[Testing Update] 2017-09-11 - Kernels, KDE Framework, Mesa, GCC, Removal of OpenRC
update
testing
#1
Hi community,
another week, another update to our testing branch. We updated Mesa to v17.2 series, which includes new drivers and other goodies, updated some of our kernels, added latest KDE Frameworks v5.38 plus having GCC v7.2 as our latest compiler. If you have difficulties to update, please install additional multilib packages of gcc first, so a full upgrade is possible.
With this update, however, we also removed the support of OpenRC. For all users who had used that init-system we recommend to either convert back to systemd or try the new project Artix Linux, which is focused on OpenRC only and is also based on Arch Linux. They already have great migration documentations.
Please test and give us feedback as usual
Current supported Kernels
  • linux310 3.10.107
  • linux312 3.12.74 [EOL]
  • linux316 3.16.47
  • linux318 3.18.70 [EOL]
  • linux41 4.1.43
  • linux44 4.4.87
  • linux48 4.8.17 [EOL]
  • linux49 4.9.49
  • linux410 4.10.17 [EOL]
  • linux411 4.11.12 [EOL]
  • linux412 4.12.12
  • linux413 4.13.1
  • linux-RT-LTS 4.9.40_rt30 (x86_64)
  • linux-RT 4.11.12_rt12 (x86_64)
Package Updates (Mon Sep 11 08:42:26 CEST 2017)
  • testing community i686: 95 new and 242 removed package(s)
  • testing community x86_64: 106 new and 248 removed package(s)
  • testing core i686: 25 new and 25 removed package(s)
  • testing core x86_64: 27 new and 27 removed package(s)
  • testing extra i686: 137 new and 146 removed package(s)
  • testing extra x86_64: 149 new and 162 removed package(s)
  • testing multilib x86_64: 25 new and 29 removed package(s)
A detailed list of package changes can be found here.
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Password boxes don't get focus in KDE
#2
Everything went fine. 119 packages.
Noticed this but only on KDE:
warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
warning: /etc/drirc installed as /etc/drirc.pacnew
error: could not remove database entry flatpak-0.9.8-1
error: could not remove entry 'flatpak' from cache
#3
I got this error. Am I missing something.
warning: cannot resolve "glibc>=2.26", a dependency of "lib32-glibc"
: The following package cannot be upgraded due to unresolvable dependencies:
      lib32-glibc
#4
I got the same errors on KDE Unstable, but since I do not believe I have ever used flatpak, I do not think they will affect me immediately. I do know that after re-booting, nothing is obviously broken.
#5
Pacnew files are nothing to worry about, just updated conf files that didn’t overwrite your existing ones, and probably should be viewed and merged.
I got a conflict message at the start of my update, asking if I wanted to replace flatpak with flatpak-builder. I said yes and flatpak was removed, here is the pacman.log confirmation.
[2017-09-11] [ALPM] removed flatpak (0.9.8-1)
I got one error during mkinitcpio
[2017-09-11] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: n5pf
Not sure what n5pf is, will have to investigate.
Apart from that, smooth update, many thanks.
#6
This has something to do with a Cavium NITROX Crypto Device. The firmware was added in August, but the current linux-firmware is form June. It will resolve eventually.
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git/tree/drivers/crypto/cavium/nitrox/Kconfig?h=v4.13.1
#7
Thanks to everyone who contributes testing upstream from the stable release - we really appreciate it!
More power to you all.
Ruziel :slight_smile:
#8
No issues xfce. Good update
#9
You should probably integrate the drirc.pacnew into your drirc ( or simply do a sudo mv /etc/drirc.pacnew /etc/drirc )
that one adds the mesa_glthread parameters for compatible games and applications, which boosts the performance of those a lot.
#10
I got an error at configuring fontconfig:
(16/59) Aktualisiere fontconfig        [########################################################################################################################] 100%
Rebuilding fontconfig cache...
Fehler: Befehl konnte nicht korrekt ausgeführt werden
Where can i find this log while pacman is configuring?
And found another one in /var/log/pacman.log some days old:
[2017-09-03 21:43] [ALPM] upgraded perl-error (0.17025-1 -> 0.17025-2)
inxi:
#11
Me neither, but that error was present on my testing and one of unstable installs, but not on a VBox unstable install. Anyway all seems fine.
Indeed, i start to love Kompare and helps me to identify stuff really quick and take measures.
Thanks, i done it right after. Last game i played was Mirrors Edge, and if i recall correctly was in 2009, but i do care how applications run, so is good to have all the updates on my machine. :smiley:
Cheers! I really love this community!
#12
I got the following error:
warning: removing 'gcc-libs' from target list because it conflicts with 'gcc-libs-multilib'
warning: removing 'gcc' from target list because it conflicts with 'gcc-multilib'
:: gcc-fortran: requires gcc=7.2.0-2
removing gcc-fortran solved this issue, not sure if I even need the package.
Thanks for the update!
#13
None of feral games start after this update. Looking what’s problem havent found yet.
edit: Found solution
#14
This particular “conflict” has been annoying me as well.
There’s a gcc-fortran-multilib package that should solve the problem in a different way.
#15
Well - it seems this update did not turn out all to well for me.
First of on boot gdm is complaining about something glib related:
Sep 12 10:24:56 hk-01 gdm[728]: GLib: g_variant_new_string: assertion 'string != NULL' failed
Sep 12 10:24:56 hk-01 gdm[728]: GLib: g_hash_table_find: assertion 'version == hash_table->version' failed
And 2nd suspend to ram is broken - when waking up the latops screen backlight turns on, but the screen stays black. - I will try to find something useful for debuging - in the meanwhile if someone knows where to look, let me know please.
EDIT: Well well - did what I alsway do when the system acts strangely. Reinstalled ALL packages and removed the latest kernel and now it works again. Good update now!
#16
Also having issues with multilib, on manjaro-openrc.
warning: removing ‘gcc-libs’ from target list because it conflicts with 'gcc-libs-multilib’
:: gcc: requires gcc-libs=7.2.0-2
#17
On Manjaro-openrc, the upgrade from glibc-2.25-7-x86_64 to glibc-2.26-3-x86_64 broke all kernels on my desktop computer except for linux-rt-lts-manjaro 4.9 (which I could use to downgrade glibc).
I was getting:
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt
#18
@mu3r73: This might explain a few things
#19
Well I cheered to early - system is unable to wake up from suspend to ram again:
Sep 12 23:25:45 hk-01 kernel: DMAR: DRHD: handling fault status reg 3
Sep 12 23:25:45 hk-01 kernel: DMAR: [DMA Write] Request device [00:02.0] fault addr 49f7000 [fault reason 23] Unknown
Sep 12 23:25:45 hk-01 kernel: DMAR: DRHD: handling fault status reg 2
Sep 12 23:25:45 hk-01 kernel: DMAR: [DMA Write] Request device [00:02.0] fault addr 49f9000 [fault reason 23] Unknown
Sep 12 23:25:45 hk-01 kernel: DMAR: [DMA Write] Request device [00:02.0] fault addr 49fc000 [fault reason 23] Unknown
Sep 12 23:25:50 hk-01 ntpd[7689]: bind(21) AF_INET6 fe80::6257:18ff:fe93:9ab3%2#123 flags 0x11 failed: Cannot assign requested address
Sep 12 23:25:50 hk-01 ntpd[7689]: unable to create socket on wlp3s0 (5) for fe80::6257:18ff:fe93:9ab3%2#123
Sep 12 23:25:51 hk-01 ntpd[7689]: bind(24) AF_INET6 fe80::6257:18ff:fe93:9ab3%2#123 flags 0x11 failed: Cannot assign requested address
Sep 12 23:25:51 hk-01 ntpd[7689]: unable to create socket on wlp3s0 (6) for fe80::6257:18ff:fe93:9ab3%2#123
Sep 12 23:27:57 hk-01 kernel: [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe A FIFO underrun
Sep 12 23:29:16 hk-01 gdm[808]: GLib: g_variant_new_string: assertion 'string != NULL' failed
Sep 12 23:29:16 hk-01 login[7755]: pam_systemd(login:session): Failed to release session: Interrupted system call
Sep 12 23:29:17 hk-01 gdm[808]: GLib: g_hash_table_find: assertion 'version == hash_table->version' failed
Sep 12 23:29:17 hk-01 kernel: wlp3s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22)
Sep 12 23:29:19 hk-01 kernel: watchdog: watchdog0: watchdog did not stop!
DMA or something and intel driver also playing into the game -.-
Any help would be highly appreciated
inxi -F output:
System:    Host: hk-01 Kernel: 4.13.1-1-MANJARO x86_64 bits: 64
           Desktop: Gnome 3.24.3 Distro: Manjaro Linux
Machine:   Device: laptop System: LENOVO product: 20BWS03F00 v: ThinkPad T450s serial: N/A
           Mobo: LENOVO model: 20BWS03F00 v: NO DPK serial: N/A
           UEFI [Legacy]: LENOVO v: JBET65WW (1.29 ) date: 06/15/2017
Battery    BAT0: charge: 13.7 Wh 95.5% condition: 14.3/23.2 Wh (62%)
           BAT1: charge: 70.5 Wh 99.9% condition: 70.5/71.3 Wh (99%)
CPU:       Dual core Intel Core i7-5600U (-HT-MCP-) cache: 4096 KB
           clock speeds: max: 3200 MHz 1: 2593 MHz 2: 2593 MHz 3: 2593 MHz
           4: 2593 MHz
Graphics:  Card: Intel HD Graphics 5500
           Display Server: x11 (X.Org 1.19.3 ) driver: i915
           Resolution: 1920x1080@60.02hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
           version: 4.5 Mesa 17.2.0
Audio:     Card-1 Intel Broadwell-U Audio Controller driver: snd_hda_intel
           Card-2 Intel Wildcat Point-LP High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.13.1-1-MANJARO
Network:   Card-1: Intel Ethernet Connection (3) I218-LM driver: e1000e
           IF: enp0s25 state: down mac: 50:7b:9d:7b:55:7d
           Card-2: Intel Wireless 7265 driver: iwlwifi
           IF: wlp3s0 state: up mac: 60:57:18:93:9a:b3
Drives:    HDD Total Size: 500.1GB (41.1% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 500.1GB
Partition: ID-1: / size: 446G used: 180G (43%) fs: ext4 dev: /dev/dm-0
           ID-2: swap-1 size: 13.54GB used: 0.00GB (0%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 36.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 240 Uptime: 5 min Memory: 1677.9/11804.4MB
           Client: Shell (bash) inxi: 2.3.38
#20
Looks like a kernel issue to me. Do you have an alternative installed? 412 maybe?
