Temporary public topic, pending deletion
(Copy +pasted from the other Topic, since its unlisted now)
Hello Penguin,
You using a old Linux install from a total differend and old system and want to use it now on your total differend and new system?
I think the best way should be a clean install and only overwrite your Home partition after a fresh install, if you don’t want to reconfig your system.
2 posts were merged into an existing topic: Black screen after laptop update
