[Testing Update] 2017-09-20 - Kernels, Haskell, Python, PulseAudio, Wine
update
testing
#1
Hi community,
we have updated most of our kernels. linux310, linux410 and linux411 kernel series got removed now. Additionally we have a lot of haskell and python rebuilds. With latest PulseAudio and Wine updates we added latest features to our distro.
Please test and give us feedback as usual
Current supported Kernels
  • linux316 3.16.48
  • linux318 3.18.71 [EOL]
  • linux41 4.1.43
  • linux44 4.4.88
  • linux49 4.9.51
  • linux412 4.12.14 [EOL]
  • linux413 4.13.3
  • linux414 4.14-rc0 (x86_64)
  • linux-RT-LTS 4.9.40_rt30 (x86_64)
  • linux-RT 4.11.12_rt12 (x86_64)
Package Updates (Wed Sep 20 17:16:47 CEST 2017)
  • testing community i686: 707 new and 680 removed package(s)
  • testing community x86_64: 719 new and 689 removed package(s)
  • testing core i686: 13 new and 19 removed package(s)
  • testing core x86_64: 15 new and 21 removed package(s)
  • testing extra i686: 132 new and 182 removed package(s)
  • testing extra x86_64: 144 new and 193 removed package(s)
  • testing multilib x86_64: 13 new and 13 removed package(s)
A detailed list of package changes can be found here.
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
#2
Added some fixes to some kernels:
:: Different overlay package(s) in repository core i686
                             PACKAGE              testing             unstable
                            linux413             4.13.3-1             4.13.3-2
                    linux413-headers             4.13.3-1             4.13.3-2
:: Different overlay package(s) in repository core x86_64
                            linux414     4.14rc1-1 4.14rc1.20170920.g820bf5c-1
                    linux414-headers     4.14rc1-1 4.14rc1.20170920.g820bf5c-1
#3
I didn’t noticed any problem with the 4.13.3-1 kernel, the update went ok, then the 4.13.3-2 kernel made the boot time faster with 34ms :smiley:
Cheers!
#4
In Manjaro Settings Manager all kernels are for install. Does not list the ones I have installed.
#5
Did you reboot after the update?
I don’t have the same behavior of what you mention
#6
Yes I rebooted, I always do this after any upgrade.
But, …strange now its working good. Don’t know what happen. :slight_smile:
#7
Updated using “pacman-mirrors -b unstable”. Fixed the problem of kernel panic with kernel 4.13, for now starts without problems in my i3.
#8
As of “manjaro-keyring-20170919-1”
This occurred on testing here:
[Unstable] - Missing multiple Manjaro keys
==> Appending keys from manjaro.gpg...
key 5BD96CC4247B52CC:
1 signature not checked due to a missing key
key CAA6A59611C7F07E:
3 signatures not checked due to missing keys
key 363DFFFD59152F77:
key 2B80869C5C0102A6:
2 signatures not checked due to missing keys
key 8934292D604F8BA2:
key 2C089F09AC97B894:
key 137C934B5DCB998E:
key 62443D89B35859F8:
key DAD3B211663CA268:
key 8DB9F8C18DF53602:
key 17C752B61B2F2E90:
key 8238651DDF5E0594:
[Stable Update] 2017-09-23 - Kernels, Mesa, PulseAudio, GST, Python, Haskell
#9
I got the same error but the update went through okay
#10
zfs module isn’t build for kernel 4.13 and 4.9. Had to revert to 4.4
#11
Manjaro keyring issue from unstable now occurred in testing.
Be good to get it sorted before keyring update hits stable.
#12
I have issues with upgrading kernel and modules due key issues, I guess.
Octopi returns with the following message:
:: Retrieving packages...
linux413-4.13.3-2-x86_64
linux413-r8168-8.044.02-3-x86_64
linux413-virtualbox-host-modules-5.1.28-2-x86_64
checking keys in keyring
checking package integrity
error: linux413: signature from "Philip Müller (Called Little) " is marginal trust
:: File /var/cache/pacman/pkg/linux413-4.13.3-2-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: linux413-r8168: signature from "Philip Müller (Called Little) " is marginal trust
:: File /var/cache/pacman/pkg/linux413-r8168-8.044.02-3-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: linux413-virtualbox-host-modules: signature from "Philip Müller (Called Little) " is marginal trust
:: File /var/cache/pacman/pkg/linux413-virtualbox-host-modules-5.1.28-2-x86_64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Command finished with errors!
#13
I’ve got the same. Update went fine though.
#14
Try this from therminal:
sudo pacman -Syy && sudo pacman -S manjaro-keyring && sudo pacman -Syyu
#15
Thanks for the suggestion, but it run into errors.
error: manjaro-keyring: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is marginal trust
:: File /var/cache/pacman/pkg/manjaro-keyring-20170919-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package (PGP signature))
#16
Try with different mirror/mirrors:
sudo pacman-mirrors -f 10
then run the update command again.
Also you can clean your cache in Octopi …
#17
hiba: linux413: signature from “Philip Müller (Called Little) philm@manjaro.org” is marginal trust
:: A /var/cache/pacman/pkg/linux413-4.13.3-2-x86_64.pkg.tar.xz fájl sérült (hibás vagy sérült csomag (PGP aláírás)).
Szeretné törölni? [I/n]
#18
I’m getting the same error after multiple mirror changes and cache cleaning.
#19
I can’t reproduce this and i have 3 installs … Try to clean the cache first, sync database with the Octopi opened, from the sync icon/button (it will ask for root password) then try to make the update.
#20
I have a solution:
sudo pacman-key --refresh-keys && sudo pacman -Syyu
Signatures not checked due to missing keys
