Systemd timer crashing my system at midnight
I’m not entirely sure but there happens to be 3 systemd timers enabled on the system and I’ve been having problems with it crashing at midnight. I thought I’d disable them one at a time to figure out which might be causing it when it happens… I used stop and disable, yet somehow it’s been enabled again, maybe due to a system update? How can I avoid that from happening?
These crashes are a hard lockup, I cannot change tty, I cannot do anything with the system. My browser doesn’t recover the tabs instead recovering what it did from my previous boot, I think the system might have restored itself in some way where that info after boot was lost?(haven’t verified elsewhere beyond session data) Major pain since I can’t recall if anything lost might have been valuable :\
It might be possible that it’s related to the 2nd suspend/resume cycle bug I have with the same symptoms for kernels 4.9 and higher. Potentially a power management bug?
Is there anything useful in the logs that might indicate what causes the crash? You can search them using journalctl:
https://wiki.archlinux.org/index.php/systemd#Filtering_output
No, journal shows only activity 7 mins prior to midnight. Any other ideas?
So when you had it handled before which systemd timer was it?
I forgot to note it down, I disabled both logrotate and shadow timers tonight, no crash at midnight, will enable shadow and see if I crash or not.
Is there a way to figure out why it crashes or prevent the system enabling it again by update or whatever else caused it to be enabled after I explicity stop and disable via systemctl? The lack of a log makes it difficult :confused:
Good question, you can look in /etc/systemd/system or /etc/systemd/user to see what has been updated recently. I did look at mine and there were some updates in March but nothing that looked like a likely suspect. Did you write your own systemd unit files? Anyway it seems strange that anything would be scheduled at exactly midnight, I can not find any here on my machine. hmmmm
Try using
sudo systemctl list-timers --all
to see which timers are executed at midnight and then use
locate *.timer
to find the *.timer files and their *.service files. I find most of them are located in
/usr/lib/systemd/system/
Have a look inside the timer and service files to see what they are doing. You could try to run the commands manually to see if one of those crashes your system.
Had some time to look into this a bit. It’s logrotate service. Seems fine when forced the first time, when done a 2nd time it causes the hard freeze. I guess the timer might fire it off and fail so try a 2nd time? All logs just have two lines for the service of it being started each time.
cat /var/lib/logrotate.status:
logrotate state -- version 2
"/var/log/wtmp" 2017-3-28-20:0:0
"/var/log/btmp" 2017-3-28-20:0:0
ls -l /var/log:
-rw-------  1 root utmp                 0 Mar 26 00:00 btmp
-rw-------  1 root utmp                20 Mar 25 17:37 btmp.1.gz
-rw-rw-r--  1 root utmp             58752 Mar 28 19:58 wtmp
-rw-rw-r--  1 root utmp             18847 Mar 10 15:41 wtmp.1.gz
You can see the dates are a bit inconsistent. Here is the /etc/logrotate.conf:
# see "man logrotate" for details
# rotate log files weekly
weekly
# keep 1 weeks worth of backlogs
rotate 1
# restrict maximum size of log files
size 12M
# create new (empty) log files after rotating old ones
create
# uncomment this if you want your log files compressed
compress
# Logs are moved into directory for rotation
# olddir /var/log/archive
# Ignore pacman saved files
tabooext + .pacorig .pacnew .pacsave
# Manjaro packages drop log rotation information into this directory
# include /etc/logrotate.d
/var/log/wtmp {
    weekly
    create 0664 root utmp
	minsize 512K
    rotate 1
/var/log/btmp {
    missingok
    weekly
    create 0600 root utmp
    rotate 1
I commented out the include to verify that it was still happening despite the extra config in /etc/logrotate.d/, which it does. Next I ran the unit via a different tty without the DE, instead of locking up after the command a bunch of dmesg output was spat out, unfortunately it freezes afterwards and I can only see what is on screen. I tried to output this over SSH to my phone withdmesg -wH` but the output gets cut out early on. It seems that it might be due to BFQ in the Manjaro kernel
This is what I got on my phone:
[Mar28 20:44] ------------[ cut here ]------------
[  +0.000578] kernel BUG at block/bfq.h:864!
[  +0.000445] invalid opcode: 0000 [#1] PREEMPT SMP
[  +0.000510] Modules linked in: ctr ccm fuse xt_CHECKSUM i
table_mangle ipt_REJECT nf_reject_ipv4 xt_tcpudp tun ipt_MA
QUERADE nf_nat_masquerade_ipv4 xfrm_user xfrm_algo iptable_
at nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 xt_addrtype
xt_conntrack nf_nat nf_conntrack br_netfilter bridge stp ll
 overlay arc4 ebtable_filter ebtables ip6table_filter ip6_t
bles iptable_filter rt73usb rt2x00usb rt2x00lib mac80211 cf
80211 input_leds led_class crc_itu_t mousedev joydev bnep s
d_hda_codec_hdmi sch_fq_codel snd_hda_codec_realtek snd_hda
codec_generic nvidia_drm(PO) nvidia_modeset(PO) uinput inte
_rapl x86_pkg_temp_thermal intel_powerclamp nvidia(PO) core
emp kvm_intel nls_iso8859_1 nls_cp437 vfat iTCO_wdt mei_wdt
fat kvm iTCO_vendor_support irqbypass crct10dif_pclmul evde
 mac_hid crc32_pclmul ghash_clmulni_intel
[  +0.017723]  mxm_wmi pcbc snd_hda_intel aesni_intel snd_h
a_codec aes_x86_64 snd_hda_core hci_uart crypto_simd snd_hw
ep glue_helper btbcm cryptd btqca btintel intel_cstate e100
e bluetooth snd_pcm intel_rapl_perf ptp snd_timer mei_me sn
 i2c_i801 pps_core soundcore mei rfkill intel_pch_thermal s
pchp video i2c_hid battery crc16 wmi fjes button intel_lpss
acpi acpi_als acpi_pad kfifo_buf intel_lpss industrialio tp
_tis tpm_tis_core tpm pci_stub vboxpci(O) vboxnetflt(O) vbo
netadp(O) vboxdrv(O) ttm drm_kms_helper drm syscopyarea sys
illrect sysimgblt fb_sys_fops sg ip_tables x_tables xfs lib
rc32c crc32c_generic hid_generic usbhid hid sd_mod crc32c_i
tel ahci libahci xhci_pci libata xhci_hcd scsi_mod usbcore
sb_common serio
I’ll try get more of the output from the desktop machine with a picture or recording if it helps. While debugging this and another kernel bug(which I think has similar output with BFQ) I disabled legacy USB which referred to it as 2.0, this has prevented me from using keyboard during boot and entering BIOS again :\ Not sure if I will reset the CMOS chip or go buy a PS/2 keyboard yet.
I did a recording, there wasn’t that much missed between the snippet I provided above and what I saw on the screen about BFQ. Changing the IO scheduler to something else like CFQ fixed logrotate service as well as the suspend/resume bug I and others have encountered on kernels greater than 4.8. So I guess this is solved?
Not sure what the systemd service for logrotate was doing that BFQ didn’t like :S It seems calling /usr/bin/logrotate /etc/logrotate.conf doesn’t seem to cause the lockup, the unit file is rather lengthy and unfamiliar for me though. I guess I should get in touch with the Manjaro team or BFQ dev about this?
I’m not entirely sure if I’ve fixed this as checking /var/log/ again the files timestamps don’t seem to change bar wtmp, wtmp.1.gz remains the same timestamp, no wtmp.2.gz generated. The unit/service status also doesn’t have any new entries in it’s log beyond the two starting lines:
● logrotate.service - Rotate log files
   Loaded: loaded (/usr/lib/systemd/system/logrotate.service; static; vendor preset: disabled)
   Active: inactive (dead) since Tue 2017-03-28 23:13:25 NZDT; 5min ago
  Process: 4851 ExecStart=/usr/bin/logrotate /etc/logrotate.conf (code=exited, status=0/SUCCESS)
 Main PID: 4851 (code=exited, status=0/SUCCESS)
      CPU: 3ms
Mar 28 23:13:25 pola-pc systemd[1]: Starting Rotate log files...
Mar 28 23:13:25 pola-pc systemd[1]: Started Rotate log files.
