[Testing Update] 2017-09-11 - Kernels, KDE Framework, Mesa, GCC, Removal of OpenRC
update
testing
#21
On Thursday we have a new set of Kernels anyway …
#22
seems fine
#23
Have usually the last LTS as backup, so back to 4.9.49-1-MANJARO for now and so far it looks good.
Should I install that and try it as well? EDIT: this one works fine.
just for completeness:
==> Building image from preset: /etc/mkinitcpio.d/linux413.preset: 'default'
  -> -k /boot/vmlinuz-4.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.13-x86_64.img
==> Starting build: 4.13.1-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: n5pf
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.13-x86_64.img
#24
I still have this same problem. I see that glibc is still on 2.25 version, and lib32 is trying to install 2.26 version, so I can understand is a problem. But there’s other updates that are freeze for this one. Is there any way to solve it?
I asee that Arch has 2.26 package
Thanks!
#25
@deimidis 2.26 is available in manjaro repo itself.
The problem got solved on next day for me. Sorry that I didn’'t update it.
Please try updating your pacman-mirrors and try that.
If you are still facing the issue please let us know.
#26
