When the system starts, the laptop tries to connect to a 5 ghz wifi network, but it fails. After that, all 5 ghz networks simply disappear and it is possible to select only 2.4 ghz networks. I’ve probably tried everything I can, but I haven’t found a solution yet.
Everything is fine with the router, I can connect from the phone.
Device - Broadcom BCM43602 802.11ac Wireless LAN SoC
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fc4272d8-5d77-41a0-8182-f86aad5c9ad9 rw quiet splash apparmor=1
security=apparmor resume=UUID=fe9d3853-ac83-4475-b7bc-8a30099e8035
udev.log_priority=3
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0 serial: <filter>
Chassis: type: 9 v: Mac-E43C1C25D4880AD6 serial: <filter>
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1 serial: <filter>
UEFI: Apple v: 481.0.0.0.0 date: 01/12/2023
ID-1: BAT0 charge: 57.2 Wh (99.0%) condition: 57.8/74.8 Wh (77.3%)
volts: 12.8 min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 510
System RAM: available: 15.53 GiB used: 3.9 GiB (25.1%)
Array-1: capacity: 16 GiB note: est. slots: 2 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: 1867 MT/s
volts: N/A width (bits): data: 64 total: 64 manufacturer: 0x02FE
part-no: 0x4544464232333241314D412D4A442D460000 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: 1867 MT/s
Info: model: Intel Core i5-5257U socket: BGA1168 (U3E1) note: check bits: 64
type: MT MCP arch: Broadwell gen: core 5 level: v3 note: check built: 2015-18
process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 500/3100 base/boost: 3100/2700 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.1 V ext-clock: 25 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21608
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
class-ID: 0300
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: 1280x800 hz: 60
dpi: 112 gamma: 1.2 size: 290x180mm (11.42x7.09") diag: 337mm (13.3")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Iris Graphics 6100
(BDW GT3) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
Device-4: JMTek LLC. USB PnP Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0c76:1617 class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 05ac:8290
class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 233.76 GiB used: 56.98 GiB (24.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256F
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: JA1Q scheme: GPT
ID-1: / raw-size: 216.38 GiB size: 211.92 GiB (97.94%)
used: 56.98 GiB (26.9%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: fc4272d8-5d77-41a0-8182-f86aad5c9ad9
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: DD68-08EA
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: fe9d3853-ac83-4475-b7bc-8a30099e8035
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 1-1:2 info: JMTek LLC. USB PnP Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 0c76:1617 class-ID: 0300 serial: <filter>
Device-2: 1-2:3 info: A4Tech USB Device type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:3f29 class-ID: 0300
Device-3: 1-3:4 info: Apple Bluetooth Host Controller
type: keyboard,mouse,bluetooth driver: btusb interfaces: 6 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05ac:8290
class-ID: fe01
Device-4: 1-5:5 info: Apple Internal Keyboard/Trackpad (ISO)
type: HID,keyboard,mouse driver: apple,bcm5974,usbhid interfaces: 5 rev: 2.0
chip-ID: 05ac:0273 class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 72.0 C pch: 65.5 C mobo: N/A
Processes: 244 Uptime: 9m wakeups: 5 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1372
pm: pacman pkgs: 1353 libs: 366 tools: gnome-software,pamac pm: flatpak
pkgs: 19 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.27
