[Testing Update] 2018-01-04 - Kernels, XFCE-Settings, Gimp Development Edition
update
testing
pti
kpti
#21
I have not noticed any regression yet on my Manjaro XFCE.
However, I tested the Manjaro Cinnamon on my AMD laptop (I did a fresh install of the 17.0.6 and installed all updates available before I switched to the Testing branch) and yes, I saw an big issue with the Cinnamon panel when we use the Adapta theme: the application menu has become way too transparent and thus, unreadable.
With the Adapta-Nokto-Maia desktop theme.
With the Adapta-Maia desktop theme.
However, other desktop themes doesn’t seems to have any issue at all.
With the Vertex-Maia desktop theme.
With the Cinnamon desktop theme.
As you can see, previews for Adapta themes aren’t available, but this is something that have been introduced before (I don’t remember when exactly though).
I don’t know what happened here. I received absolutely no updates for Adapta and no updates for Cinnamon too.
[awesome@k55n ~]$ inxi -FxxN
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System:    Host: k55n Kernel: 4.9.74-2-MANJARO x86_64 bits: 64 gcc: 7.2.1
           Desktop: Cinnamon 3.6.6 (Gtk 3.22.26) dm: lightdm
           Distro: Manjaro Linux
Machine:   Device: laptop System: ASUSTeK product: K55N v: 1.0 serial: N/A
           Mobo: ASUSTeK model: K55N v: 1.0 serial: N/A
           UEFI: American Megatrends v: 217 date: 09/07/2012
Battery    BAT0: charge: 19.0 Wh 45.0% condition: 42.2/51.7 Wh (82%)
           volts: 11.0/10.9
           model: ASUS K55--47 serial: N/A status: Discharging
CPU:       Quad core AMD A8-4500M APU with Radeon HD Graphics (-MCP-)
           arch: Piledriver rev.1 cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 15178
           clock speeds: min/max: 1400/1900 MHz 1: 1400 MHz 2: 1400 MHz
           3: 1400 MHz 4: 1400 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Trinity [Radeon HD 7640G]
           bus-ID: 00:01.0 chip-ID: 1002:9903
           Display Server: N/A drivers: ati,radeon (unloaded: modesetting)
           tty size: 80x24
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           driver: snd_hda_intel bus-ID: 00:14.2 chip-ID: 1022:780d
           Card-2 Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio Controller
           driver: snd_hda_intel bus-ID: 00:01.1 chip-ID: 1002:9902
           Sound: Advanced Linux Sound Architecture v: k4.9.74-2-MANJARO
Network:   Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter
           driver: ath9k bus-ID: 04:00.0 chip-ID: 168c:0032
           IF: wlp4s0 state: up mac: dc:85:de:8d:06:9d
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8168 v: 8.044.02-NAPI port: e000
           bus-ID: 05:00.0 chip-ID: 10ec:8168
           IF: enp5s0 state: down mac: 08:60:6e:05:ea:a6
Drives:    HDD Total Size: 500.1GB (1.3% used)
           ID-1: /dev/sda model: Hitachi_HTS54505 size: 500.1GB
           serial: TE85123RCU6XHW
Partition: ID-1: / size: 60G used: 5.9G (11%) fs: ext4 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 40.9C mobo: N/A gpu: 39.0
           Fan Speeds (in rpm): cpu: 2200
Info:      Processes: 170 Uptime: 22 min Memory: 819.4/3408.9MB
           Init: systemd v: 236 Gcc sys: 7.2.1
           Client: Shell (bash 4.4.121 running in gnome-terminal-) inxi: 2.3.53
[Testing Update] 2018-01-06 - Browsers, Nvidia, PHP, Compiz, Repo-Cleanup
#22
KSysguard informs everything runs as regular with cpu load and ram use in my testing branch laptop.
Summary
[manjaro@manjaro-pc ~]$ inxi -FxxN
System: Host: manjaro-pc Kernel: 4.14.11-3-MANJARO x86_64 bits: 64 gcc: 7.2.1
Desktop: KDE Plasma 5.11.5 (Qt 5.10.0) dm: sddm,sddm Distro: Manjaro Linux
Machine: Device: laptop System: Dell product: Inspiron 5459 serial: N/A Chassis: type: 9 serial: N/A
Mobo: Dell model: 0TNRDT v: A00 serial: N/A UEFI [Legacy]: Dell v: 1.2.5 date: 10/06/2016
Battery BAT0: charge: 11.6 Wh 29.7% condition: 39.1/41.4 Wh (94%) volts: 15.9/14.8
model: Panasonic DELL 78V9D6A serial: 3572 status: Charging
CPU: Dual core Intel Core i5-6200U (-MT-MCP-) arch: Skylake rev.3 cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9602
clock speeds: min/max: 400/2800 MHz 1: 2400 MHz 2: 2400 MHz 3: 2400 MHz 4: 2400 MHz
Graphics: Card: Intel HD Graphics 520 bus-ID: 00:02.0 chip-ID: 8086:1916
Display Server: x11 (X.Org 1.19.6 ) drivers: intel (unloaded: modesetting)
Resolution: 1366x768@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
version: 4.5 Mesa 17.3.1 (compat-v: 3.0) Direct Render: Yes
Audio: Card Intel Sunrise Point-LP HD Audio
driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d70
Sound: Advanced Linux Sound Architecture v: k4.14.11-3-MANJARO
Network: Card-1: Intel Wireless 3160 driver: iwlwifi bus-ID: 01:00.0 chip-ID: 8086:08b3
IF: wlp1s0 state: up mac: f4:06:69:ac:99:73
Card-2: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8136
IF: enp2s0 state: down mac: 18:db:f2:4f:b3:b5
Drives: HDD Total Size: 480.1GB (4.4% used)
ID-1: /dev/sda model: SanDisk_Ultra_II size: 480.1GB serial: 173040421585
Partition: ID-1: / size: 431G used: 12G (3%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 9.07GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 43.0C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 159 Uptime: 11 min Memory: 755.9/3650.6MB Init: systemd v: 236 Gcc sys: 7.2.1
Client: Shell (bash 4.4.121 running in konsole) inxi: 2.3.53
Summary
System: Host: manjaro-pc Kernel: 4.9.74-2-MANJARO x86_64 bits: 64 gcc: 7.2.1
Battery BAT0: charge: 16.8 Wh 42.9% condition: 39.1/41.4 Wh (94%) volts: 16.1/14.8
clock speeds: min/max: 400/2800 MHz 1: 474 MHz 2: 489 MHz 3: 478 MHz 4: 499 MHz
Info: Processes: 172 Uptime: 2 min Memory: 735.7/3658.2MB Init: systemd v: 236 Gcc sys: 7.2.1
#23
In regard to the regression I got with Adapta theme for Cinnamon, I think I found the culprit. It seems to be one of Cinnamon dependencies: librsvg. Downgrading librsvg from 2:2.41.2-1 (the new version we have in Testing) to 2:2:40.20-1 (the old version I had before) fixes the problem I had with the application menu in Cinnamon.
I didn’t need to downgrade any other package.
It seems that the new version of librsvg does some weird shenanigans with Adapta desktop theme for Cinnamon. I don’t know yet if it’s a bug introduced in librsvg 2:2.41.2-1 or if Adapta theme needs some tweaks so it can work well with the new version of this library.
#24
I can confirm that librsvg 2:2.41.2-1 is the issue.
I did a full upgrade to testing except for librsvg 2:2.41.2-1 and everything is ok. As soon as I upgrade librsvg the adapta theme issue starts. Downgrading to 2:2:40.20-1 solves the issue.
My plank start delay issue remains. No clue what is causing this.
#25
I have created an issue for adapta:
#26
Please grab the new version 3.93.0.11-1 from unstable to check if issue is solved
#27
I tested it. It is not fixed with 3.93.0.11-1 .
#28
Evolution mail client doesn’t work with librsvg 2.41, crashing with error
thread '<unnamed>' panicked at 'Cairo error "invalid matrix (not invertible)"'
Downgrading to librsvg 2.40 solves the problem. Can someone check is it my local trouble? Thanks.
#29
The adapta devs fixed the issue:
#30
