Temperature monitor does not work upon boot
I’ve added a temperature monitor widget to kde but for some reason I need to select the source of the readings after each boot so I can see the info. I added a video for better understanding
The Plugin is thermal monitor from kotelnik. There is an open issue but no answer so far: lm-sensors displayed as OFF when boot (#3) · Issues · Gurenko Alex / plasma-applet-thermal-monitor · GitLab
maybe someone here can provide me some idea or other plugin suggestion.
Install the plasma5-applets-thermal-monitor-git package from AUR.
http://aur.archlinux.org/packages/plasma5-applets-thermal-monitor-git
Same behavior with the package you suggested :confused:
Solution:
just a variable to be declared as array …
Read here:
