I have a problem, I noticed that the FPS in games was below normal, I had the cool-bits enabled but the GPU fan is only locked at 25% and I can’t change it either through Nvidia settings or using GWE.
Do you have hysteresis enabled in GWE? I can’t use it on my 1080 Ti, it causes the fans to get stuck at certain speeds.
How can i check it?
In its settings, of course
