Testing NVK drivers for Nouveau
(This is pretty easy if you want to try it.)
First, I added the following: nouveau.config=NvGspRm=1
to the
etc/modprobe.d/nouveau.conf
Then I installed vulkan-nouveau which requires mesa versions greater than 2.1. (Running 2.1.6)
Rebooted!!
The system boots normally with the mod to nouveau.conf now. It hung before.
But the info center says I am still using llvmpipe. And I still cannot run vkcube.
Should I expect this?
