GNOME seems to crash, taking to much processes with it
I experience a strange and extremely annoying behaviour. I have a manjaro box on an iMac 27" using GNOME. Some time after the WM goes into power saving, it seems my desktop session dies. Along with it goes my tmux which is supposed to survive this. I can’t see that it restarts which would explain the absence of any tmux session but my knowledge is a bit outdated (I can’t really figure out why I can’t find many logs and why I have to use sudo even with a root shell when less /var/log/anything). So I’m not sure where to look and what I’m looking for. After most of these crashes GNOME has reset most of my display settings, activated a not attached monitor output and changed the resolution which sould never happen.
I tried to insert all the info that the manual asks for but then I can’t post this question because it complains about me trying to insert links. I coul’d not find any links in the log and it does not tell in which line it thinks it found a link sou I either cant post od cant insert logs. Very strange.
Now it seems to work. No 420 error anymore, no complaining about links which aren’t there.
  Kernel: 5.15.145-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=b15bda12-8b9a-42aa-99d1-fbd5fbbaa682 rw quiet splash apparmor=1
    security=apparmor resume=UUID=e1ad7a27-4ee5-415b-a1c3-66990d898b67
    udev.log_priority=3
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop System: Apple product: iMac15,1 v: 1.0 serial: <filter>
    Chassis: type: 13 v: Mac-42FD25EABCABB274 serial: <filter>
  Mobo: Apple model: Mac-42FD25EABCABB274 v: iMac15,1 serial: <filter>
    UEFI: Apple v: 432.60.3.0.0 date: 10/27/2021
  System RAM: total: 8 GiB available: 7.7 GiB used: 3.82 GiB (49.7%)
  Array-1: capacity: 16 GiB slots: 4 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB speed: 1600 MT/s
    volts: N/A width: N/A manufacturer: 0x802C
    part-no: 0x384B54463531323634485A2D314736453220 serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 4 GiB speed: 1600 MT/s
  Device-3: DIMM1 type: no module installed
  Device-4: DIMM1 type: no module installed
  Info: model: Intel Core i7-4790K socket: LGA1150 (U3E1) note: check bits: 64
    type: MT MCP arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
    process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
    microcode: 0x28
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3992 high: 4000 min/max: 800/4400 base/boost: 4000/4000
    scaling: driver: intel_cpufreq governor: schedutil volts: 1.1 V
    ext-clock: 25 MHz cores: 1: 4000 2: 3991 3: 3991 4: 3990 5: 3991 6: 3991
    7: 3994 8: 3992 bogomips: 63876
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Curacao XT / Trinidad [Radeon R7 370 R9 270X/370X]
    vendor: Apple driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: eDP-1 off: DP-2 empty: DP-1,DP-3
    bus-ID: 01:00.0 chip-ID: 1002:6810 class-ID: 0300 temp: 43.0 C
  Device-2: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 05ac:8511
  Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 res: 3840x2160 hz: 60 dpi: 163
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
    direct-render: yes renderer: PITCAIRN ( LLVM 16.0.6 DRM 2.50
    5.15.145-1-MANJARO) device-ID: 1002:6810 memory: 1.95 GiB unified: no
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aab0 class-ID: 0403
  API: ALSA v: k5.15.145-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
    vendor: Apple driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
    chip-ID: 14e4:1686 class-ID: 0200
  IF: enp4s0f0 state: down mac: <filter>
  Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3:10
    chip-ID: 05ac:828d class-ID: fe01
  Local Storage: total: 1.93 TiB used: 67.01 GiB (3.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
    family: based SSDs size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 4B6Q
    temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 118d 14h cycles: 21558
    written: 13.73 TiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Apple model: SSD SD0128F
    family: SD/SM/TS...E/F/G SSDs size: 113 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 821 temp: 50 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 362d 11h cycles: 79568
  ID-1: / raw-size: 103.9 GiB size: 101.71 GiB (97.89%) used: 48.73 GiB (47.9%)
    fs: ext4 block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: b15bda12-8b9a-42aa-99d1-fbd5fbbaa682
    used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    label: NO_LABEL uuid: 6187-E188
  ID-3: /opt/steam raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 18.28 GiB (1.0%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: d40adff8-81a4-4d77-bf81-55f6127c14c9
    dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: e1ad7a27-4ee5-415b-a1c3-66990d898b67
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-2: 1-6:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    chip-ID: 1a40:0201 class-ID: 0900
  Hub-3: 1-6.3:4 info: Apple Keyboard Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
    chip-ID: 05ac:1005 class-ID: 0900
  Device-1: 1-6.3.2:7 info: Apple Aluminum Mini Keyboard (ISO)
    type: keyboard,HID driver: apple,usbhid interfaces: 2 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 20mA
    chip-ID: 05ac:021e class-ID: 0300
  Device-2: 1-6.5:6 info: Logitech MX Revolution Cordless Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c525 class-ID: 0300
  Device-3: 1-7:3 info: Apple FaceTime HD Camera (Built-in) type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
  Hub-4: 1-8:5 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
    Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 1-8.3:10 info: Apple Bluetooth Host Controller type: bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 05ac:828d class-ID: fe01
  Hub-5: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: radeon temp: 43.0 C
  Fan Speeds (rpm): N/A
  Processes: 322 Uptime: 53m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1699 libs: 403 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Sudo (sudo) v: 1.9.15p4 default: Bash v: 5.2.21 running-in: tmux:
  inxi: 3.3.31
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
One Post Wonder never returned.
