Can't play DVDs with media players, returning libva error
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F21 date: 02/08/2018
  Device-1: ps-controller-battery-d0:bc:c1:d2:d1:f4 model: N/A serial: N/A
    charge: N/A status: full
  System RAM: total: 16 GiB available: 15.57 GiB used: 3.73 GiB (23.9%)
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001129
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 1726 high: 3200 min/max: 1550/3200 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550
    3: 2715 4: 1550 5: 3200 6: 1550 7: 1374 8: 1550 9: 1375 10: 1375 11: 1375
    12: 1550 bogomips: 76674
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
    lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300
  Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0894
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
    memory: 2.93 GiB
  API: Vulkan v: 1.3.264 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1060 3GB driver: nvidia v: 535.113.01 device-ID: 10de:1c02
    surfaces: xcb,xlib
  Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Sony DualSense wireless controller (PS5)
    driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 054c:0ce6 class-ID: 0300
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off tools: jack_control
  Server-3: PipeWire v: 0.3.81 status: off with: 1: pipewire-media-session
    status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
    v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-3: Sony DualSense wireless controller (PS5)
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 3.41 TiB used: 1.17 TiB (34.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
    dev-links: cdrom
  Features: speed: 62 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 185.32 GiB (81.3%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 40809886-d17c-433b-876f-89a03d053b64
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
    uuid: E832-7B45
  ID-3: /run/media/nicholas/NBX0NNW1 raw-size: 7.15 GiB
    size: 7.15 GiB (99.99%) used: 7.15 GiB (100.0%) fs: udf block-size: 2048 B
    dev: /dev/sr0 maj-min: 11:0 label: NBX0NNW1 uuid: 38ec281900000000
  ID-4: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 810.75 GiB (88.5%) fs: ext4 dev: /dev/sdd
    maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
  ID-5: /run/media/nicholas/second disk raw-size: 434.51 GiB
    size: 426.62 GiB (98.18%) used: 195.66 GiB (45.9%) fs: ext4 dev: /dev/sdc2
    maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
  ID-6: /run/media/nicholas/third-disk raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 10.93 GiB (0.6%) fs: ext4 dev: /dev/sda
    maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
  ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
    uuid: 14863704-322a-453c-b7a5-87bba34bb094
  Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Device-2: 1-2:3 info: Logitech CrystalCam type: video,audio
    chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
  Device-3: 1-3:4 info: Sony DualSense wireless controller (PS5)
    type: audio,HID driver: playstation,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
  Device-1: 3-3:2 info: Ducky One 3̠ type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 40.1 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 355 Uptime: 5m wakeups: 1 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2366
  pm: pacman pkgs: 2352 libs: 583 tools: gnome-software,pamac pm: flatpak
  pkgs: 5 pm: snap pkgs: 9 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.30
As the title says I’m having problems playing DVDs with any media player. First I tired VLC and it would automatically try to play the DVD then crash, then mpv, kaffeine, and dragon did the same thing. The error is the same for all of them.
glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
Seems like hardware acceleration is failing.
Usually, and I mean in most cases and even without this particular error, VLC needs to be set to a decent working backend, as its ‘automatic’ is … flaky.
That you tried other players throws this into a question a bit.
Lets take a look at some packages:
pacman -Qs 'libva|vdpau|nvidia'
PS.
This looks like a BIOS in need of updating.
Here’s the output of that command
local/egl-wayland 2:1.1.12-1
    EGLStream-based Wayland external platform
local/lib32-libva 2.20.0-1
    Video Acceleration (VA) API for Linux (32-bit)
local/lib32-libva-vdpau-driver 0.7.4-7
    VDPAU backend for VA API (32-bit)
local/lib32-libvdpau 1.5-2
    Nvidia VDPAU library
local/lib32-mesa-vdpau 1:23.1.9-1
    VDPAU drivers (32-bit)
local/lib32-nvidia-utils 535.113.01-1
    NVIDIA drivers utilities (32-bit)
local/libva 2.20.0-1
local/libva-mesa-driver 1:23.1.9-1
    VA-API drivers
local/libva-vdpau-driver 0.7.4-6
local/libvdpau 1.5-2
local/libxnvctrl 535.113.01-1
    NVIDIA NV-CONTROL X extension
local/linux419-nvidia 535.113.01-2 (linux419-extramodules)
    NVIDIA drivers for linux
local/linux510-nvidia 535.113.01-2 (linux510-extramodules)
local/linux515-nvidia 535.113.01-2 (linux515-extramodules)
local/linux61-nvidia 535.113.01-2 (linux61-extramodules)
local/mesa-vdpau 1:23.1.9-1
    VDPAU drivers
local/mhwd-nvidia 535.113.01-2
    MHWD module-ids for nvidia 535.113.01
local/mhwd-nvidia-390xx 390.157-8
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.199.02-4
    MHWD module-ids for nvidia 470.199.02
local/nvidia-utils 535.113.01-2
local/vala 0.56.13-1
    Compiler for the GObject type system
local/vamp-plugin-sdk 2.10.0-2 (pro-audio)
    The Vamp audio analysis plug-in system
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards
Thanks for the bios update recommendation, I’ll see if I can do that now.
pacman -Qi libva
Version         : 2.20.0-1
Description     : Video Acceleration (VA) API for Linux
Architecture    : x86_64
URL             : https://01.org/linuxmedia/vaapi
Licenses        : MIT
Groups          : None
Provides        : libva-drm.so=2-64  libva-glx.so=2-64  libva-wayland.so=2-64
                  libva-x11.so=2-64  libva.so=2-64
Depends On      : libdrm  libgl  libx11  libxext  libxfixes  wayland
Optional Deps   : intel-media-driver: backend for Intel GPUs (>= Broadwell)
                  libva-intel-driver: backend for Intel GPUs (<= Haswell)
                  libva-mesa-driver: backend for AMD and NVIDIA GPUs [installed]
Required By     : ffmpeg  ffmpeg4.4  gst-plugins-bad-libs  lib32-libva  onevpl
                  qt6-multimedia-ffmpeg  steam-native-runtime
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 899.79 KiB
Packager        : Maxime Gauduin <alucryd@archlinux.org>
Build Date      : Fri 15 Sep 2023 10:15:31 AM CDT
Install Date    : Sat 14 Oct 2023 08:51:26 PM CDT
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
Uninstalling and then reinstalling VLC should also reinstall many dependencies needed by other multimedia applications.
Uninstall VLC:
sudo pacman -R vlc
Now, we reinstall VLC while also performing an upgrade:
sudo pacman -Syyu vlc
Now, try to play a DVD. This will either work now, or it won’t.
Note that if you see errors related to downgrading ffmpeg, that’s another issue currently being attended to. Cheers
Error persists. Thank you for your help still.
Found, at least, a temporary fix from this thread.
Removing libva-vdpau-driver as shared in the solution works for now.
Remember not to select it in VLC then. :wink:
Interesting to note; I’m not experiencing this at all in KDE, stable, v6.1 LTS kernel; system fully updated and current.
