[Testing Update] 2018-04-02 - Kernels, Gnome, Mesa, Pamac, Browsers, GStreamer, LibreOffice, PHP
update
testing
#1
Hi community,
welcome to another testing update of Manjaro. With this update we focus on GNOME 3.28, which is the result of 6 months’ hard work by the GNOME community. It contains major new features, as well as many smaller improvements and bug fixes.
One major new feature for this release is automatic downloading of operating systems in Boxes, which takes the work out of creating and running virtual machines – just pick the operating system that you want to create a virtual machine of, and Boxes will now download and install it for you.
Other highlights include improvements to the Calendar and Contacts applications, the ability to star files and folders in the Files application, and improved support for Thunderbolt 3 and Bluetooth LE devices. GNOME’s default UI font has also been overhauled to be more attractive and easy to read, and the on-screen keyboard has been rewritten to be more reliable and has layouts for a number of different locales.
There are many other improvements in GNOME 3.28, which can be read about in the release notes.
Additionally we updated Pamac, Mesa, Kernels, Browsers, LibreOffice, GStreamer and PHP to mention a few …
Our effort and all the needed information about the new security risk can be found here.
So please report back and give us feedback for given changes made to our repositories. Users of our 32-bit Distro should read this.
Current supported Kernels
  • linux316 3.16.56
  • linux318 3.18.102 [EOL]
  • linux41 4.1.51
  • linux44 4.4.126
  • linux49 4.9.92
  • linux414 4.14.32
  • linux415 4.15.15
  • linux416 4.16.0
  • linux-rt 4.14.29_rt25
Package Updates (Mon Apr 2 11:59:08 CEST 2018)
  • testing community x86_64: 831 new and 823 removed package(s)
  • testing core x86_64: 25 new and 26 removed package(s)
  • testing extra x86_64: 601 new and 592 removed package(s)
  • testing multilib x86_64: 35 new and 28 removed package(s)
A detailed list of all package changes can be found here.
0 voters
Cuda 9.1. not compatible with nvidia 384
#2
Known issues and solutions
Nautilus - Middle click on any location in other-locations:/// closes tab
#3
maybe check for others linux416 & nvidia
#4
Wow, 169 packages, many gnome related and libraries. Delicious!
Loading dconf editor gives me this, are these schemas necessary?
dconf-editor[6772]: source-manager.vala:108: The following schemas:
                                          org.cinnamon.invalid-schema
                                          org.cinnamon.settings-daemon.plugins.csdwacom
                                          org.x.apps
                                        contain neither keys nor children.
#5
For me display is flickering on kernel 4.16 on my radeon gpu, on 4.15 it was only with redshift but now is different(also on wayland plasma), so am staying on lts for now.Possibly related:
https://bugs.freedesktop.org/show_bug.cgi?id=105083
#6
Great update, GNOME 3.28 runs without problems here.
One thing I would like to mention even if it is not related to this update, but the GNOME implementation in general.
Like with 3.26 I still have to install the Mutter-workaround to get rid of micro stuttering in the gnome animations. Maybe it’s just my GTX 780 ti, I really don’t know, but I can verify that on Solus GNOME it just works fine. So there must be something this guys do different with their implementation.
Maybe the Manjaro devs could have a talk to the Solus devs about their changes? :wink:
#7
Bah, no desktop icons ;(
#8
They simply use the patch. Nothing more, nothing less.
#9
#10
There is extension in work to bring desktop icons, and they recommend using Nemo instead of Nautilus ;p
#11
Well, Gnome was never about the users. Decisions are made by the board, even if it changes user space. That is one of the reasons I stick to XFCE since years.
#12
Hi, smooth update, Desktop=Deepin 15.5
  Host: deepin Kernel: 4.16.0-1-MANJARO x86_64 bits: 64 Desktop: N/A
  Distro: Manjaro Linux 17.1.7 Hakoila
[mint@deepin ~]$ inkscape -V
(inkscape:32277): Gtk-WARNING **: 15:31:22.939: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
Inkscape 0.92.2 2405546, 2018-03-11
After reinstall
(inkscape:18250): Gtk-WARNING **: 15:48:27.407: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
** (inkscape:18250): WARNING **: 15:48:28.705: <svg:path id="path1">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.705: <svg:path id="path1">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.705: <svg:rect id="rect2">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.705: <svg:path id="path11">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.705: <svg:path id="path11">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:path id="path11">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:path id="path11">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:rect id="rect22">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:path id="path111">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:path id="path111">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.706: <svg:rect id="rect222">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.763: <svg:path id="path2302">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.763: <svg:path id="path2304">: CSS Style property: "stroke-width" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:48:28.764: <svg:path id="path2312">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.764: <svg:path id="path2314">: CSS Style property: "stroke-width" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:48:28.794: <svg:path id="">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:48:28.953: <svg:path id="path1">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.953: <svg:path id="path1">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.953: <svg:rect id="rect2">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.953: <svg:path id="path11">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.954: <svg:path id="path11">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.954: <svg:path id="path11">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.954: <svg:rect id="rect22">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.954: <svg:path id="path111">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.954: <svg:path id="path111">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.955: <svg:path id="path111">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.955: <svg:path id="path111">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:28.955: <svg:rect id="rect222">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.059: <svg:path id="path1">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.059: <svg:path id="path1">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.059: <svg:rect id="rect2">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.060: <svg:path id="path11">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.060: <svg:path id="path11">: CSS Style property: "marker-end" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.060: <svg:rect id="rect22">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.060: <svg:path id="path111">: CSS Style property: "marker-start" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.060: <svg:path id="path111">: CSS Style property: "marker-mid" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:48:29.061: <svg:rect id="rect222">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:07.397: <svg:rect id="">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:07.398: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:07.398: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:07.398: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-miterlimit" with default value (4) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-dasharray" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:07.399: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-miterlimit" with default value (4) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-dasharray" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:08.045: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-miterlimit" with default value (4) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-dasharray" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:08.046: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-miterlimit" with default value (4) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-dasharray" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.047: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-miterlimit" with default value (4) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-dasharray" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:08.048: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:08.049: <svg:rect id="rect815">: CSS Style property: "stroke-dashoffset" with default value (0) not needed.
** (inkscape:18250): WARNING **: 15:49:08.049: <svg:rect id="rect815">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.586: <svg:path id="">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.587: <svg:path id="">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.588: <svg:path id="whiteSpace">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.589: <svg:path id="whiteSpace">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.589: <svg:path id="droplet01">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.589: <svg:path id="droplet01">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.589: <svg:path id="droplet02">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.589: <svg:path id="droplet02">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.590: <svg:path id="droplet02">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.590: <svg:path id="droplet02">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.590: <svg:path id="droplet03">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.590: <svg:path id="droplet03">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.590: <svg:path id="mountainDroplet">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:path id="mountainDroplet">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:path id="mountainDroplet">: CSS Style property: "font-size" is inappropriate.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:text id="">: CSS Style property: "font-style" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:text id="">: CSS Style property: "font-variant" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:text id="">: CSS Style property: "font-stretch" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:text id="">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.591: <svg:text id="">: CSS Style property: "stroke" with default value (none) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "stroke-linecap" with default value (butt) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "stroke-linejoin" with default value (miter) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "stroke-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "font-style" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "font-variant" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "font-stretch" with default value (normal) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "fill-opacity" with default value (1) not needed.
** (inkscape:18250): WARNING **: 15:49:35.592: <svg:text id="">: CSS Style property: "stroke" with default value (none) not needed.
Inkscape do not change the Info?
After delete and new install same, and lot of warning, but no image problem I think.
#13
…i3 sandy-bridge, i5 ivy-bridge, xfce, kernel 4.16.0-1 smooth update. :egg:
#14
I got a grub error during update:
( 6/32) Updating Grub-Bootmenu
GRUB-Konfigurationsdatei wird erstellt …
Thema gefunden: /usr/share/grub/themes/manjaro/theme.txt
Linux-Abbild gefunden: /boot/vmlinuz-4.15-x86_64
initrd-Abbild gefunden: /boot/intel-ucode.img /boot/initramfs-4.15-x86_64.img
Found initrd fallback image: /boot/initramfs-4.15-x86_64-fallback.img
Linux-Abbild gefunden: /boot/vmlinuz-4.14-x86_64
initrd-Abbild gefunden: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
/dev/mapper/control: open failed: Kein passendes Gerät gefunden
Failure to communicate with kernel device-mapper driver.
Check that device-mapper is available in the kernel.
Incompatible libdevmapper 1.02.146 (2017-12-18) and kernel driver (unknown version).
Command failed
Fehler: Befehl konnte nicht korrekt ausgeführt werden
An update-grub in a separte window gave the same error. I kept my fingers crossed during reboot. reboot worked and update-grub after reboot was successful as well. Phuuuh. :wink:
#15
Since kernel 4.16 just release i tried it and i experience flashes on desktop like for a second gamma is set to max and then back to normal. It happens moving the mouse. Playing games is not affected, i tried with dc enable and disable. I’m using kde and my graphics card is a radeon R9 380X.
#16
UaU (wow)
228 updates, download 971, 45 MiB
Pamac didn’t show any updates, using “sudo pacman -Syyu”
#17
Amen - and I create my franken-gnome; Replaced nautilus with nemo right now ^^
Probably should realy give xfce a shot soon though…
#18
Smooth update on my main rig. One thing i noticed regarding the 4.16.0 kernel … if i boot with my Cintiq OFF, when i turn it on, there is a connect-disconnect simultaneously, and i could only see something related to event16, but i don’t see it in journactl, just in the KSystemLog. I took a screenshot (i apologize for that), but as you can see i will not post it directly in the forum :slight_smile:
Same behavior if i attach an USB stick or external drive. Turing it off and on again seems to solve the Pen Display connection, but not always with the USB stick.
[Testing Update] 2018-10-07 - Linux419 LTS, Pamac-Dev, SPL/ZFS
#19
sudo modprobe dm-mod
Now - the question is why this needs to be done on some systems and not others.
#20
for me, the flashes disappeared with disabling amdgpu.dc - on RX480. You need to set the boot parameter to amdgpu.dc=0 to deactivate it! Removing the line from grub does not deactivate it, as it is activated by default on Arch-based distributions. 4.17 will activate amdgpu.dc on mainline.
