After enable System-swap I got break no network Manager
Here is a log after systemctl enable --now systemd-swap
journalctl -b -1 -p3
-- Journal begins at Mon 2021-02-15 10:11:58 CET, ends at Mon 2021-02-15 12:00:>
Feb 15 11:32:45 yoga kernel: dw_dmac INTL9C60:00: Missing DT data
Feb 15 11:32:45 yoga kernel: ACPI BIOS Error (bug): Could not resolve symbol [\>
Feb 15 11:32:45 yoga kernel: ACPI Error: Aborting method \_SB.PCI0.B0D4._TMP du>
Feb 15 11:32:46 yoga kernel: proc: Bad value for 'hidepid'
Feb 15 11:33:07 yoga wpa_supplicant[735]: bgscan simple: Failed to enable signa>
Feb 15 11:35:23 yoga lightdm[3849]: gkr-pam: unable to locate daemon control fi>
Feb 15 11:59:23 yoga kernel: watchdog: watchdog0: watchdog did not stop!
then the log when I systemctl disable --now systemd-swap
Journal begins at Mon 2021-02-15 10:11:58 CET, ends at Mon 2021-02-15 12:02:32 CET. --
Feb 15 11:59:34 yoga kernel: dw_dmac INTL9C60:00: Missing DT data
Feb 15 11:59:34 yoga kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.HEC.PMAX], AE_NOT_FOUND (20190816/psargs-330)
Feb 15 11:59:34 yoga kernel: ACPI Error: Aborting method \_SB.PCI0.B0D4._TMP due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
Feb 15 11:59:35 yoga kernel: proc: Bad value for 'hidepid'
Feb 15 12:00:22 yoga systemd[1]: NetworkManager.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: avahi-daemon.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: bluetooth.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: iio-sensor-proxy.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: systemd-logind.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: lightdm.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: accounts-daemon.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: wpa_supplicant.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga systemd[1]: polkit.service: Unexpected error response from GetNameOwner(): Connection terminated
Feb 15 12:00:22 yoga kernel: proc: Bad value for 'hidepid'
Feb 15 12:00:24 yoga pulseaudio[1223]: Found duplicated D-Bus path for adapter /org/bluez/hci0
Feb 15 12:00:24 yoga kernel: proc: Bad value for 'hidepid'
Feb 15 12:01:36 yoga kernel: proc: Bad value for 'hidepid'
Feb 15 12:02:09 yoga kernel: watchdog: watchdog0: watchdog did not stop!
…seems that there is more problems but the connection is present.
here is the info
inxi -Fzxc0
Kernel: 5.4.95-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: Cinnamon 4.8.6 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80HE v: Lenovo YOGA 3 Pro-1370
serial: <filter>
Mobo: LENOVO model: VIUU4 v: 31900058 WIN serial: <filter> UEFI: LENOVO
v: A6CN58WW date: 08/06/2015
ID-1: BAT1 charge: 14.9 Wh condition: 30.1/44.0 Wh (68%)
model: Getac SDS-BAT status: Discharging
Info: Dual Core model: Intel Core M-5Y71 bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 4 MiB
bogomips: 11179
Speed: 798 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 798 2: 798
3: 799 4: 798
Device-1: Intel HD Graphics 5300 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0
Device-2: Acer Lenovo EasyCamera integrated webcam type: USB
driver: uvcvideo bus ID: 1-7:3
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting resolution: 3200x1800~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 5300 (BDW GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.95-1-MANJARO
Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter
vendor: Lenovo driver: wl v: kernel port: 3040 bus ID: 01:00.0
Device-1: Foxconn / Hon Hai BCM20702A0 type: USB driver: btusb v: 0.8
bus ID: 1-4:2
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 238.47 GiB used: 113.81 GiB (47.7%)
ID-1: /dev/sda vendor: LITE-ON model: L8H-256V2G size: 238.47 GiB
ID-1: / size: 14.4 GiB used: 5.3 GiB (36.8%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 49.9 MiB used: 678 KiB (1.3%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 224.02 GiB used: 108.51 GiB (48.4%) fs: btrfs
dev: /dev/sda4
System Temperatures: cpu: 47.0 C mobo: 29.8 C
Processes: 220 Uptime: 11m Memory: 7.69 GiB used: 1.63 GiB (21.2%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1237 Shell: Bash v: 5.1.0
inxi: 3.3.01
