Hi!
I’m using Telegram native (3.6.1), and I noticed it crashes when starting a voice call.
Also, I noticed that installing the snap version (3.7.3), it works perfectly.
Is there any plan to keep the Telegram packages up to date, avoiding this?
Thanks, and best regards,
HeCSa.
Hi @hecsa,
like you can see in Manjaro - Branch Compare ‘telegram-desktop’ is at 3.7.3 in testing-branch.
So it would came soon in stable. I guess 1-2 weeks.
If you need it right now you have the possibility to switch to testing-branch.
Hi @kisun !
Thanks a lot for your quick answer!
I’ll continue using the snap version until the native arrives.
Best regards,
HeCSa.
