Terminus font name fix after freetype2 update to 2.7.1-1
font
#21
Yeah, you’re right, it matches DejaVu Sans.
I guess there’s another alias to correct, can you tell me which one?
#22
Maybe you need to update font cache with sudo fc-cache -r? Or maybe logout and login? On my system it works with urxvt as I wrote in OP.
EDIT. Don’t forget to create a symlink in /etc/fonts/conf.d/
#23
Symlink is in place, ran fc-cache, rebooted. No…
I will check other files in /etc/fonts/conf.d
Do you have a file named 75-yes-terminus.conf in there?
EDIT: Problem identified. It was either yes-terminus or no-bitmaps.conf. Removing symlink fixed the problem.
#24
No, I don’t. I have 70-yes-bitmaps.conf.
#25
Are you sure this line in your PKGBUILD is OK?
install -Dm755 "$srcdir/$pkgname/mhwd-tui" "$pkgdir/usr/bin/mhwd-tui"
#26
No, it was just a placeholder. I had working pkgbuild that I offered to the repos
# Maintainer: Chrysostomus @forum.manjaro.org
 pkgname=terminusfix
 pkgver=0.1
 pkgrel=1
 pkgdesc="A simple alias for terminus-font"
 arch=(any)
 url="https://github.com/Chrysostomus/$pkgname"
 license=('MIT')
 depends=('bash')
 makedepends=('git')
 source=("git://github.com/Chrysostomus/$pkgname")
 md5sums=('SKIP')
 package () {
 	cd "$srcdir"
         install -Dm755 "$srcdir/$pkgname/33-TerminusPcfFont.conf" "$pkgdir/etc/fonts/conf.d/33-TerminusPcfFont.conf"
But we instead decided to integrate the alias to the terminus package itself so everyone should get it automatically
#27
I see. Also, does -Dm755 set executable permission to .conf file? Why? Maybe I am wrong.
#28
A typo. But yes, very much not necessary.
#29
No, not necessary, fonts configs are 644 IIRC.
