Maybe I will have more luck here than on various search engines.
For some time now I have not been able to launch Borderlands 2 on my laptop. This is new behaviour, but I am not sure when exactly this started occuring (I don’t play regularly).
This is what terminal shows me when I launch Borderlands 2 on Steam
Running Steam on manjarolinux 21.1.0 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/olividir/.local/share/Steam/ubuntu12_32/steam
[2021-08-03 21:19:50] Startup - updater built Aug 3 2021 19:02:35
[2021-08-03 21:19:50] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1628019665)
[2021-08-03 21:19:50] Loading cached metrics from disk (/home/olividir/.local/share/Steam/package/steam_client_metrics.bin)
[2021-08-03 21:19:50] Using the following download hosts for Public, Realm steamglobal
[2021-08-03 21:19:50] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-08-03 21:19:50] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-08-03 21:19:50] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-08-03 21:19:50] Verifying installation...
[2021-08-03 21:19:50] Verification complete
Loaded SDL version 2.0.15-6693122
/usr/share/themes/Breath/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:13582): Gtk-WARNING **: 21:19:51.423: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breath/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0803/211951.622168:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0803/211951.659288:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0803/211951.659339:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1628017382
[0803/211951.659346:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0803/211951.659353:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0803/211951.709310:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0803/211951.709363:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1628017382
[0803/211951.709367:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0803/211951.709371:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0803/211951.709861:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0803/211951.819683:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0803/211951.819736:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1628017382
[0803/211951.819741:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0803/211951.819744:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0803/211951.820262:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CAppInfoCacheReadFromDiskThread took 49 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:13582): Gtk-WARNING **: 21:19:52.472: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 3536 bytes.
roaming config store loaded successfully - 3536 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 4ms
[0803/211953.930060:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0803/211954.007501:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0803/211954.085654:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/olividir/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 3.65 seconds
[0803/211954.525582:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0803/211954.542417:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
BuildCompleteAppOverviewChange: 132
RegisterForAppOverview 1: 6ms
RegisterForAppOverview 2: 6ms
[49520]Non-Steam Controller Configs Enabled: 1
Opted-in Controller Mask for AppId 49520: 0
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 49520, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 49520, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/olividir/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=49520 -- '/run/media/olividir/500 Gaming/SteamLibrary/steamapps/common/Borderlands 2/./Borderlands2'\0
Game update: AppID 49520 "", ProcID 13738, IP 0.0.0.0:0
ERROR: ld.so: object '/home/olividir/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 49520
>>> Adding process 13738 for game ID 49520
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/olividir/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 49520, ActionID 1] : LaunchApp changed task to Completed with ""
>>> Adding process 13739 for game ID 49520
Game update: AppID 49520 "", ProcID 13739, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 13739): SteamUser017 / User
RecordSteamInterfaceCreation (PID 13739): SteamFriends014 / Friends
RecordSteamInterfaceCreation (PID 13739): SteamUtils006 / Utils
RecordSteamInterfaceCreation (PID 13739): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 13739): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 13739): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 13739): STEAMAPPS_INTERFACE_VERSION006 / Apps
RecordSteamInterfaceCreation (PID 13739): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 13739): STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
RecordSteamInterfaceCreation (PID 13739): STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
RecordSteamInterfaceCreation (PID 13739): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 13739): STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
RecordSteamInterfaceCreation (PID 13739): STEAMCONTROLLER_INTERFACE_VERSION / Controller
RecordSteamInterfaceCreation (PID 13739): STEAMUGC_INTERFACE_VERSION001 / UGC
Setting breakpad minidump AppID = 49520
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198038982991 [API loaded no]
>>> Adding process 13743 for game ID 49520
>>> Adding process 13758 for game ID 49520
Installing breakpad exception handler for appid(gameoverlayui)/version(20210803190238)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
[0803/212005.948341:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Game removed: AppID 49520 "", ProcID 13739
Game 49520 created interface STEAMAPPS_INTERFACE_VERSION006 / Apps
Game 49520 created interface STEAMCONTROLLER_INTERFACE_VERSION / Controller
Game 49520 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 49520 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
Game 49520 created interface STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
Game 49520 created interface STEAMUGC_INTERFACE_VERSION001 / UGC
Game 49520 created interface STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
Game 49520 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 49520 created interface SteamFriends014 / Friends
Game 49520 created interface SteamMatchMaking009 / Matchmaking
Game 49520 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 49520 created interface SteamNetworking005 / Networking
Game 49520 created interface SteamUser017 / User
Game 49520 created interface SteamUtils006 / Utils
Game 49520 method call count for IClientRemoteStorage::GetQuota : 1
Game 49520 method call count for IClientUserStats::RequestCurrentStats : 1
Game 49520 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 49520 method call count for IClientAppManager::GetAppStateInfo : 1
Game 49520 method call count for IClientAppManager::BIsDlcEnabled : 1
Game 49520 method call count for IClientUtils::RecordSteamInterfaceCreation : 14
Game 49520 method call count for IClientUtils::GetAppID : 17
Game 49520 method call count for IClientFriends::GetFriendPersonaName_Public : 1
Game 49520 method call count for IClientFriends::GetFriendRichPresence : 1
Game 49520 method call count for IClientFriends::SetRichPresence : 1
Game 49520 method call count for IClientFriends::GetFriendGamePlayed : 1
Game 49520 method call count for IClientFriends::GetFriendByIndex : 1
Game 49520 method call count for IClientFriends::GetFriendCount : 1
Game 49520 method call count for IClientFriends::GetFriendPersonaState : 1
Game 49520 method call count for IClientFriends::GetPersonaName : 1
Game 49520 method call count for IClientUser::BIsSubscribedApp : 4
Game 49520 method call count for IClientUser::GetSteamID : 2
Game 49520 method call count for IClientUser::BLoggedOn : 2
Uploaded AppInterfaceStats to Steam
Exiting app 49520
No cached sticky mapping in ActivateActionSet.
(process:13785): GLib-GObject-CRITICAL **: 21:20:15.576: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Exiting workitem thread
(steam:13582): GLib-GObject-CRITICAL **: 21:30:53.514: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:13582): GLib-GObject-WARNING **: 21:30:53.516: invalid (NULL) pointer instance
(steam:13582): GLib-GObject-CRITICAL **: 21:30:53.516: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:13582): GLib-GObject-CRITICAL **: 21:30:53.517: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2021-08-03 21:30:53] Shutdown
Maybe someone has encountered similar problem and found a solution, I for once am having difficulties finding something that works. I have tried few launch commands I have found on few threads on Reddit.
So far, this is the only game that is not launching from my library. The game did launch without a problem few weeks ago.
I am very bad at seeing reading through these logs and I am not sure which error I should really look into.
Inxi
Kernel: 5.13.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1c142e9a-0f6d-4249-a9c9-c0091c0fdbf8 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
date: 04/21/2020
ID-1: BAT1 charge: 0% condition: 28.7/52.8 Wh (54.4%) volts: 12.5 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Unknown
RAM: total: 15.52 GiB used: 5.06 GiB (32.6%)
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 36812
Speed: 2358 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 2358 2: 1602
3: 954 4: 900 5: 1097 6: 900 7: 961 8: 919
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 05c8:03bc class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.4:7 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b822 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 05:00.0
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:5 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Local Storage: total: 1.6 TiB used: 688.41 GiB (42.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CXB73H1Q temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 0740 size: 465.73 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1007 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
model: External USB 3.0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 5438 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 119.73 GiB (51.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 1c142e9a-0f6d-4249-a9c9-c0091c0fdbf8
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: D7A9-849E
ID-3: /run/media/olividir/500 Gaming raw-size: 465.73 GiB
size: 457.42 GiB (98.22%) used: 350.93 GiB (76.7%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: 500 Gaming uuid: de409be9-45c3-41ba-973e-edb56ccb5ee2
ID-4: /run/timeshift/backup raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 217.74 GiB (23.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: 1TB_Backup uuid: 36188c27-123c-4a32-8813-b60224d6cc58
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.1:4 info: MOSART Semi. 2.4G Wireless Mouse
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 3938:1047 class-ID: 0301
Device-2: 1-2.2:6 info: HP ENVY 4520 series type: Printer driver: usblp
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 2mA chip-ID: 03f0:d711
class-ID: 0701 serial: <filter>
Device-3: 1-2.4:7 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-4: 1-5:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide Vision
HD Integrated Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-5: 1-14:5 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Western Digital My Passport Essential (WDBACY)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:0740 class-ID: 0806 serial: <filter>
Device-2: 2-3:3 info: Toshiba America MQ04UBF100 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0900 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 59.0 C mobo: 29.8 C gpu: nvidia temp: 52 C
Processes: 321 Uptime: 3h 57m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
pacman: 1408 lib: 391 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
Thanks for the help in advanced
P.S. I have tried proton-ge as well, that didn’t work either.
