Teamviewer is blurred/fuzzy
#1
Hello. I am using Manjaro 64bit with KDE as my desktop environment. Here is how my teamviewer looks like.
Note: I downloaded from https://aur.archlinux.org/packages/teamviewer/ here.
Then made pkg using terminal as in other apps. then enabled teamviewerd in systemctl.
Then ran Teamviewer. but still no luck. Please help.
#2
Maybe you want try teamviewer 14 from comminuty of teamvierwer you can download from teamviewers webpage
download–>here
Instructions to install–>here
Lycka till! :smiley:
#3
the version available from the AUR is 14 already.
#4
Have you used the PKGBUILD?
Have you applied scaling or dpi changes?
#5
It looks like a problem with font settings. Maybe subpixel order?
