Riding the struggle bus here fam. Assistance would be appreciated.
Hardware:
Manjaro (latest)
2 Graphics Cards
Main: GeForce 2080ti
Primary Monitor BENQ (working great)
Secondary: GeForce 1080
Secondary Monitor HP VH240A
OS Install and steps so far
- Booted to live (only primary monitor working)
- Installed Manjaro
- Rebooted into new install (only primary monitor working)
- Ran all updates
- Rebooted
- Error Failed to start simple desktop display manager
- CTRL ALT F2
- sudo mhwd -a pci nonfree 0300
- It compiles and eventually monitors go black. Wait a while for good measure. I enter sudo reboot now enter.
- Reboots, loads plasma great. (only primary monitor working)
- Open System Settings -> Display and Monitor -> Select first HP monitor from list -> Check Enabled -> Clicked Apply -> Nothing happens
- Try the other monitors -> System Settings app crashes.
- Restart System Settings app and none of my previous settings were saved. More attempted ended with another System Settings app crash.
- Tried learning to use xrandr and used “xrandr --output DP-1-3 --auto --right-of DP-0” and got the following error:
xrandr: Configure crtc 4 failed
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x0
Serial number of failed request: 82
Current serial number in output stream: 82
So I’m worried any more tinkering I do will lose me my primary display which will leave me with my only recourse being a reinstall which will potentially lose me this learning opportunity. Any help you guys can provide will be appreciated. Here are some various outputs that might be useful:
lspci | grep VGA
03:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1)
lsmod | grep "kms\|drm"
nvidia_drm 57344 31
nvidia_modeset 1220608 24 nvidia_drm
drm_kms_helper 262144 1 nvidia_drm
cec 73728 1 drm_kms_helper
drm 589824 20 drm_kms_helper,nvidia_drm
agpgart 53248 1 drm
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
find /dev -group video
/dev/dri/card1
/dev/dri/card0
/dev/fb0
cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=0dc8fa2c-7f7b-453c-9dd1-b925351a54bb rw quiet cryptdevice=UUID=4703aac2-3571-4506-9b9b-ece539eabf3a:luks-4703aac2-3571-4506-9b9b-ece539eabf3a root=/dev/mapper/luks-4703aac2-3571-4506-9b9b-ece539eabf3a apparmor=1 security=apparmor udev.log_priority=3
find /etc/modprobe.d/
/etc/modprobe.d/
/etc/modprobe.d/mhwd-gpu.conf
cat /etc/modprobe.d/*kms*
cat: '/etc/modprobe.d/*kms*': No such file or directory
ls /etc/X11/xorg.conf.d
00-keyboard.conf 30-touchpad.conf 90-mhwd.conf
glxinfo | grep -i "vendor\|rendering"
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_packed_float_linear, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_buffer_object,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
grep LoadModule /var/log/Xorg.0.log
[ 9.462] (II) LoadModule: "glx"
[ 9.485] (II) LoadModule: "nvidia"
[ 9.503] (II) LoadModule: "fb"
[ 9.505] (II) LoadModule: "wfb"
[ 9.507] (II) LoadModule: "ramdac"
[ 9.513] (II) LoadModule: "glxserver_nvidia"
[ 12.703] (II) LoadModule: "dri2"
[ 12.723] (II) LoadModule: "dri2"
[ 12.790] (II) LoadModule: "libinput"
xrandr -q
Screen 0: minimum 8 x 8, current 3839 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm panning 3839x1080+0+0
1920x1080 60.00 + 144.00* 119.98 99.93 59.94 50.00
1440x900 119.85
1280x1024 75.02
1280x960 99.78
1280x720 60.00 59.94 50.00
1024x768 119.99 75.03 60.00
800x600 119.97 99.66 75.00 60.32
720x576 50.00
720x480 59.94
640x480 119.52 99.77 75.00 59.93 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
DVI-D-1-0 disconnected
HDMI-1-0 connected
1920x1080 60.00 + 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
HDMI-1-1 connected
1920x1080 60.00 + 60.00 59.94 50.00 23.98 60.00 50.04
1680x1050 59.95
1360x768 60.02
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-1-0 disconnected
DP-1-1 connected
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-1-2 disconnected
DP-1-3 connected
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
1920x1080 (0x1be) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1c2) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c3) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1280x720 (0x1c7) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c8) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1c9) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x1cc) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d0) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1d1) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d2) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d7) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d6) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
