27
BTW, ever since I made a separate unencrypted /boot partition about 2 weeks ago, sudo update-grub ends with the following:
/usr/bin/grub-probe: warning: unknown device type nvme0n1
This does not irritate me much as my main loader is rEFInd, but anyway…
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --recheck
made Grub work but this warning still persist. And btw in Ubuntu I have nvme module (according to lsmod |grep nv), but in Manjaro the output of this command is empty. Is that OK?
#28
My bad, should have issued -Syyu
#29
#30
Edit: Problem was caused by old gtk3 3.22. Installed gtk3-classic and it fixed.
#31
All good on my X61, updated for the first time since November 2017 (was running kernel 4.14.0). 2200 updated packages, 8GB total, removed some obsolete packages -> no issues.
#32
I so can’t wait for that…that is right in the price range I am wanting to spend on my next laptop and for it to be built for Manjaro kde is the icing on the cake.
#33
Hi everyone,
Slight problem here, last testing update (or maybe the one before that since I did both at once) broke my wifi.
I’m going to try to start up on kernel 4.14.85 to see if it comes from there, but it’s the most likely culprit unless I missed something in the update.
My wifi card is an Intel Wireles 8260 set up in a Dell XPS 9570 (I replaced the killer card, that I still have, so I can also try to set it up in my computer to see if it works with that if needed).
Link appears down, and when I try to set it up:
~ >>> sudo ip link set wlp59s0 up        [1]
RTNETLINK answers: Input/output error
~ >>> sudo ip link set wlp59s0 up        [2]
Cannot find device "wlp59s0"
Anyone experienced something similar? How can I provide more information for debugging?
EDIT:
I looked down in dmesg and found bleeding messages about iwlwifi crashing:
[ 1786.844327] iwlwifi 0000:3b:00.0: loaded firmware version 36.7596afd4.0 op_mode iwlmvm
[ 1786.844367] iwlwifi 0000:3b:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x208
[ 1786.920137] iwlwifi 0000:3b:00.0: base HW address: f0:d5:bf:b2:0d:e5
[ 1786.994297] ieee80211 phy1285: Selected rate control algorithm 'iwl-mvm-rs'
[ 1787.002936] iwlwifi 0000:3b:00.0 wlp59s0: renamed from wlan0
[ 1787.038913] IPv6: ADDRCONF(NETDEV_UP): wlp59s0: link is not ready
[ 1787.282558] iwlwifi 0000:3b:00.0: FW Error notification: type 0x00000000 cmd_id 0x05
[ 1787.282561] iwlwifi 0000:3b:00.0: FW Error notification: seq 0x0023 service 0x00000005
[ 1787.282562] iwlwifi 0000:3b:00.0: FW Error notification: timestamp 0x            802A
[ 1787.282566] iwlwifi 0000:3b:00.0: Microcode SW error detected.  Restarting 0x2000000.
[ 1787.282734] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1787.282735] iwlwifi 0000:3b:00.0: Status: 0x00000100, count: 6
[ 1787.282736] iwlwifi 0000:3b:00.0: Loaded firmware version: 36.7596afd4.0
[ 1787.282738] iwlwifi 0000:3b:00.0: 0x00000038 | BAD_COMMAND
[ 1787.282739] iwlwifi 0000:3b:00.0: 0x00A002F1 | trm_hw_status0
[ 1787.282740] iwlwifi 0000:3b:00.0: 0x00000000 | trm_hw_status1
[ 1787.282741] iwlwifi 0000:3b:00.0: 0x000241F4 | branchlink2
[ 1787.282742] iwlwifi 0000:3b:00.0: 0x000397EE | interruptlink1
[ 1787.282743] iwlwifi 0000:3b:00.0: 0x00000000 | interruptlink2
[ 1787.282744] iwlwifi 0000:3b:00.0: 0x00230405 | data1
[ 1787.282745] iwlwifi 0000:3b:00.0: 0x00000024 | data2
[ 1787.282746] iwlwifi 0000:3b:00.0: 0x00000024 | data3
[ 1787.282747] iwlwifi 0000:3b:00.0: 0x00000000 | beacon time
[ 1787.282748] iwlwifi 0000:3b:00.0: 0x0000802E | tsf low
[ 1787.282749] iwlwifi 0000:3b:00.0: 0x00000000 | tsf hi
[ 1787.282750] iwlwifi 0000:3b:00.0: 0x00000000 | time gp1
[ 1787.282751] iwlwifi 0000:3b:00.0: 0x0000802F | time gp2
[ 1787.282752] iwlwifi 0000:3b:00.0: 0x00000001 | uCode revision type
[ 1787.282753] iwlwifi 0000:3b:00.0: 0x00000024 | uCode version major
[ 1787.282755] iwlwifi 0000:3b:00.0: 0x7596AFD4 | uCode version minor
[ 1787.282756] iwlwifi 0000:3b:00.0: 0x00000201 | hw version
[ 1787.282757] iwlwifi 0000:3b:00.0: 0x18489008 | board version
[ 1787.282758] iwlwifi 0000:3b:00.0: 0x00230405 | hcmd
[ 1787.282759] iwlwifi 0000:3b:00.0: 0x00122080 | isr0
[ 1787.282760] iwlwifi 0000:3b:00.0: 0x00000000 | isr1
[ 1787.282761] iwlwifi 0000:3b:00.0: 0x28201802 | isr2
[ 1787.282762] iwlwifi 0000:3b:00.0: 0x004000C0 | isr3
[ 1787.282763] iwlwifi 0000:3b:00.0: 0x00000000 | isr4
[ 1787.282764] iwlwifi 0000:3b:00.0: 0x0022019F | last cmd Id
[ 1787.282765] iwlwifi 0000:3b:00.0: 0x00000000 | wait_event
[ 1787.282766] iwlwifi 0000:3b:00.0: 0x00005FBC | l2p_control
[ 1787.282767] iwlwifi 0000:3b:00.0: 0x00000820 | l2p_duration
[ 1787.282768] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_mhvalid
[ 1787.282769] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_addr_match
[ 1787.282770] iwlwifi 0000:3b:00.0: 0x0000000D | lmpm_pmg_sel
[ 1787.282771] iwlwifi 0000:3b:00.0: 0x22040707 | timestamp
[ 1787.282772] iwlwifi 0000:3b:00.0: 0x00001830 | flow_handler
[ 1787.282857] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1787.282859] iwlwifi 0000:3b:00.0: Status: 0x00000100, count: 7
[ 1787.282860] iwlwifi 0000:3b:00.0: 0x00000070 | ADVANCED_SYSASSERT
[ 1787.282861] iwlwifi 0000:3b:00.0: 0x00000000 | umac branchlink1
[ 1787.282862] iwlwifi 0000:3b:00.0: 0xC0086AA4 | umac branchlink2
[ 1787.282863] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac interruptlink1
[ 1787.282864] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac interruptlink2
[ 1787.282865] iwlwifi 0000:3b:00.0: 0x00000800 | umac data1
[ 1787.282866] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac data2
[ 1787.282867] iwlwifi 0000:3b:00.0: 0xDEADBEEF | umac data3
[ 1787.282868] iwlwifi 0000:3b:00.0: 0x00000024 | umac major
[ 1787.282869] iwlwifi 0000:3b:00.0: 0x7596AFD4 | umac minor
[ 1787.282870] iwlwifi 0000:3b:00.0: 0xC088628C | frame pointer
[ 1787.282871] iwlwifi 0000:3b:00.0: 0xC088628C | stack pointer
[ 1787.282872] iwlwifi 0000:3b:00.0: 0x00230405 | last host cmd
[ 1787.282873] iwlwifi 0000:3b:00.0: 0x00000000 | isr status reg
[ 1787.282876] ieee80211 phy1285: Hardware restart was requested
[ 1787.282881] iwlwifi 0000:3b:00.0: iwlwifi transaction failed, dumping registers
[ 1787.282883] iwlwifi 0000:3b:00.0: iwlwifi device config registers:
[ 1787.283051] iwlwifi 0000:3b:00.0: 00000000: 24f38086 00100406 0280003a 00000010 ed400004 00000000 00000000 00000000
[ 1787.283053] iwlwifi 0000:3b:00.0: 00000020: 00000000 00000000 00000000 00108086 00000000 000000c8 00000000 000001ff
[ 1787.283054] iwlwifi 0000:3b:00.0: iwlwifi device memory mapped registers:
[ 1787.283116] iwlwifi 0000:3b:00.0: 00000000: 18489008 0000ff40 00000000 ba00008b 00000000 00000000 00000019 00000000
[ 1787.283117] iwlwifi 0000:3b:00.0: 00000020: 00000000 08040005 00000201 d55555d5 d55555d5 d55555d5 80008040 041f0042
[ 1787.283130] iwlwifi 0000:3b:00.0: iwlwifi device AER capability structure:
[ 1787.283172] iwlwifi 0000:3b:00.0: 00000000: 14010001 00000000 00000000 00462031 00000000 00002000 00000000 00000000
[ 1787.283173] iwlwifi 0000:3b:00.0: 00000020: 00000000 00000000 00000000
[ 1787.283174] iwlwifi 0000:3b:00.0: iwlwifi parent port (0000:00:1c.0) config registers:
[ 1787.283210] iwlwifi 0000:00:1c.0: 00000000: a3388086 00100407 060400f0 00810010 00000000 00000000 003b3b00 200000f0
[ 1787.283212] iwlwifi 0000:00:1c.0: 00000020: ed40ed40 0001fff1 00000000 00000000 00000000 00000040 00000000 001001ff
[ 1787.283214] iwlwifi 0000:3b:00.0: iwlwifi root port (0000:00:1c.0) AER cap structure:
[ 1787.283225] iwlwifi 0000:00:1c.0: 00000000: 14010001 00000000 00010000 00060011 00000000 00002000 00000000 00000000
[ 1787.283227] iwlwifi 0000:00:1c.0: 00000020: 00000000 00000000 00000000 00000000 00000000 00000000
[ 1787.283228] iwlwifi 0000:3b:00.0: FW error in SYNC CMD GEO_TX_POWER_LIMIT
[ 1787.283230] CPU: 5 PID: 669 Comm: NetworkManager Tainted: G        W  OE     4.19.6-1-MANJARO #1
[ 1787.283231] Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.3.1 08/02/2018
[ 1787.283231] Call Trace:
[ 1787.283236]  dump_stack+0x5c/0x80
[ 1787.283243]  iwl_trans_pcie_send_hcmd+0x50c/0x520 [iwlwifi]
[ 1787.283246]  ? wait_woken+0x80/0x80
[ 1787.283250]  iwl_trans_send_cmd+0x61/0xd0 [iwlwifi]
[ 1787.283256]  iwl_mvm_send_cmd+0x2c/0x90 [iwlmvm]
[ 1787.283260]  iwl_mvm_send_cmd_pdu+0x51/0x70 [iwlmvm]
[ 1787.283263]  iwl_mvm_up+0x9c5/0xa50 [iwlmvm]
[ 1787.283265]  ? skb_dequeue+0x52/0x60
[ 1787.283268]  __iwl_mvm_mac_start+0x287/0x2f0 [iwlmvm]
[ 1787.283270]  ? fib6_walk+0x7d/0x90
[ 1787.283273]  iwl_mvm_mac_start+0x53/0x120 [iwlmvm]
[ 1787.283285]  drv_start+0x3e/0x130 [mac80211]
[ 1787.283293]  ieee80211_do_open+0x429/0x840 [mac80211]
[ 1787.283295]  __dev_open+0xce/0x160
[ 1787.283297]  __dev_change_flags+0x179/0x1f0
[ 1787.283298]  dev_change_flags+0x21/0x60
[ 1787.283299]  do_setlink+0x30b/0xe90
[ 1787.283302]  ? nla_parse+0xb5/0xda
[ 1787.283303]  ? inet6_validate_link_af+0x4b/0x70
[ 1787.283305]  rtnl_newlink+0x502/0x810
[ 1787.283306]  ? update_group_capacity+0x26/0x2d0
[ 1787.283308]  ? cpumask_next_and+0x19/0x20
[ 1787.283308]  ? find_busiest_group+0x747/0xb10
[ 1787.283309]  ? cpumask_next+0x16/0x20
[ 1787.283310]  ? snmp6_fill_stats.isra.10+0xa9/0x1b0
[ 1787.283313]  ? __nla_reserve+0x38/0x50
[ 1787.283315]  ? __kmalloc_node_track_caller+0x1ed/0x290
[ 1787.283316]  ? pskb_expand_head+0x71/0x2f0
[ 1787.283318]  ? __local_bh_enable_ip+0x3a/0x80
[ 1787.283319]  ? __kmalloc_reserve.isra.8+0x2e/0x80
[ 1787.283321]  ? preempt_count_add+0x79/0xb0
[ 1787.283322]  ? _raw_spin_lock_irqsave+0x25/0x50
[ 1787.283323]  ? skb_queue_tail+0x1b/0x50
[ 1787.283325]  ? sock_def_readable+0xe/0x80
[ 1787.283327]  ? __netlink_sendskb+0x3d/0x50
[ 1787.283327]  ? netlink_sendskb+0x12/0x40
[ 1787.283328]  ? netlink_unicast+0x219/0x240
[ 1787.283329]  ? rtnl_getlink+0x190/0x280
[ 1787.283332]  ? skb_dequeue_tail+0x20/0x60
[ 1787.283333]  ? sock_def_readable+0xe/0x80
[ 1787.283334]  ? rt6_multipath_rebalance.part.28+0x140/0x140
[ 1787.283335]  ? fib6_clean_node+0x8a/0x160
[ 1787.283336]  rtnetlink_rcv_msg+0x126/0x390
[ 1787.283338]  ? proc_sys_compare+0x9e/0xc0
[ 1787.283339]  ? __d_lookup+0x73/0x130
[ 1787.283340]  ? rtnl_calcit.isra.14+0x110/0x110
[ 1787.283341]  netlink_rcv_skb+0x4c/0x120
[ 1787.283342]  netlink_unicast+0x196/0x240
[ 1787.283343]  netlink_sendmsg+0x1fd/0x3c0
[ 1787.283345]  sock_sendmsg+0x33/0x40
[ 1787.283346]  ___sys_sendmsg+0x295/0x2f0
[ 1787.283347]  ? __rtnl_unlock+0x25/0x40
[ 1787.283348]  ? netdev_run_todo+0x61/0x280
[ 1787.283350]  ? addrconf_sysctl_forward+0x113/0x250
[ 1787.283351]  ? __fget+0x6e/0xa0
[ 1787.283353]  __sys_sendmsg+0x57/0xa0
[ 1787.283355]  do_syscall_64+0x65/0x180
[ 1787.283357]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1787.283358] RIP: 0033:0x7f05c35300f7
[ 1787.283359] Code: c3 66 90 41 54 41 89 d4 55 48 89 f5 53 89 fb 48 83 ec 10 e8 eb ec ff ff 44 89 e2 48 89 ee 89 df 41 89 c0 b8 2e 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 35 44 89 c7 48 89 44 24 08 e8 24 ed ff ff 48
[ 1787.283360] RSP: 002b:00007ffeac3e8ed0 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
[ 1787.283361] RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f05c35300f7
[ 1787.283362] RDX: 0000000000000000 RSI: 00007ffeac3e8f20 RDI: 0000000000000008
[ 1787.283362] RBP: 00007ffeac3e8f20 R08: 0000000000000000 R09: 0000000000000000
[ 1787.283363] R10: 00005598eecd5010 R11: 0000000000000293 R12: 0000000000000000
[ 1787.283363] R13: 0000000000000000 R14: 00007ffeac3e90d8 R15: 00007ffeac3e90cc
[ 1787.788102] iwlwifi 0000:3b:00.0: Microcode SW error detected.  Restarting 0x82000000.
[ 1787.788631] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1787.788639] iwlwifi 0000:3b:00.0: Status: 0x00000110, count: 6
[ 1787.788644] iwlwifi 0000:3b:00.0: Loaded firmware version: 36.7596afd4.0
[ 1787.788650] iwlwifi 0000:3b:00.0: 0x00000038 | BAD_COMMAND
[ 1787.788655] iwlwifi 0000:3b:00.0: 0x00A002F1 | trm_hw_status0
[ 1787.788660] iwlwifi 0000:3b:00.0: 0x00000000 | trm_hw_status1
[ 1787.788665] iwlwifi 0000:3b:00.0: 0x000241F4 | branchlink2
[ 1787.788670] iwlwifi 0000:3b:00.0: 0x000397EE | interruptlink1
[ 1787.788675] iwlwifi 0000:3b:00.0: 0x00000000 | interruptlink2
[ 1787.788679] iwlwifi 0000:3b:00.0: 0x00220405 | data1
[ 1787.788684] iwlwifi 0000:3b:00.0: 0x00000023 | data2
[ 1787.788689] iwlwifi 0000:3b:00.0: 0x00000023 | data3
[ 1787.788694] iwlwifi 0000:3b:00.0: 0x00000000 | beacon time
[ 1787.788699] iwlwifi 0000:3b:00.0: 0x0000B1B6 | tsf low
[ 1787.788703] iwlwifi 0000:3b:00.0: 0x00000000 | tsf hi
[ 1787.788708] iwlwifi 0000:3b:00.0: 0x00000000 | time gp1
[ 1787.788713] iwlwifi 0000:3b:00.0: 0x0000B1B7 | time gp2
[ 1787.788718] iwlwifi 0000:3b:00.0: 0x00000001 | uCode revision type
[ 1787.788723] iwlwifi 0000:3b:00.0: 0x00000024 | uCode version major
[ 1787.788728] iwlwifi 0000:3b:00.0: 0x7596AFD4 | uCode version minor
[ 1787.788733] iwlwifi 0000:3b:00.0: 0x00000201 | hw version
[ 1787.788738] iwlwifi 0000:3b:00.0: 0x18489008 | board version
[ 1787.788743] iwlwifi 0000:3b:00.0: 0x00220405 | hcmd
[ 1787.788748] iwlwifi 0000:3b:00.0: 0x00122080 | isr0
[ 1787.788753] iwlwifi 0000:3b:00.0: 0x00000000 | isr1
[ 1787.788757] iwlwifi 0000:3b:00.0: 0x28201802 | isr2
[ 1787.788762] iwlwifi 0000:3b:00.0: 0x004000C0 | isr3
[ 1787.788767] iwlwifi 0000:3b:00.0: 0x00000000 | isr4
[ 1787.788771] iwlwifi 0000:3b:00.0: 0x0021019F | last cmd Id
[ 1787.788776] iwlwifi 0000:3b:00.0: 0x00000000 | wait_event
[ 1787.788781] iwlwifi 0000:3b:00.0: 0x00005FBC | l2p_control
[ 1787.788786] iwlwifi 0000:3b:00.0: 0x00000820 | l2p_duration
[ 1787.788790] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_mhvalid
[ 1787.788795] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_addr_match
[ 1787.788800] iwlwifi 0000:3b:00.0: 0x0000000D | lmpm_pmg_sel
[ 1787.788805] iwlwifi 0000:3b:00.0: 0x22040707 | timestamp
[ 1787.788810] iwlwifi 0000:3b:00.0: 0x00001828 | flow_handler
[ 1787.789010] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1787.789016] iwlwifi 0000:3b:00.0: Status: 0x00000110, count: 7
[ 1787.789021] iwlwifi 0000:3b:00.0: 0x00000070 | ADVANCED_SYSASSERT
[ 1787.789026] iwlwifi 0000:3b:00.0: 0x00000000 | umac branchlink1
[ 1787.789031] iwlwifi 0000:3b:00.0: 0xC0086AA4 | umac branchlink2
[ 1787.789036] iwlwifi 0000:3b:00.0: 0xC008D836 | umac interruptlink1
[ 1787.789041] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac interruptlink2
[ 1787.789046] iwlwifi 0000:3b:00.0: 0x00000800 | umac data1
[ 1787.789051] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac data2
[ 1787.789055] iwlwifi 0000:3b:00.0: 0xDEADBEEF | umac data3
[ 1787.789060] iwlwifi 0000:3b:00.0: 0x00000024 | umac major
[ 1787.789065] iwlwifi 0000:3b:00.0: 0x7596AFD4 | umac minor
[ 1787.789070] iwlwifi 0000:3b:00.0: 0xC088628C | frame pointer
[ 1787.789075] iwlwifi 0000:3b:00.0: 0xC088628C | stack pointer
[ 1787.789080] iwlwifi 0000:3b:00.0: 0x00220405 | last host cmd
[ 1787.789085] iwlwifi 0000:3b:00.0: 0x00000000 | isr status reg
[ 1787.789092] iwlwifi 0000:3b:00.0: Firmware error during reconfiguration - reprobe!
[ 1787.789111] iwlwifi 0000:3b:00.0: FW Error notification: type 0x00000000 cmd_id 0x05
[ 1787.789117] iwlwifi 0000:3b:00.0: FW error in SYNC CMD GEO_TX_POWER_LIMIT
[ 1787.789120] iwlwifi 0000:3b:00.0: FW Error notification: seq 0x0022 service 0x00000005
[ 1787.789127] iwlwifi 0000:3b:00.0: FW Error notification: timestamp 0x            B1B3
[ 1787.789139] CPU: 2 PID: 766 Comm: wpa_supplicant Tainted: G        W  OE     4.19.6-1-MANJARO #1
[ 1787.789141] Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.3.1 08/02/2018
[ 1787.789143] Call Trace:
[ 1787.789158]  dump_stack+0x5c/0x80
[ 1787.789182]  iwl_trans_pcie_send_hcmd+0x50c/0x520 [iwlwifi]
[ 1787.789192]  ? wait_woken+0x80/0x80
[ 1787.789211]  iwl_trans_send_cmd+0x61/0xd0 [iwlwifi]
[ 1787.789232]  iwl_mvm_send_cmd+0x2c/0x90 [iwlmvm]
[ 1787.789249]  iwl_mvm_send_cmd_pdu+0x51/0x70 [iwlmvm]
[ 1787.789264]  iwl_mvm_up+0x9c5/0xa50 [iwlmvm]
[ 1787.789280]  __iwl_mvm_mac_start+0x259/0x2f0 [iwlmvm]
[ 1787.789294]  iwl_mvm_mac_start+0x53/0x120 [iwlmvm]
[ 1787.789303]  ? sock_def_readable+0xe/0x80
[ 1787.789340]  drv_start+0x3e/0x130 [mac80211]
[ 1787.789375]  ieee80211_do_open+0x429/0x840 [mac80211]
[ 1787.789383]  __dev_open+0xce/0x160
[ 1787.789389]  __dev_change_flags+0x179/0x1f0
[ 1787.789399]  dev_change_flags+0x21/0x60
[ 1787.789406]  devinet_ioctl+0x53a/0x670
[ 1787.789414]  ? netlink_recvmsg+0x35b/0x420
[ 1787.789420]  inet_ioctl+0x97/0x170
[ 1787.789427]  ? dev_get_by_name_rcu+0x73/0x90
[ 1787.789431]  ? dev_get_by_name_rcu+0x73/0x90
[ 1787.789439]  ? __check_object_size+0xa0/0x189
[ 1787.789444]  sock_do_ioctl+0x48/0x160
[ 1787.789450]  sock_ioctl+0x1a4/0x320
[ 1787.789457]  do_vfs_ioctl+0xa4/0x630
[ 1787.789465]  ? syscall_slow_exit_work+0x19b/0x1b0
[ 1787.789471]  ? syscall_trace_enter+0x1d3/0x2d0
[ 1787.789476]  ksys_ioctl+0x60/0x90
[ 1787.789481]  __x64_sys_ioctl+0x16/0x20
[ 1787.789486]  do_syscall_64+0x65/0x180
[ 1787.789493]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1787.789498] RIP: 0033:0x7f18fa82f80b
[ 1787.789503] Code: 0f 1e fa 48 8b 05 55 b6 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 25 b6 0c 00 f7 d8 64 89 01 48
[ 1787.789506] RSP: 002b:00007ffedfa3ab18 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 1787.789512] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f18fa82f80b
[ 1787.789514] RDX: 00007ffedfa3ab20 RSI: 0000000000008914 RDI: 0000000000000007
[ 1787.789517] RBP: 0000000000000007 R08: 00007ffedfa3ab2f R09: 0000000000000007
[ 1787.789519] R10: 000055ba00022010 R11: 0000000000000246 R12: 00007ffedfa3ab20
[ 1787.789521] R13: 000055ba00030df0 R14: 0000000000000001 R15: 0000000000000000
[ 1788.056547] iwlwifi 0000:3b:00.0: Microcode SW error detected.  Restarting 0x82000000.
[ 1788.057033] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1788.057039] iwlwifi 0000:3b:00.0: Status: 0x00000100, count: 6
[ 1788.057045] iwlwifi 0000:3b:00.0: Loaded firmware version: 36.7596afd4.0
[ 1788.057050] iwlwifi 0000:3b:00.0: 0x00000038 | BAD_COMMAND
[ 1788.057056] iwlwifi 0000:3b:00.0: 0x00A002F1 | trm_hw_status0
[ 1788.057061] iwlwifi 0000:3b:00.0: 0x00000000 | trm_hw_status1
[ 1788.057066] iwlwifi 0000:3b:00.0: 0x000241F4 | branchlink2
[ 1788.057071] iwlwifi 0000:3b:00.0: 0x000397EE | interruptlink1
[ 1788.057076] iwlwifi 0000:3b:00.0: 0x00000000 | interruptlink2
[ 1788.057080] iwlwifi 0000:3b:00.0: 0x00210405 | data1
[ 1788.057085] iwlwifi 0000:3b:00.0: 0x00000022 | data2
[ 1788.057090] iwlwifi 0000:3b:00.0: 0x00000022 | data3
[ 1788.057095] iwlwifi 0000:3b:00.0: 0x00000000 | beacon time
[ 1788.057100] iwlwifi 0000:3b:00.0: 0x0000A529 | tsf low
[ 1788.057104] iwlwifi 0000:3b:00.0: 0x00000000 | tsf hi
[ 1788.057109] iwlwifi 0000:3b:00.0: 0x00000000 | time gp1
[ 1788.057114] iwlwifi 0000:3b:00.0: 0x0000A52A | time gp2
[ 1788.057119] iwlwifi 0000:3b:00.0: 0x00000001 | uCode revision type
[ 1788.057124] iwlwifi 0000:3b:00.0: 0x00000024 | uCode version major
[ 1788.057129] iwlwifi 0000:3b:00.0: 0x7596AFD4 | uCode version minor
[ 1788.057134] iwlwifi 0000:3b:00.0: 0x00000201 | hw version
[ 1788.057138] iwlwifi 0000:3b:00.0: 0x18489008 | board version
[ 1788.057143] iwlwifi 0000:3b:00.0: 0x00210405 | hcmd
[ 1788.057148] iwlwifi 0000:3b:00.0: 0x00122080 | isr0
[ 1788.057153] iwlwifi 0000:3b:00.0: 0x00000000 | isr1
[ 1788.057157] iwlwifi 0000:3b:00.0: 0x28201802 | isr2
[ 1788.057162] iwlwifi 0000:3b:00.0: 0x004000C0 | isr3
[ 1788.057167] iwlwifi 0000:3b:00.0: 0x00000000 | isr4
[ 1788.057172] iwlwifi 0000:3b:00.0: 0x0020019F | last cmd Id
[ 1788.057176] iwlwifi 0000:3b:00.0: 0x00000000 | wait_event
[ 1788.057181] iwlwifi 0000:3b:00.0: 0x00005FBC | l2p_control
[ 1788.057186] iwlwifi 0000:3b:00.0: 0x00000820 | l2p_duration
[ 1788.057191] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_mhvalid
[ 1788.057196] iwlwifi 0000:3b:00.0: 0x00000000 | l2p_addr_match
[ 1788.057200] iwlwifi 0000:3b:00.0: 0x0000000D | lmpm_pmg_sel
[ 1788.057205] iwlwifi 0000:3b:00.0: 0x22040707 | timestamp
[ 1788.057210] iwlwifi 0000:3b:00.0: 0x00001828 | flow_handler
[ 1788.057402] iwlwifi 0000:3b:00.0: Start IWL Error Log Dump:
[ 1788.057407] iwlwifi 0000:3b:00.0: Status: 0x00000100, count: 7
[ 1788.057413] iwlwifi 0000:3b:00.0: 0x00000070 | ADVANCED_SYSASSERT
[ 1788.057418] iwlwifi 0000:3b:00.0: 0x00000000 | umac branchlink1
[ 1788.057423] iwlwifi 0000:3b:00.0: 0xC0086AA4 | umac branchlink2
[ 1788.057427] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac interruptlink1
[ 1788.057432] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac interruptlink2
[ 1788.057436] iwlwifi 0000:3b:00.0: 0x00000800 | umac data1
[ 1788.057441] iwlwifi 0000:3b:00.0: 0xC0083C90 | umac data2
[ 1788.057446] iwlwifi 0000:3b:00.0: 0xDEADBEEF | umac data3
[ 1788.057451] iwlwifi 0000:3b:00.0: 0x00000024 | umac major
[ 1788.057456] iwlwifi 0000:3b:00.0: 0x7596AFD4 | umac minor
[ 1788.057460] iwlwifi 0000:3b:00.0: 0xC088628C | frame pointer
[ 1788.057465] iwlwifi 0000:3b:00.0: 0xC088628C | stack pointer
[ 1788.057470] iwlwifi 0000:3b:00.0: 0x00210405 | last host cmd
[ 1788.057475] iwlwifi 0000:3b:00.0: 0x00000000 | isr status reg
[ 1788.057482] ieee80211 phy1285: Hardware restart was requested
[ 1788.057503] iwlwifi 0000:3b:00.0: FW Error notification: type 0x00000000 cmd_id 0x05
[ 1788.057510] iwlwifi 0000:3b:00.0: FW error in SYNC CMD GEO_TX_POWER_LIMIT
[ 1788.057512] iwlwifi 0000:3b:00.0: FW Error notification: seq 0x0021 service 0x00000005
[ 1788.057519] iwlwifi 0000:3b:00.0: FW Error notification: timestamp 0x            A526
[ 1788.057531] CPU: 2 PID: 766 Comm: wpa_supplicant Tainted: G        W  OE     4.19.6-1-MANJARO #1
[ 1788.057534] Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.3.1 08/02/2018
[ 1788.057535] Call Trace:
[ 1788.057550]  dump_stack+0x5c/0x80
[ 1788.057573]  iwl_trans_pcie_send_hcmd+0x50c/0x520 [iwlwifi]
[ 1788.057582]  ? wait_woken+0x80/0x80
[ 1788.057600]  iwl_trans_send_cmd+0x61/0xd0 [iwlwifi]
[ 1788.057620]  iwl_mvm_send_cmd+0x2c/0x90 [iwlmvm]
[ 1788.057636]  iwl_mvm_send_cmd_pdu+0x51/0x70 [iwlmvm]
[ 1788.057650]  iwl_mvm_up+0x9c5/0xa50 [iwlmvm]
[ 1788.057656]  ? skb_dequeue+0x52/0x60
[ 1788.057670]  __iwl_mvm_mac_start+0x287/0x2f0 [iwlmvm]
[ 1788.057684]  iwl_mvm_mac_start+0x53/0x120 [iwlmvm]
[ 1788.057691]  ? sock_def_readable+0xe/0x80
[ 1788.057723]  drv_start+0x3e/0x130 [mac80211]
[ 1788.057756]  ieee80211_do_open+0x429/0x840 [mac80211]
[ 1788.057763]  __dev_open+0xce/0x160
[ 1788.057769]  __dev_change_flags+0x179/0x1f0
[ 1788.057774]  ? lookup_fast+0x136/0x2f0
[ 1788.057779]  dev_change_flags+0x21/0x60
[ 1788.057785]  devinet_ioctl+0x53a/0x670
[ 1788.057792]  inet_ioctl+0x97/0x170
[ 1788.057797]  ? filename_lookup.part.21+0xe0/0x170
[ 1788.057802]  ? dev_get_by_name_rcu+0x73/0x90
[ 1788.057807]  ? dev_get_by_name_rcu+0x73/0x90
[ 1788.057814]  ? __check_object_size+0xa0/0x189
[ 1788.057818]  sock_do_ioctl+0x48/0x160
[ 1788.057825]  sock_ioctl+0x1a4/0x320
[ 1788.057832]  do_vfs_ioctl+0xa4/0x630
[ 1788.057839]  ? syscall_slow_exit_work+0x19b/0x1b0
[ 1788.057843]  ? __se_sys_newlstat+0x4d/0x70
[ 1788.057849]  ? syscall_trace_enter+0x1d3/0x2d0
[ 1788.057854]  ksys_ioctl+0x60/0x90
[ 1788.057860]  __x64_sys_ioctl+0x16/0x20
[ 1788.057865]  do_syscall_64+0x65/0x180
[ 1788.057871]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1788.057877] RIP: 0033:0x7f18fa82f80b
[ 1788.057881] Code: 0f 1e fa 48 8b 05 55 b6 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 25 b6 0c 00 f7 d8 64 89 01 48
[ 1788.057884] RSP: 002b:00007ffedfa3a708 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 1788.057890] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f18fa82f80b
[ 1788.057892] RDX: 00007ffedfa3a710 RSI: 0000000000008914 RDI: 0000000000000008
[ 1788.057894] RBP: 0000000000000008 R08: 00007ffedfa3a71f R09: 0000000000000007
[ 1788.057897] R10: 000055ba00022010 R11: 0000000000000246 R12: 00007ffedfa3a710
[ 1788.057899] R13: 000055ba00032398 R14: 0000000000000001 R15: 00007ffedfa3ab20
[ 1788.284293] iwlwifi 0000:3b:00.0: loaded firmware version 36.7596afd4.0 op_mode iwlmvm
[ 1788.284332] iwlwifi 0000:3b:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x208
[ 1788.359933] iwlwifi 0000:3b:00.0: base HW address: f0:d5:bf:b2:0d:e5
[ 1788.433694] ieee80211 phy1286: Selected rate control algorithm 'iwl-mvm-rs'
[ 1788.441923] iwlwifi 0000:3b:00.0 wlp59s0: renamed from wlan0
[ 1788.486081] IPv6: ADDRCONF(NETDEV_UP): wlp59s0: link is not ready
#34
Downgrading linux-firmware to linux-firmware-20181018.d877533-1 didn’t help, neither using 4.14.85 (nor any combination of both).
Any ideas?
#35
Hi, I have noticed that systemd has been downgraded today to 239.6-2 in testing, as it is in stable. Was it intentional?
#36
Yes it was intentional. Check the stable update 2018-12-04 announcement.
#37
I had the same warning in stable. Everything is fine like it is. Could this be hardware related?
[bob@Manjaro-Testing ~]$ sudo pacman -Syyu
core 147.4 KiB 2.29M/s 00:00 [######################] 100%
extra 1826.8 KiB 15.2M/s 00:00 [######################] 100%
community 5.1 MiB 25.7M/s 00:00 [######################] 100%
multilib 185.0 KiB 30.1M/s 00:00 [######################] 100%
:: Starting full system upgrade…
warning: lib32-systemd: local (239.303-1) is newer than multilib (239.6-2)
warning: libsystemd: local (239.303-1) is newer than core (239.6-2)
warning: systemd: local (239.303-1) is newer than core (239.6-2)
warning: systemd-sysvcompat: local (239.303-1) is newer than core (239.6-2)
there is nothing to do
#38
Update fails because of a PGP signature being unrecognized on my end:
Le fichier /var/cache/pacman/pkg/linux-firmware-20181026.1cb4e51-1-any.pkg.tar.xz est corrompu (paquet non valide ou corrompu (signature PGP)).
Took steps to solve it but server times out, have to try with another key server.
Edit: solved by reinstalling the keyrings, initialising pacman-key and changing the server in /etc/pacman.d/gnupg/gpg.conf.
Steps detailed here.
Or the package has been reuploaded with correct key, dunno.
#39
Got
chromium-71.0.3578.80-0
tonight. Thank you.
#40
@philm
This issue
is now gone,
thank you guys :slight_smile:
