Target not found: masterpdfeditor-free
Trying to get master pdf editor in Aur, so
 sudo pamac search -a  masterpdfeditor
masterpdfeditor-free        4.3.89-1  AUR
    A complete solution for creation and editing PDF files - Free version without
    watermark
masterpdfeditor        5.8.06-1  AUR
    A complete solution for viewing, creating and editing PDF files
$ sudo pamac install masterpdfeditor-free
Error: target not found:  masterpdfeditor-free
How can be just was found then denied, how to solve it ?
You are using pamac wrongly.
  1. It should not be used with sudo.
  2. The pamac command for installing a package from the AUR is not install but build.
pamac build masterpdfeditor-free
so what install there for ?
For repo packages.
Ones that actually come from Manjaro maintainers and Manjaro mirrors.
