Hello,
My laptop (Asus FX505DT) is taking a long time to shutdown (around 60 seconds).
Here is the output of inxi -Fxxxz
❯ inxi -Fxxxz
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3 tk: Gtk 3.24.23
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505DT.310 date: 12/24/2019
Battery: ID-1: BAT0 charge: 26.9 Wh condition: 39.6/48.1 Wh (82%) volts: 10.9/11.7 model: FX50442 type: Li-ion serial: N/A
status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+ rev: 1
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33552
Speed: 1355 MHz max: 1400 MHz boost: disabled Core speeds (MHz): 1: 1347 2: 1285 3: 1227 4: 1236 5: 1315 6: 1327
7: 1362 8: 1297
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1f91
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:15d8
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-1:2 chip ID: 13d3:56e5
serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati,modesetting,nouveau alternate: fbdev,nv,vesa
resolution: 1920x1080~120Hz s-dpi: 96
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.3
direct render: Yes
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10fa
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtw_8822ce v: N/A
port: d000 bus ID: 04:00.0 chip ID: 10ec:c822
IF: wlp4s0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 175.96 GiB (36.9%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: P1MA0V4 scheme: GPT
Partition: ID-1: / size: 196.25 GiB used: 175.93 GiB (89.6%) fs: ext4 dev: /dev/nvme0n1p4
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 47.6 C mobo: N/A
GPU: device: amdgpu temp: 47.0 C device: nouveau temp: N/A
Info: Processes: 261 Uptime: 15m Memory: 13.67 GiB used: 2.70 GiB (19.8%) Init: systemd v: 246 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: 1594 pacman: 1591 snap: 3 Shell: fish v: 3.1.2 running in: server inxi: 3.1.08
The logs obtained using journalctl -b -1 | rg -i -A99999 "system is powering down"
are available at pastebin (due to size limits).
Almost all the time is spent in some logs related to nouveau. I am unable to find out how to resolve these.
Some of the things that I have tried:
- Reinstalling nouveau.
- Trying both 5.9 and 5.8 kernels
Can someone please guide me as to how can I fix this.
Thanks!
