Terminal name ends with tobefilledbyoem
The displayed name in my Terminal is sebastian@sebastian-tobefilledbyoem, but I double checked my System Settings -> Account Details and the name there is correct.
I didn’t find anything about it.
Any hints?
Try sudo hostnamectl set-hostname WHATEVERYOUWANT.
“$USERNAME-To be filled by OEM(Original Equipment Manufacturer)” is a funny hostname though.
@argentinaseby … did you install the system yourself?
Out of curiosity, could you post the output of cat /sys/devices/virtual/dmi/id/modalias?
This worked perfectly fine
