Hey. After Manjaro update (haven’t seen such fails before) start to observe random crashes of the Telegram (6.9.3).
Terminal outpute:
QEGLPlatformContext: Failed to create context: 3009
QRhiGles2: Failed to create temporary context
QRhiGles2: Failed to create context
error: empty dic file
Hash Manager Error : 2
qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
[h264 @ 0x55f8471a68c0] Increasing reorder buffer to 2
[libvpx-vp9 @ 0x55f83efeac00] v1.16.0
[libvpx-vp9 @ 0x55f84be173c0] v1.16.0
[h264 @ 0x55f848a51480] Increasing reorder buffer to 2
[h264 @ 0x55f84a5d8700] Increasing reorder buffer to 2
[h264 @ 0x55f84fced100] Increasing reorder buffer to 2
[h264 @ 0x55f8493bdb40] Increasing reorder buffer to 2
[h264 @ 0x55f851094a80] Increasing reorder buffer to 2
[h264 @ 0x55f84a82d200] Increasing reorder buffer to 2
[h264 @ 0x55f848ae5780] Increasing reorder buffer to 2
/usr/include/c++/16.1.1/semaphore:74: void std::counting_semaphore<__least_max_value>::release(std::ptrdiff_t) [with long int __least_max_value = 1; std::ptrdiff_t = long int]: Assertion '__update >= 0 && __update <= max() - __old' failed.
zsh: abort (core dumped) Telegram
Could be that I’ve missed some additional info about the error, so please direct me where to look
Impossible to say but as telegram is built on top of electron - one could speculate if you are in some kind of partial update state.
telegram-desktop v6.9.3-7 is currently only available in unstable branch.
So if you are using stable branch I would think it is a custom package?
Given that I am using unstable branch - I tested the package and it runs fine when I open it using Telegram on the commandline.
Just installed from the extra repo:
❯ pamac info telegram-desktop | grep -Ei 'Name|Version|Repository|Install Date'
Version : 6.9.3-2
Repository : extra
Install Date : fr, 26-jun-2026 22:02:22 +0300
The crash happens randomly when going through several posts with videos
telegram-desktop v6.9.3-7 is currently available in unstable branch.
I searched just telegram - that did not give me all info - sorry about that - you are correct telegram-desktop is in all branches - the version I used is the repackage of v6.9.3-7 pkgrel 7.
$ mbn info telegram-desktop -q
Branch : archlinux
Version : 6.9.3-7
Repository : extra
Build Date : Wed 24 Jun 2026 11:51:54
Packager : Sven-Hendrik Haase <svenstaro@archlinux.org>
Branch : unstable
Version : 6.9.3-7
Repository : extra
Branch : testing
Version : 6.9.3-2
Repository : extra
Build Date : Sat 13 Jun 2026 18:53:24
Packager : Felix Yan <felixonmars@archlinux.org>
Branch : stable
Version : 6.9.3-2
Repository : extra
If you really need telegram - the only suggestion I can make is to switch branch.
sudo pacman -Syu testing && sudo pacman -Syyu
Thanks for suggestion. Seems like just an issue of the current version on the stable branch. So I’ll just wait for it’s update and just spend less time on telegram
pamac build forkgram
Hard to tell the difference - but it doesn’t stop working at the drop of a hat
Lolix
27 June 2026 10:08
9
Incorrect, it is a Qt6 program
Teo
27 June 2026 11:41
10
The flatpak is always an option
Thanks. Let’s see will it help
Update: so far no crashes
Update_2: Was to fast with conclusions, crashed again
A post generated by AI has been deleted.
Found bug report related to the issue on the telegram github with comprehensive root cause analysis in case someone is interested
opened 11:28PM - 15 Jun 26 UTC
closed 04:49PM - 24 Jun 26 UTC
Follow-up to the closed #30833 (dismissed as "3rd party issue"). That report onl… y had an unsymbolized stack, so it was attributed to Arch's libstdc++. I symbolized the coredump and the abort is a **real semaphore over-release inside tdesktop's own streaming code** — the libstdc++ assertion is merely catching it. Filing a fresh, symbolized report since the other one is closed.
### Steps to reproduce
1. On a build using a hardened libstdc++ (Arch's `_GLIBCXX_ASSERTIONS`), open a streamed video and close the media viewer, **or** let a voice/audio message finish playing.
2. Telegram aborts (`SIGABRT`) — reproducible ~100% of the time on closing a video for several users in #30833.
[with long int __least_max_value = 1]: Assertion '__update >= 0 && __update <= max() - __old' failed.
### Symbolized backtrace
Symbolized against the exact Arch `6.9.3-2` binary (build-id `7914059cd4e15f803231c242b4ebeffeeae5b980`) via `debuginfod.archlinux.org`:
#3 abort
#4 std::__glibcxx_assert_fail
("…/semaphore", line 74,
"std::counting_semaphore<1>::release(std::ptrdiff_t)",
"__update >= 0 && __update <= max() - __old")
#5 std::counting_semaphore<1l>::release (__update=1) semaphore:74
#6 crl::semaphore::release lib_crl/crl/common/crl_common_semaphore.h:27
#7 Media::Streaming::File::Context::interrupt media/streaming/media_streaming_file.cpp:419
#8 Media::Streaming::File::stop (stillActive=false) media/streaming/media_streaming_file.cpp:483
#9 Media::Streaming::Player::stop (stillActive=false) media/streaming/media_streaming_player.cpp:794
#10 Media::Streaming::Player::stop media/streaming/media_streaming_player.cpp:628
#11 Media::Streaming::Player::~Player media/streaming/media_streaming_player.cpp:1027
#12 std::_Sp_counted_base::_M_release_last_use shared_ptr_base.h
#14 Media::View::OverlayWidget::Streamed::~Streamed media/view/media_view_overlay_widget.cpp:438
#19 Media::View::OverlayWidget::clearStreaming(bool) media/view/media_view_overlay_widget.cpp:1388
#20 Media::View::OverlayWidget::applyVideoQuality media/view/media_view_overlay_widget.cpp:5494
(reached from the quality-change rpl handler installed in OverlayWidget::initStreaming)
### Root cause
`Media::Streaming::File::Context::interrupt()` (`media_streaming_file.cpp:419`) calls `crl::semaphore::release()` → `std::counting_semaphore<1>::release(1)`. The binary semaphore is already at its max value (1), so the precondition `__update <= max() - __old` (`1 <= 1 - 1`) is violated → abort. I.e. a **double / redundant `release()`** on the streaming wakeup semaphore during media teardown.
This dump reaches the teardown via `applyVideoQuality → clearStreaming`, but the same `~Player → Player::stop → File::stop → Context::interrupt → semaphore.release()` path runs whenever a streamed item is closed or finishes — matching the reports of aborting right when an audio message finishes or a video is closed.
### Why this is a tdesktop bug, not a distro/libstdc++ bug
`_GLIBCXX_ASSERTIONS` does not introduce anything; it only makes the precondition violation fatal. On a libstdc++ built **without** assertions (e.g. the official static binary, which links the older el8 `15.2.1` libstdc++) the same `release()` is a **silent counter overflow / UB**, not a benign no-op. So the over-release is latent on every platform — the static build just hides it. That is why "use the static build" makes it merely *appear* fixed.
Suggested fix: make `Context::interrupt()` idempotent (skip `release()` when the wakeup is already signaled), or use a wakeup primitive without an upper-bound precondition.
### Expected behaviour
Closing / finishing streamed media does not abort.
### Actual behaviour
`SIGABRT` from `std::counting_semaphore<1>::release` precondition violation.
### Operating system
Arch / EndeavourOS, x86_64, Wayland and X11 both affected.
### Version of Telegram Desktop
6.9.x (6.9.2-1 and 6.9.3-2). 6.8.2 and earlier are unaffected.
### Installation source
Distribution package (Arch `extra`, hardened libstdc++ build).
I can provide the full 70-thread backtrace or test a patch.
